Sofirn C8F host. 21700 C8F Available
1389 posts / 0 new
contactcr
Last seen: 39 min 40 sec ago
Check and see if your spring bypass is still secure too. Could it be triggering the battery protection (you said laptop pull) when a loose bypass wire makes connection with less resistance (on either end really)
DB Custom
DB Custom's picture
Last seen: 26 min 24 sec ago
This light is made to accept the non-anodized threads into the head of the light. Anodized threads at the tail cap. Without having pictures of the actual arrangement of the wires and such, it’s just impossible to predict what the problem might be. The simplest and easiest to make mistake is to reassemble with the battery tube inverted, causing contact issues. Other than that, there shouldn’t be any issue if all the contacts are made properly.
Keeping the wires long from the MCPCB allows the light to be assembled, but they need to be cut off just long enough to solder onto the driver, this will prevent an excess of wires in the driver bay. Done this way, even 18ga wires will work…
Scientist
Scientist's picture
Last seen: 3 min 2 sec ago
I will have to check. I remember having the non anodized threads at the head. That is why I kept the tube unscrewed at the head, I figured the tail cap had to be on tight to make contact. The light does light, just not when the head threads are tightened up. I remember a previous thread somewhere about this happening and if I remember right the springs were pushing so hard on the battery that it deformed the battery causing loss of current. I’m not sure why this would happen as I haven’t done any modification of the tube or cap.
Scientist
Scientist's picture
Can you explain a little more how this would happen and how it triggers protection? To me if the bypass is loose there would still be current flow through the spring.
DB Custom
DB Custom's picture
The bypass would not affect operation, and you clearly stated that you were using a flat top cell pulled from a laptop battery pack, no protection circuit on these. They tend to not be the most capable cell out there, but should still work fine even if not making as much output as a top cell.
Scientist
Scientist's picture
Thank you Dale. I am following in your footsteps with a UV light build in this nice host. Will post details if I can get the thing working right. I wanted to start slow with a cruddy battery since I am not quite sure how the emitters will handle full power.
DB Custom
DB Custom's picture
UV emitters are typically much lower voltage/current, like 700mW or 1000mW, so if you aren’t taking precaution to keep power level to their requirements you’re gonna blow 3 UV emitters in a big hurry.
Scientist
Scientist's picture
While we’re on the subject, what current do you think the Sofirn driver puts out with an average battery for the C8F, no DB Custom FET mods?
robo819
robo819's picture
Last seen: 1 day 5 hours ago
I reviewed one of these and I am in contact with Dale comparing notes a lot of times also.
with everything as the light comes out of the box , I would say 8.5 to 9.5 amps would be a good average to expect from the included cell or a quality high drain cell.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Scientist
Scientist's picture
Thanks Robo. I am assuming that is on Turbo.
robo819
robo819's picture
Yes on Turbo and at the tailend.
gravelmonkey
Last seen: 14 hours 36 min ago
Stupid question, but does the host come with the side clicky e switch included?
contactcr
Yes it’s already installed with wire leads
teacher
teacher's picture
If I read correctly… it does.
thijsco19
Last seen: 2 hours 40 min ago
Did a quick search but didn’t find anything.
Did anyone mod this light with 3x sst-40 using a fet driver or other high performance driver?
If so, how much lumens did you got?
g_damian
g_damian's picture
Last seen: 18 min 28 sec ago
C8F has arrived! Here is my build. It is nice that it came without any engraving.
Lexel
Lexel's picture
Last seen: 25 min 26 sec ago
Yeah received yesterday unbranded host, quite heavy for a C8
I am not sure if I like the smooth host, a bit knurling would have been nice
I wish there would be a transparent switch cover included for lighted switch board, but I will look into it later if I can find a solution
gchart
gchart's picture
Last seen: 1 hour 26 min ago
Yeah, their hosts are unbranded. I love that they did that. My regular Sofirn C8 is the same way. Kinda wish Convoy did that.
johnkey68
Last seen: 10 hours 32 min ago
Hello friend! Began to collect a flashlight sent from Sofirn and found that the electronic button does not have a free wheeling and is not pressed. That is, it stands in one, jammed position. What to do ? Where to buy a similar button? Maybe she understands? I wrote to the seller, I’ll see what answers.
!DSC_0682.jpg!
!DSC_0684.jpg!
!DSC_0685.jpg!
!DSC_0686.jpg!
!DSC_0687.jpg!
!DSC_0689.jpg!
djozz
djozz's picture
Last seen: 1 hour 8 min ago
That is some fine machining johnkey! Those switches can be found easily, I’m on my phone now but I will get you a link later.
