Mod: Olight SR Mini with triple SST-40 and host bypass.
14 posts / 0 new
Mike C
Mike C's picture
I received a SR Mini some year ago with a broken driver and no LEDs to play with. I didn’t know what to do with it as it’s a little too big for the standard triple and it the time I didn’t make E-switch only drivers, so in the drawer it went to collect dust.
I only recently learned about the SST-40 LED’s characteristics and XM-L compatible size, but when I did I immediately thought of the SR Mini in my drawer and ordered three SST-40s on MCPCBs. However, when I took the light apart I noticed that the empty MCPCB in this light was a good copper MCPCB with direct thermal path, so I decided to move my LEDs over to it instead of gluing on the three seperate MCPCBs. However, it was for LEDs in series so I hacked up some traces and scraped away some coating to make all LEDs in parallel with solder points.
MCPCB is screwed in place too, so it’s a nice fit. Each LED got it’s own set of 22 awg wires:
I combined the three + wires and three – wires to 18 awg wires and drilled out the hole a little:
Before considering making a custom driver I decided to build it with one of my existing FET + 8 × 7135 drivers and use the original as BAT+ contact plate, which I hacked up a little to accommodate spring bypass wires:
The BAT+ contact plate put together (solder blobs added later):
This light comes with a USB charger port. My own drivers don’t (yet) support USB charging so I ripped it out. However, it’s location is interesting, it’s on the side of the battery tube:
On closer inspection it turned out that the hole for the USB charger wires actually runs through the entire host:
So I ran a 18 awg GND wire from the driver through this hole all the way to the back, soldered it to the back plate together with the rear spring bypass wires, essentially creating a host bypass. I now have both BAT+ and BAT- in direct contact with my driver with 18 awg wires. I just had to remove one of those plastic battery spacers that prevents the contact board from rotating when screwing on the tailcap:
Assembling is a little tight, but there is enough room for the wires to twist while screwing it together. A custom made driver will make this easier, but it’s currently good enough for testing so I just added some kapton tape to prevent any shorts to the host:
As everything is now held together by wires it’s a little finicky to pull a part and put back together. The longer the wires, the more finicky it gets, but I wanted some extra so I can chop it up a little once I get the custom driver made. Rather too long than too short!
In with some three freshly charged LG cells and check amp readings. I took my clamp meter and measured the amps for 1, 2 and 8 × 7135s turned on and the readings where accurate, so I slammed on boost mode with FET full on. Man, it puts out light! The clamp read 24.5 amps. That’s just over 8 amps per LED, and is about where I wanted to be since djozz tested an SST-40 to it’s death at 9.5 amps.
It’s a nice size for the hand, and with three 18650 cells I’ll get decent run times during normal use, and a lot light when I want it. So far I like it so I’m going to design my own custom driver for it as it might very well be my go to light for my exploration trips underground.
Update 12/22/2017
I’ve now taken some beamshots with 2 other lights for comparison: A M2 quad XPL-HI 5000K with 10621 Carclo lens that pulls around 10 amps, and my BMF SRK with 3 x MT-G2 5000K that pulls around 15 amps. I set a little too fast shutter speed because the photos don’t look like much but they are OK for comparison as all photos are taken with the exact same settings set manually. I can’t set a white balance number of my choice with my camera so I selected daylight 5200K.
M2 quad:
BMF SRK:
SR Mini:
M2 quad:
BMF SRK:
SR Mini:
Edited by: Mike C on 12/22/2017 - 05:57
Mike C
Mike C's picture
Reserved for future upgrades…
I’ve designed and ordered a custom driver for it. It’s based on my ATtiny1634 drivers with a FET and 8 × 7135. The screw holes where not on aligned so instead of risking having with slightly off I skipped them altogether and will drill them manually when it’s in place. I’ve also added some vias for output pins as I plan on adding a multi color lighted switch with color control.
sovereignknight
sovereignknight's picture
Last seen: 2 days 1 hour ago
Night shots! Bring on the night shots!
https://en.wikipedia.org/wiki/John_3:16
Flashlights:
x6 Sk68 modded 3 Nichia 319AT, 3 Cree XP-G3 - x1 Solorforce P60 drop in custom XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver - x2 Lumintop EDC05 CW - x2 Jaxman E2L tripple XP-G2 S4
x1 Jaxman Z1 Zoomie, Cree MT-G2 Q0 LED - x1 Acebeam K40m thrower with MT-G2 Q0 LED - x1 Xintd SC-82 V5 Limited Edition C8, XM-L2 U4 1C, Qlight Rev.A 7135*8 3.04A Driver
x1 Convoy L6 moded with a Cree XHP-70.2 P2 1D LED - x1 Rare Olight x7 Maurauder with a Nuetral White LED - x1 Astrolux MF-01 Nichia 219c - x1 Astrolux MF-01 Cree XP-G3 - x2 Zebralight SC5w MKII
x6 Lumintop Tool AA - x1  x2 Lumintop Tool AA 2.0 - x1 Lumintop ODL20C - x1 Lumintop GT mini - Olight i3E EOS - x2 Zebralight SC600w Plus MK IV XHP 50.2 4500k 80 CRI - x1 Fenix CL30R - x1 Lumintop C01 Bike Light
CRX
CRX's picture
Last seen: 2 hours 48 min ago
Nice mod Thumbs Up
Mike C
Mike C's picture
Alrighty, I’ll get it done within a few days. I’ll take a triple, a quad and my BLF SRK (triple MT-G2) and make some comparison shots.
FmC
FmC's picture
Last seen: 7 hours 45 min ago
Nice mod Thumbs Up
I have 3 SST 40’s sitting here, & don’t yet know what to put them in…
EasyB
Last seen: 7 hours 23 min ago
Nice mod. Really driving those SST40s to their full potential. Thumbs Up
Mike C
Mike C's picture
Thanks guys!
Put them to use! Seeing that clamp meter measurement is a joy in it’s self Smile
DENGOH
DENGOH's picture
Last seen: 11 sec ago
Host bypass Big Smile
cool i'll see you when you get there
MRsDNF
MRsDNF's picture
Last seen: 2 hours 3 min ago
Nice mod Mike. Good to see the old host put to s good use. Silly
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
18sixfifty
18sixfifty's picture
Nice mod and great job overcoming the obstacles in the way of making this possible.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
Majoroverkill
Majoroverkill's picture
Do you have any beam shots of this little monster? Cool
Doug S.
Mike C
Mike C's picture
Thanks guys!
Coming. Right now I’ve taken it apart to make measurements of the original driver I used as battery contact plate. When I like a light this much I feel it deserves it’s own dedicated driver instead of a loose driver attached only by wires. I hope to get the beam shots done this weekend though!
Mike C
Mike C's picture
Beamshots added to bottom of OP… Unfortunately a little too fast shutter speed so they are a little too dark but I have comparison shots with two other lights taken with the same camera settings.
I’ve also designed and ordered a custom driver for it. It’s based on my ATtiny1634 drivers with a FET and 8 × 7135. The screw holes where not evenly aligned with anything else on the original driver so instead of risking having with slightly off I skipped them altogether and will drill them manually when I’ve put it in place. Besides the programming vias I’ve also added some from unused output pins as I plan on adding a multi color lighted switch with color control.
