LED drivers and Accessories you want, but don’t exist
498 posts / 0 new
Schoki
Schoki's picture
Last seen: 2 months 3 days ago
Oh I’m so sorry, I forgot to to write it down and tell you! You have to solder bridge the middle pad to one of the outer ones. It must not be left open. Do NOT short out all 3 pads. There’s a small “E” of enable, and a “D” for disable power save mode. You can look at the datasheet to learn a bit more about the two modes.
It’s there for better efficiency at low currents. Since your running it at 1.4A, short the middle one with the “D” next to it (I think it could have a bit higher efficiency). You can enable it if you want, but I would only activate it if I’m under 150mA.
Edit: The 6mA is mostly because of the OpAmp quiescent current. It’s about 4.6mA typically.
...don't tell me how electronic components work, i'm studying exactly that...
Lexel
Lexel's picture
Last seen: 2 days 37 min ago
Yeah I did solder the bridge, but still no output for the LED
Added C8 nothing changed
Checked the Buck chip for all connections and its fine
could you troubleshoot this driver if I send you 3 of them?
Schoki
Schoki's picture
I can troubleshoot them if you want, here are some pictures of the board and the schematic. Could you check all the traces? The pictures help you which pads are connected, check them for continuity. Could you make some photos of your boards as well? Link: https://imgur.com/a/315u7
If someone finds a mistake, please tell me.
Note: the one airwaire (coloured yellow) is there because Eagle won’t let me create polygons without something in it with the same signal. I placed a pad there on the bottom layer, so this one airwire can be ignored.
In the schematic, the pad on the input is called Bat-, it should be Bat+.
Lexel
Lexel's picture
I measured the board the connections from the buck/Boost driver to the other parts are all like the board design
and no shorts between two pins of the buck converter measured
I build now all 3 drivers and test if one works
Schoki
Schoki's picture
And just leave C8 open. Wait, is there a 206 resistor on R1? That is 20 mega ohm. You need 20 milli ohm there.
Jensen567
Last seen: 12 months 2 days ago
Was about to comment, R1 looks like sense resistor so I think 20m was 20 milliohm, 206 is 20 megaohm, so would make sense if no light with 20 meg in series with the emitter.
Lexel
Lexel's picture
OK it makes sense was a bit wondering about 20MOhms but I thought with C8 some kind of protection for the OPAmp
but as I had no layout I thought it is 20MOhms
Shoki you may have a 0,02Ohms 0603 resistor that you can send me 3?
or I add there some 0.02mm² wire of a certain length
I got here only 3 0.1Ohms 0805 resistors in my box
I think I got some dead Klarus XT11 Drivers I may salvage a few 0.05Ohm 0805 resistors
and a small zip lock filled with stripped driver parts I may find some small resistors
Schoki
Schoki's picture
I currently don’t have, but I can order some, wanted to make a mouser order this weekend for the new MP3431 board anyway. If you want I can buy some 20mOhm resistors and send them to you.
Do you have higher resistor values in the milli ohm region, just to check if the board works?
Schoki
Schoki's picture
The 0.02mm² wire won’t work, 1.4A through that is a bit too much (50mA is the maximum current for that size). For now, maybe a 0.1Ohms 0805 resistor fits. Just to make sure it works (and it should put out around 300mA). I can order some resistors for you, no problem.
And with 20MOhm, you were driving an LED with around 1.5nA LOL
Lexel
Lexel's picture
after looking on my dead drivers and an old motherboard I found suitable resistors
0.1+0.05+0.05 parallel are 0.2
and a way oversized 0.02 one
Schoki
Schoki's picture
If you can solder the three resistors on top of each other, go for it. Let me know if you then still need 3 0.02Ohm resistors.
Lexel
Lexel's picture
OK I stacked resistors on 2 drivers one without and one with C8 both do not light up
Ok found it I soldered positive to the wrong side of the spring pad on the one without capacitor
I get 1.65A on the one without capacitor
so I have to reduce R2?
Schoki
Schoki's picture
To get less current, the gain of the Opamp has to be increased. So R2 has to be higher, or R3 needs to be lower.
Lexel
Lexel's picture
stacked a 19.1k Ohms on R3 so I get 1.48A that seems OK for 1.4A UV emitter
if you do a order from Mouser or digikey soon could you get me 3 0603 0.02Ohms resistors?
Schoki
Schoki's picture
Good to know. And the other driver with C8?
Lexel
Lexel's picture
does not work even with removed capacitor, I think a contact of the boost converter is not connected
the 3. with only a 0.1Ohms resistor and capacitor works, at reduced current
Schoki
Schoki's picture
Was that a driver you powered on without shorting out two pads at first? Or have you tried the now working one without shorting the pads as well? Maybe the IC is toast because you tried it without shorting the pads at first.
