Review: FandyFire STL-V3 CREE XM-LT6 5-Mode
26 posts / 0 new
old4570
Last seen: 3 days 18 hours ago
FandyFire STL-V3 CREE XM-LT6 5-Mode 850-Lumen White LED Flashlight with Clip (1 x 18650)
Price: $40.80 @ time of review . [ Though I got this one when it was on sale @ DX ]
Brand:FandyFire
Model:STL-V3
Color:Black
Emitter Brand/Type:CREE
Emitter BIN:XM-LT6
Color BIN:White
Total Emitters:1
Battery Configurations:1 x 18650 (not included)
Voltage Input:3.2~8.4V
Switch Type:Clicky/Clickie
Switch Location:Tail-cap
Modes:5
Mode Memory:Yes
Mode Arrangement:High > Mid > Low > Fast strobe > SOS
Circuitry:Digital Regulated 2800mA Current Output
Brightness:850-Lumen
Runtime:2 hours
Lens:Glass lens
Reflector:Aluminum Smooth/SMO
Carrying Clip:Built-in
When I first saw this light , I thought it interesting , when DX put it on sale , it was too much , I had to buy it .
I really wasn't expecting to get this much flashlight for the money . Modes are set out  High - Medium - Low - Strobe - SOS and mode memory is about two seconds after turning the light of . The sample I got is extremely well made, surprisingly well  so . Build quality and finish is just great , I have nothing negative to say here , so lets move onto performance .
Freshly charged 18650's run the light [ measured at the tail ] from 1.9A to 2.12A on high , 0.83A to 0.87A on medium and 0.15A to 0.18A on low .
Doing a ceiling bounce test , the Fandyfire did some 66Lux , my Trustfire X9 some 62Lux , and my Kegos K5 some 49Lux , using the same battery ...
Lets try some throw figures @ 1 meter ...
The Fandyfire did some 33000Lux @ 1 meter
The Trustfire X9 some 36000Lux @ 1 meter [ 31000Lux with the same battery ]
And the Keygos did some 19000Lux @ 1 Meter
I have to say I am impressed with the Fandyfire , I didn't know how it would perform , and well , it does perform !
I don't have time for outdoor beams right now , but will update shortly with some comparison shots .
Back yard beams :
I will take some comparison shots , and post them in a day or so ...
Fandyfire - VS - X9 - VS - Keygos K5
Update:
Ok , the light is small , and not every 18700 fits well , tightening down the tailcap with some 18700 could be problematic , as long as the battery fits inside the body all should be fine , but if it sticks out , you may end up with a crush fit tightening the tailcap down . Forgot , will not like flat top batteries !
2x16340
Hi- 1.66a
Med- 0.71A
Low- 0.16A
Ceiling bounce 71Lux
throw 33800Lux
Some comparison shots :
http://img196.imageshack.us/img196/2459/91664092.jpg  KE-5
http://img193.imageshack.us/img193/79/50051412.jpg  X9
http://img528.imageshack.us/img528/2886/18645454.jpg  V3
http://img9.imageshack.us/img9/9727/pa40.jpg  PA-40
Click to view larger image ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 08/26/2014 - 17:21
how2
Last seen: 4 years 5 months ago
Nice review old4570.
What's the Trustfire and Keygos pulling in relation to the fandyfire?
The Fandyfire is pulling 2.12Amps on high. Is the Trustfire you got pulling 1.7Amps?
old4570
how2
So the Trustfire is pulling 2.3Apms on high.
That means the driver on the Fandyfire is slightly more efficient?
I wanted to get this but I was in two minds because it was a 45mm head.
Now I will get this or the Sky Ray version if I can get it for $30.
how2
Have you tried it with 2 x RCR123?
What's it pulling?
old4570
Its late , Ive got school tomorrow ...  I will update as time permits ...
_the_
_the_'s picture
Last seen: 3 hours 30 min ago
What's it pulling?
