Sofirn C8F host. 21700 C8F Available
1391 posts / 0 new
Jaded
Jaded's picture
Last seen: 10 months 1 week ago
I hope you don’t fall for that. Once you close the dispute, AE might see the issue as resolved. Also, you have no assurance that the seller will honor his word.
beam0
beam0's picture
Last seen: 1 year 6 months ago
Jerommel wrote:
I can confirm Convoy C8 battery tube and tail cap fit on the Sofirn C8F
In fact, i bought a Convoy C8 host just to swap the tube and tail cap, because i personally like the classic C8, where the tail cap design matches the head design, and i prefer the Convoy knurdled battery tube too.
So now i also have a Sofirn C8 host without any switch.. Big Smile
Same here, I recently bought a Convoy C8 and also decided to use it’s tube and tail for the same reasons. Also installed the Convoy SS bezel. Now I have a Sofvoy C8F!
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
beam0
beam0's picture
DB Custom wrote:
The new C8F comes with XP-L2’s in a nice tint, makes 3000 lumens out of the box with the supplied cell. Hard to go wrong there.
Dale, this may have been brought up already, was this statement you posted way earlier in this thread a mistake? (post #81) I only see the C8A with XP-L2.
This was pointed out in another thread and I wanted to clear up any confusion, including my own.
JasonWW
JasonWW's picture
Last seen: 6 hours 30 min ago
beam0 wrote:
DB Custom wrote:
The first one came with an aluminum mcpcb and XP-G3’s, the emitters couldn’t take a high discharge cell on that board. So I modified it.
Are you asking about the early version of the C8F?
It had no side switch. Had the aluminum mcpcb. Had xpg3’s. Had a rear tail switch.
They don’t sell that version anymore as they tended to burn up the emitters.
They redesigned it to what you see today. I wish they had changed the name to signify the difference, but they are both called the C8F. Hopefully everyone will forget about the first version.
Click this to go to signature links.
beam0
beam0's picture
No I’m not asking about the C8F v1 (I have both v1 & v2)
My question for Dale was for his statement (I put in bold and underline) in his earlier post (post#81) where he stated that the “NEW” C8F comes with XP-L2’s. But as far as I know it didn’t, only regular XPL. Unless I missed something.
I’ll edit out the first part of his quote in my post to avoid this kind of confusion in what I’m asking about.
JasonWW
JasonWW's picture
Oh. Okay.
Yeah, Dale made a mistake in saying that. It comes with xpl’s.
I’m sure he’ll be a long soon to give more details.
See his review over here.
http://budgetlightforum.com/node/57806
contactcr
Last seen: 4 hours 9 min ago
Just FYI I have the XPL2’s in mine as well (built from a host, not from Sofrin) and the few hundred lumens increase comes with a yellow corona trade off. You aren’t missing anything unless all you care about is MORE POWER!!
JasonWW
JasonWW's picture
Did you swap to a better quality FET to get even more output? The one Sofrin uses is not so efficient.
contactcr
It’s a MTN fet+1
JasonWW
JasonWW's picture
Doh. Facepalm
The host does not come with driver. I forgot.
t18d16
t18d16's picture
I am still a novice when it comes to building lights (so far built a 85cri-nw with Convoy S2+ and a cyan with Convoy M1). I am in the middle of building a triple r9080sw45 219b (thanks clemence!) using this host. I plan to run it at a conservative 2A (I hate turbo modes and my country has warm climate), and the experience so far has been daunting.
I couldn’t use Sofirn’s fet driver as the current would be too high. So I thought I would go with a Nanjg 105C. Could not afford a Pomona soic clip, so hand soldered the attiny and flashed momentary star firmware with some modifications. Now the thick driver retaining ring of this host refuses to fit over (the 2×7135 heatsink tabs on the backside of the driver obstruct the ring). So I must manage this somehow using excess solder. And the spring of the 105C is too short, so I have to buy some new springs :(.
The light engine part is complete though, but that was not easy either. For that I first reflowed the 219s to the dtp board, then attached wires, then screwed on the reflector to the board (this must not be too tight), then applied arctic alumina to the pill, then pushed the reflector-dtp-wires assembly inside (making sure the wires come out properly through the holes to the other side), then tightened the bezel and finally screwed on the center screw (this must be tight for good thermal transfer) going through thr reflector.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 39 min ago
What are you doing? You keep bringing this thread up to the top of the list with this post why?
KB1428 “Live Life WOT
JasonWW
JasonWW's picture
KawiBoy1428 wrote:
t18d16 wrote:
I am still a novice when it comes to building lights (so far built a 85cri-nw with Convoy S2+ and a cyan with Convoy M1). Snip…
How would that be possible with only 2 posts? ??? I don’t understand.
KawiBoy1428
That’s why I asked, “what are you doing”?
Unless there was a glitch in the system? Kept coming up as a new post? I read the same post 4-5 times and refreshed in between by hitting Recent Posts….
raccoon city
raccoon city's picture
Last seen: 3 hours 41 min ago
With only one post in this thread...