OK, the 3rd one works as expected.
Lexel
Lexel's picture
Schoki wrote:
Was that a driver you powered on without shorting out two pads at first? Or have you tried the now working one without shorting the pads as well? Maybe the IC is toast…
I inspected it with magnification glass and it looked like the IC had no connection to the inductor on the side where it is hidden behind C1
I used very little paste on the outer pins of the IC to do no shorts there
OK reflowed it with a bit paste and now it works
this driver does spot on 1.41A, probably a lot variation on this 3 stacked sense resitors
Schoki
Schoki's picture
The IC itself has a feedback variation of +-5mV, the resistors have variation (1% or so), and the offset by the OpAmp adds some more.
Nice, now all drivers work?
Lexel
Lexel's picture
I have found out that the driver gets pretty hot and the output current drops with higher temperature slowly
on my bench one driver quit working
it was the one with the capacitor
removing the capacitor and the driver shows a fast strobe
adding it again and it is dead
it looks like a bad ground issue, need to add maybe a bit more paste to the IC
Schoki
Schoki's picture
A fast strobe? How fast? And it quit working? Was it still hot or cooled off already when the fast strobe occured?
Did it get hot in a flashlight, or was it on a bench uncooled?
Schoki
Schoki's picture
Even though it might have 90% efficiency, 0.5W or so will be heat.
Agro
Agro's picture
Last seen: 1 min 23 sec ago
Schoki, since you mentioned that 3×3 MCU is the max you can fit I did some research…
Would Silicon Labs C8051F52x/3x series work?
They:
  • are available in 3×3 mm 10-pin DFN package
  • have 2-8 KB flash
  • have 256 B RAM
  • have a 8051 core, max 25 MHz
  • work in 1.7V-5.25V range
  • work in -40 – 125 °C
  • have a temp sensor and PWM
  • cost more than ATTiny ($2-$2.5 in small quantities)
  • can be programmed with open source tools on Linux and closed source freeware on Windows (dunno about Mac / BSD / …)
  • the programmer hardware costs $35
Though that said, the new attinies which we can’t program may be close enough to make the porting effort not worthwhile…
Schoki
Schoki's picture
Thank you for looking for an alternative, i’ll look into it. But for now, I managed to squeeze an ATTiny25v on there, so bistro-hd would be possible.
The springpad is now smaller, but it should work (6.4mm diameter or so). It was possible because the ATTiny has one side of pins without any connection, so I removed these solder connections. On the other side, I just left the gnd pin.
One problem with other MCUs is that you have to change a lot in the code to make it run, so I hope it works like it is now.
I hope the 25v in a qfn package is a rev E at mouser. This is required to be able to run bistro-hd.
But since it’s a driver where a lot of current could flow, I maybe won’t even solder a spring on there. A piece of brass/copper could also work, and needs no bypass.
FreeMagenta
Last seen: 1 year 8 months ago
Hello.
Forgive me newbie question, but would it be possible to use something like TPS63024 for driving low Vf LEDs?…
Schoki
Schoki's picture
If Vf is between 2.5V and 3.6V, yes.
Schoki
Schoki's picture
Just ordered this, MP3431 board with (hopefully) bistro-HD:
It’s an 18mm board, but I’ll sand it down to 17mm to have copper right to the edge.
Flintrock
Last seen: 2 years 5 months ago
Ok, I finally found my way to thread instead of just the backroom PM discussions (that there have been a bunch of). Subscribed.
FWIW I've worked up a "Fet only" (ie single channel) configuration of bistro-HD (will be in next release, soon).  Been meaning to anyway (actually a few such configurations, switch, indicator, OTMS, etc).  It took a little compromising to match ramps to TA modegroups, mostly because without a 7135 you can't go below 11mA (1/255 * 2.8A) so modes get cutoff, but I've been thinking of ways to get around it.
16bit PWM, if the converter can actually handle such output or true, 2nd channel, enable pin PWM reduction, but Schoki says it's hard to fit the trace. 11mA ain't too bad though. It's not really moon, but it's low.
Flintrock
I thought I heard that this was going toward an attiny25 qfn, which I think is also on the scale of 3mm.  Anyway, if you can make it still flashable (soic as shown), that's great.
For software though, if you need more space, the qfn becomes a drop-in replacement from the software side.  Of course the qfn might make room for that extra trace.
Schoki
Schoki's picture
It is attiny25 qfn, the tiny is on the underside. I removed the pads that aren’t connected internally of the attiny, the springpad is now a little bit bigger.