Mine pulls 1.57A from 2 x 16340 TF Flames (2.2A from 18650)
=the=
old4570
_the_ wrote:
What's it pulling?
How do you like it so far ?
_the_
_the_'s picture
Nice review old4570!
I can confirm the relative lux readings: FF STL-V3 gives ~150%of Keygos KE5, but ~50% of FF STL-V6 (my readings for these three were something like 17kcd, 25kcd and 50kcd measured at 2m and converted back to 1m)
Edit: There might be something wrong, since 17kcd for Keygos sounds a bit too little. Have to check again later.
=the=
_the_
_the_'s picture
So far so good. It's small, almost pocketable, has a clip, is bright and throws well. My favorite 1x18650 thrower at the moment.
Ps. I was about to write a review next weekend but you were faster. Smile
=the=
old4570
16340
Hi- 1.66a
Med- 0.71A
Low- 0.16A
throw 33800Lux
So there is a nice little boost from 8.4v / would love to see a extension tube ... for 2x18650
2100
It's not too little.  My U80 does that but with the under reading meter.
Plus you definitely cannot measure at 2m.
_the_
_the_'s picture
Actually I have the same under reading meter. Smile
..and I know that 2m is too little for real throwers, but that was the best I could do yesterday. (I was just curious to see if STL-V3 really outshines KE5 by that much, and considered 2m as "good enough" for relative throw figures)
=the=
old4570
Updated with some nice outdoor beams !
VFMaddict
old4570 wrote:
16340
Hi- 1.66a
Med- 0.71A
Low- 0.16A
throw 33800Lux
Have you ever tried 2*IMR 18350's?
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
old4570
VFMaddict wrote:
old4570 wrote:
16340
Hi- 1.66a
Med- 0.71A
Low- 0.16A
throw 33800Lux
Dont own two 18350 IMR [ or one even ]
kragmutt
Last seen: 1 year 1 month ago
I just got mine yesterday. Definitely nice finish. Yeah, I was measuring the tailcap amps and it read around 1.8 A on high which I was kinda disappointed with. Was really hoping the driver was actually regulated at 2800 mAh like it says, but alas it is not the case. Still really bright though. I was hoping this would be like the X9 but with a better driver that I wouldn't need to replace to get over 2 amps. So is this driver regulated or not? How to find out?
old4570
I would say @ 8.4v or 2x16340 etc , it would be regulated ...
With a single 18650 , probably not so
Test regulation - Buy a light meter , and a Multi Meter ..  Test battery voltage and then test output , where output drops , flashlight falls out of regulation ...
sb56637
sb56637's picture
Last seen: 1 day 15 hours ago
Hi there old, sorry I missed this review. Very well done as usual. Frontpage'd and Sticky'd now.
Rusty Joe
Rusty Joe's picture
Last seen: 3 weeks 6 days ago
How does this stack up against the Uf980 in straight-up output?
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
VFMaddict
Its only just dawned on me that this is supposed to be a (Q5) clone of the Fandyfire STL-V3.    An XM-L mod of it may provide similar results for about half the price...Smile
viffer750
Last seen: 2 years 2 months ago
And what's about  this?
http://www.ebay.com/itm/1300Lm-CREE-XM-L-T6-LED-Flashlight-Torch-Lamp-Light-/300641203038?pt=US_Flashlights&hash=item45ff9cb35e
Now it isn't alive, but after the spring festival I will order one.
unique engrish language... Smile
old4570
Nice find , same with the Ebay light ---
agedbriar
Last seen: 1 month 1 week ago
Why not this one?
http://www.dealextreme.com/p/jacob-a60-cree-q5-3-mode-310lm-white-led-flashlight-w-strap-black-1-x-18650-114268?r=43033281
It has a bigger reflector and looks well-made. I have one on order.
_the_
_the_'s picture
agedbriar wrote:
Why not this one?
That looks very well-made, especially for that price.
Please write a review when you get it, ok?
=the=
agedbriar
By the time I get it, I'll forget any promise made.  Wink
But yes, of course!
