MatchBox Instruments HF-R Ti Mods
11 posts / 0 new
CRX
CRX's picture
Last seen: 5 min 47 sec ago
MBI HF-R Ti Nichia 219C 4000K 90CRI - 10440 - Rotary Tail & Mo Side Sw - Rechargeable - 620lm.Nichia 219C 4000K 90CRI emitter
12mm Copper DTP MCPCB
ARC glass
OP reflector
Five Mode Resistor Driver
Lighted Momentary DD side switch
Switch Position Locators
Red 6mm x 1.5mm tritium vial
Length - 101 mm
Width - 14 mm
Weight - 49g (With 10440 cell)
Max around – 620lm OTFMBI HF-R Ti Nichia 219C 4000K 90CRI - 10440 - Rotary Tail & Mo Side Sw - Rechargeable - 620lm.
MBI HF-R Ti runtime graph:
MBI HF-R Head & Tail construction:The original resistor values in the switch are:
92A – 887Ω
201 – 200Ω
150 – 15 Ω
5R1 – 5.1Ω
0 – 0Ω
Body parts modified.
USB Charging Module & Lighted Momentary Side Switch built into the 10250 extension piece.
Switch Resistor Changes & Modes:
Momentary mode – 620lm
92A – 887Ω to 1Ω – 210lm
201 – 200Ω to 2Ω – 142lm
150 – 15 Ω to same – 28lm
5R1 – 5.1Ω to 200Ω – 2lm
0 – 0Ω to 887Ω – 0.5lm
USB Charging Current - 250mA.
Other modded versions:
MBI HF-R Ti MT-G2 P0 5000K - 2x10250 - Rotary Tail Sw & Mo Side Sw - 1260lm.MBI HF-R Ti MT-G2 P0 5000K - 2x10250 - Rotary Tail Sw & Mo Side Sw - 1260lm.
MBI HF-R Copper Nichia 219B - 10250 10440 - Rotary Tail Sw - 450lm.MBI HF-R Copper Nichia 219B - 10250 10440 - Rotary Tail Sw - 450lm.
MBI HF-R Ti Nichia 219C 4000K 90CRI - Glow Reflector - 10440 - Rotary Tail - 500lm.MBI HF-R Ti Nichia 219C 5700K - 10440 - Rotary Tail & Mo Side Sw - 660lm.MBI HF-R Ti Nichia 219C 5700K - 10440 - Rotary Tail & Mo Side Sw - 660lm.
Edited by: CRX on 11/24/2019 - 06:31
Persechini
Persechini's picture
Last seen: 2 months 5 days ago
Always the coolest builds
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
i42dk
i42dk's picture
Last seen: 2 hours 6 min ago
Pure porn Love
FPV
FPV's picture
Last seen: 4 months 1 week ago
Unreal
vwpieces
vwpieces's picture
Last seen: 2 days 13 hours ago
Wow, Nice work. That is an ODD one. Like a resistor fan SW.
Consider a Pot in the tail?
CRX
CRX's picture
Nice idea, probably could but I do prefer set modes as opposed to variable output.
Taking this one apart has given me some ideas for future builds though Wink
ChibiM
ChibiM's picture
Last seen: 6 hours 41 min ago
I think something may be going on with Guy from MBI. He hasnt been online for a while and his website is down since a few days.
Cyzan
Can I ask what size wire is used in the hf-r. Or what size you used if you replaced it.
CRX
CRX's picture
Possibly 30AWG & 28AWG.
djozz
djozz's picture
Last seen: 2 min 10 sec ago
Another monumental build! Very nice work CRX!
I do not understand everything that happens though, your pictures without words always make it quite a tough puzzle to work out eveything that is going on.
CRX
CRX's picture
I thought pictures spoke a thousand words! Big Smile
I know, I’m bad for that but it makes people think about it a little Evil
I think I did the MT-G2 mod first then the other emitter swaps and then seeing what I could eventually pack into the tiny host.
I basically swapped resistor values, changed them around so the switch works the opposite way, upgraded everything and built in a lighted side switch.
Then I also added a tiny charger unit into the 10250 cell extension piece which also has the lighted momentary side switch. very useful that one.
So, the longer version ended up with built in charging and a momentary lighted side switch.
The copper version was a repair job & new emitter.
The short Ti version has a shortened rotary switch and GITD coated reflector.
