Cheap 26650 flashlight defective
21 posts / 0 new
ifratos
ifratos's picture
Last seen: 1 hour 31 min ago
Bought on Alie this flashlight:
https://www.aliexpress.com/item/High-Quality-New-Arrival-2300-Lumens-Sup...
and stop working.Start only in SOS mode sometime and stops only removing battery.
Any suggestion for repair/replace the driver, the led is OK.
Thanks!
And God said, Let there be light: and there was light.( Gen.1:3)
Edited by: ifratos on 09/09/2017 - 02:37
ifratos
ifratos's picture
No one can help?
luminarium iaculator
luminarium iaculator's picture
Last seen: 10 hours 38 min ago
Don’t bother with that driver… Swap with the one you like. Since this is around 20mm driver you could use it as a host and piggy back 17mm fet driver for example.
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
Jerommel
Jerommel's picture
Last seen: 7 hours 30 min ago
He needs an e-switch driver for this light.
This could be good:
https://www.aliexpress.com/store/product/Flashlight-driver-Flashlight-ci...
(edit) Hmm… that driver costs more than the light itself… Party
That’s really cheap though. Shocked
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
ifratos
ifratos's picture
Thanks!
On led is written : XPG – U2
Will work fine with that driver?
Or is better to buy also a good led and yes will cost quite enough but I will turn the cheapo into a real beast?
L4M4
L4M4's picture
Last seen: 1 hour 29 min ago
This LED isn’t a XP-G2, it’s not even a Cree LED.
It looks like a LG or generic 3535 LED.
That driver is made for 10W LEDs – the LED here is 3W at max.
3Amps and this thing will be dead in a very short time.
https://www.gearbest.com/led-flashlights/pp_536609.html?wid=21 + the code “harvest090” = 12.99$
Or this Convoy for under 10$: https://www.gearbest.com/led-flashlights/pp_44144.html?lkid=10940187
Both are waaaaayyyyy better that this generic AliExpress-Flashlight Wink
I would get the Zanflare.
Newer LED, in built charger and nice tint.
ifratos
ifratos's picture
I have Convoy S2 and C8 on the road in 2-3 days will arrive,Zanflare cost too much for a budget member, I don’t want to move on candle forum Smile but I don’t know why I fell the need to repair that cheapo, I hear my brothers in lights screaming : mod ,mod,mod,mod !!!!
The Last Katun
The Last Katun's picture
Last seen: 21 hours 8 min ago
I have two identical flashlights; but be careful about the changes: the LED does not have a dissipation base, it is only held by a ring, and the LED rests on the edges of the ring; Pil, in practice, does not exist
Lightbringer
Lightbringer's picture
Last seen: 1 hour 57 min ago
Not to sound like a downer, but honestly, I wouldn’t even bother trying to fix it. Into the trash it goes…
But it is a Superlight! Smile
Just direct drive it and be happy with high mode only. It won’t cost you nothing but don’t use it more than a minute or two continuously or you’ll cook the emitter.
Old-Lumens
Lightbringer
That’s what scares me… Shocked
Jerommel
Jerommel's picture
LOL Big Smile
I would like to see a tear down of it.
Maybe it’s moddable.
Jerommel
Jerommel's picture
This:
Quote:
https://www.gearbest.com/led-flashlights/pp_536609.html?wid=21 (link is external) + the code “harvest090” = 12.99$
Best deal ever for the F1.
Did you see the price?
It’s a steal.
I have a weak spot for cheapo lights too.
And for that price this seems interesting, with its 26650 size and an e-switch.
But that’s where the problems begin: The driver obviously sucks… And now yours is broken.
The LED is a fake Cree of course, so that has to go too.
But is it worth the work as a host?
How is the anodizing? (but then again, you could always de-anodize it in a lye solution)
How are the threads?
Does it have a tail switch too? (pics on AE suggest there is a tail switch)
Could you take some pictures of the parts and post them here?
ifratos
ifratos's picture
Finally somebody understand: is a SuperLight and I cannot put to trash a superlight.
Don’t have cooper pill or authentic cree but found thermal paste behinde led.
Now seriously works with 26650 and I have couple and have very nice beam and strong enough for a cheapo.
What I have in my mind ?
Because allready ordered S2 ,C8 and now F1 (12.99-thanks) I want to use spare parts that I have , to adapt driver , drill tail and put there ordinary switch and back to life that SuperLight.
Jerommel
Jerommel's picture
Ah, thanks for the tear down picture. Thumbs Up
I can’t really see it too well, but when you say the LED board has thermal grease on the back, it means the pill has a shelf, it is not hollow.
A plastic reflector, but those can be good too.
Enough threads on the battery tube too.
All the O-rings are there.
How about the lens? Is it glass or plastic?
With a normal driver you could use the side switch for “turbo blast” Big Smile
You could switch a FET with that, or an extra bunch of 7135. (for example, 6× 7135 driver and 6 extra 7135 for ‘turbo’)
Could be good with a SST-40 LED.
The Last Katun
ifratos flashlight works only in SOS. SOS mode will enter only by holding down the side switch for a long time; so for me, the driver is good but the side switch is locked to “on”
ifratos
ifratos's picture
Good idea , I will try to change the e-switch before any modding.There is some way to by-pass to be sure that is defective?
The Last Katun
Yes; insert the battery and then make short contact with the negative pole; it should enter other modes (low, strobe) for about two seconds, after about two seconds, the switch in ON will have the upper hand.
ifratos
ifratos's picture
I removed the switch and here is the result
ifratos
ifratos's picture
Obvious the driver is damaged so I start to mod….
The spare parts:
The plate for driver with driver( artistic shape Smile ) :
The driver mounted :
First test ,working and comparising with ultrafire C8 on high:
….. Tomorow the swicht
SkOrPn
SkOrPn's picture
I just noticed the same thing on one of my brothers 26650 flashlights. I was going to drop a BLF A6 and a XP-L HI V3 on 20mm Noctigon star until I noticed this oversight. Now I guess I need to add some metal heat sinking to the back of the star if I plan to use this BLF A6 driver? Right? My Google searching for a heat dissipation base, or for maybe an adapter to adapt a 16mm star to this 20mm hole insert (just for the extra metal behind the star) has not been so great. I can find sinks all day long but they are all bigger in size and I want something around maybe 16mm (the hollow hole looks to be about 17mm). So, maybe I need to ask someone to machine me something to fit the hole? Is there anyone here at BLF that can do that service? The hollow area is deep maybe 23-25mm or about (I need to keep room for the driver though). If I could machine an exact piece of metal, maybe say a round 17mm x 20mm and include two drilled lead holes I could reasonably add plenty of heat dissipation I would think. And if it just barely fits then I could solder it in for even more dissipation.
This cheap host looked decent enough for modding before I opened it. I have modded flashlights before but I never seen one that is hollow behind the LED. Image below. What to do now?
https://i.imgur.com/I117CRTl.jpg
P.S. sorry to hijack the thread, but I posted here because my title was going to be near identical, lol. Cheap 26650 flashlight needs a serious mod, BUT. Wink