Why did you choose for a TIR optic?
johnkey68
Experiments. Boredom. Innocent
!DSC_0248.jpg!
djozz
djozz's picture
Cool That is sound flashaholic reasoning. Big Smile
Nice line-up!
johnkey68
djozz wrote:
That is some fine machining johnkey! Those switches can be found easily, I’m on my phone now but I will get you a link later. Why did you choose for a TIR optic?
Wrote about the problem in the shop Sofirn on Ali.
Already sent and given a track number.
Simply good fellows!
Still found ….
https://ru.aliexpress.com/item/SMD-Tact-Switch-4-4-1-5-5-5-1-5mm-copper-...
Jerommel
Jerommel's picture
Last seen: 11 min 19 sec ago
I don’t understand:
Why would anyone want to replace the Sofirn triple LED PCB with a Noctigon?
Both are copper DTP.
DB Custom
DB Custom's picture
I can understand going to the Noctigon for it’s 3 oz copper traces, have no idea why the awesome reflector was cut into a spacer in favor of the boring CUTE-3 optics though. The triple reflector is what makes the Sofirn a game changer. Much tighter beam from the reflector. But then, I’ve built so many dozens of CUTE-3 optic triples…
Just goes to show, different strokes for different folks!
Bo4ka
Last seen: 2 days 8 hours ago
Can someone recommend me a driver and mcpcb for 3 xpl hi configuration?
Btw do I need to by extra centering rings for the emitters?
What’s about the lense, is it anti reflective?
g_damian
g_damian's picture
Bo4ka wrote:
Can someone recommend me a driver and mcpcb for 3 xpl hi configuration? Btw do I need to by extra centering rings for the emitters? What’s about the lense, is it anti reflective?
Here is my build.
I think lense is plain glass.
Bo4ka
g_damian wrote:
Here is my build.
Which mcpcb?
g_damian
g_damian's picture
Bo4ka wrote:
g_damian wrote:
Here is my build.
Which mcpcb?
Stock, it came with a host.
Zappaman
Zappaman's picture
Last seen: 2 days 7 hours ago
Bo4ka wrote:
Can someone recommend me a driver and mcpcb for 3 xpl hi configuration? Btw do I need to by extra centering rings for the emitters? What's about the lense, is it anti reflective?
I am waiting on my C8F kits (bought TWO) and I'm a newbie-- but I have had great help from several dudes here.
I also was wondering about a driver, but after chatting with Lexel... given my 30Q batteries (and other good high drain batteries available) AND using (3) XP-L2 LEDs (bought from Arrow last week), this light can run true direct drive using just the rear switch (and get a draw of about 12-14 amps into these three LEDs- a nice fit!).  I maybe should have gone with XPL-HI LEDs for my application (hunting = throw needed), but I'm going to try the XP-L2 for now and "see" what I get for my pig hunting rig (as I don't shoot pigs past 150 yards anyway).
Lexel sells a cool little C8 "FET tail switch board" (to use with a pressure switch of your choice) for a hunting rig. I am using these for my "Pig Rig" (my 6.8 SPC rifle I shoot pigs with at night) where there is NO loss (not even drain loss) and FULL output is the result (since higher current lights otherwise lose a LOT taking the trip down the 16" or thinner wire and back on your run-of-the-mill pressure switches out there).
So my "Rev A" plan (was)... Use these FET tailboards as my ONLY switch in my C8Fs and going DD (Direct Drive).  I WAS originally building for hunting ONLY-- as I wanted NO modes- just FULL on and FULL off for hunting.
But...  I was ALSO JUST told by Lexel (nice guy, I ask him way too many questions- poor guy foot-in-mouth) that I can ALSO use his Narsil driver too. This driver can be set-up for ONE mode (on and off) or run other modes.  I thought it through and going with this driver is probably a better option to running pure DD... especially if you want some protection features for the batteries.  Lexel said I can hunt with his FET pressure switch (using just the on/off full Turbo mode), but when done hunting- replace the original rear switch (going back to stock) and THEN... this C8F with his Narsil driver would ALSO work with the side switch (in any mode). Thumbs Up
So I'm now going to buy a pair of Lexel's drivers as they will give me a light that will be useful to me the other 10 months of the year I am not pig hunting ;).
All I have to do is build a few tail switches (I have the FET boards, just waiting on the C8Fs kits so I can get started) and I can use the ones that come with the kit, OR buy a spare tail switch or two (or in my case, I HOPE to use the spare C8s tail switches in my spare parts drawer for the FET mods-- but have to see IF THEY FIT this C8F first!)  Come on Sofirn Boat!  FULL speed ahead please!laughing
ZappaMan