Maybe t18d16 keeps on editing their post?
t18d16
t18d16's picture
I did not know it works like this. I am not a native English speaker, so I edited incorrect grammar multiple times, sorry guys.
t18d16
t18d16's picture
And I did hit the edit button each time, not the reply button, like this time.
raccoon city
Don't worry about it.  ;)
I sometimes edit my posts many, many times when I find small errors.
contactcr
The host is a bit tricky to put together but i’m surprised you needed a longer spring. Is the driver sitting in the usual spot since you couldnt use the retaining ring or did you solder it further back? In other lights sometimes people just take some material off the inside of the retaining ring to make room if it’s close.
teacher
teacher's picture
No problem. Thumbs Up ….. Welcome to BLF!! Smile
Mike C
Mike C's picture
Last seen: 4 hours 28 min ago
raccoon city wrote:
Don’t worry about it. I sometimes edit my posts many, many times when I find small errors.
+1
I edit the crap out of my posts… My BLF account has this weird bug, it automatically edits my posts with a lot of mistakes so I keep having to go in and correct them Big Smile
t18d16
t18d16's picture
Thank you. Whatever flashlights I have built would not be possible without this forum.
I have not soldered the 4 wires to the driver board yet, but just eyeballed that the factory spring would just touch my flat top cells (spring begins where the threads just end), but I will double check.
EDIT1: I was wrong! The shorter spring also works. And I have completed building this flashlight. While light output from the 219B triple is average at 2.4A, it actually renders things better than sunlight in red region (tested with wooden doors, skin, tongue, red multimeter leads, red buckets). Totally puts my 85cri Cree T5-5D1 to shame, which despite having a rosy tint looks orangey. Thank you JohnnyC for writing the awesome firmware (star momentary 1.6) that I used in this light.
EDIT2: If a beginner wants to repurpose Nanjg driver like me, please do not use solid core wires as they are not flexible, you may have a hard time pushing the driver down.
MtnDon
MtnDon's picture
Last seen: 57 min 13 sec ago
Mike C wrote:
+1 I edit the crap out of my posts… My BLF account has this weird bug, it automatically edits my posts with a lot of mistakes so I keep having to go in and correct them Big Smile
Thumbs Up Me Too!! Facepalm
BLF Member Map Add your name and location.
Lightbringer
Lightbringer's picture
Last seen: 3 min ago
I never had to do that back when I had an error-correcting modem.
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 2 days ago
I tested different clips including Pomona and 3M and – guess what – the cheap ones from ebay similar to this worked best: https://www.ebay.com/itm/Professional-SOIC8-SOP8-Flash-Chip-IC-Test-Clip...BIOS-Programmer-s/232633530767?hash=item362a09f98f:g:GQoAAOSw3fZaISf1
(Actually I haven’t ordered this specific one, it’s just the first I found in this moment).
Bo4ka
Last seen: 1 week 5 days ago
Did someone built one with 3 dedomed xp-g2 S4? Wondering how it throws.
DB Custom
DB Custom's picture
Last seen: 31 min 27 sec ago
Sorry, my mistake on the XP-L2 statement… the emitters I got in mine were XP-L V6 2C/2D. Nice tint, nice output. Yes, the 3000 lumens out of the box was correct.
ZozzV6
ZozzV6's picture
Last seen: 3 days 22 hours ago
Another good news guys! I tried to convince Sofirn to sell switch tailcaps separately. So if you want you can lockout the C8F with it. I hope they will have it in the store soon.
Zappaman
Zappaman's picture
Last seen: 1 hour 37 min ago
DB Custom wrote:
Sorry, my mistake on the XP-L2 statement... the emitters I got in mine were XP-L V6 2C/2D. Nice tint, nice output. Yes, the 3000 lumens out of the box was correct.
Dale,
Confused, sorry-- I guess you have a FEW of these C8Fs Wink But your batch of XP-L2s (that you mention earlier) from Arrow... I ordered the same (I think), anyway wondering if I'm remembering right where you DO have BOTH an XPL Hi and XL-L2 FC8, right?  If so was wondering if you had an opinion to share with regard to the differences between the two?
Also, didn't you also try the SST-40? (or what that another light- you write about so many!)laughing
Thanks,  Russ
ZappaMan
JasonWW
JasonWW's picture
Zappaman wrote:
Dale,
Confused, sorry— I guess you have a FEW of these C8Fs Wink But your batch of XP-L2s (that you mention earlier) from Arrow… I ordered the same (I think), anyway wondering if I’m remembering right where you DO have BOTH an XPL Hi and XL-L2 FC8, right?  If so was wondering if you had an opinion to share with regard to the differences between the two?
Also, didn’t you also try the SST-40? (or what that another light- you write about so many!)laughing
Thanks,  Russ
I thought he tried the xpl2 in a C8F as well, but I guess not.
He put the SST 40 in a Supfire M6 as well as the blf Q8.
I don’t think he tried the xpl high but he did mention that the reflectors need to be designed for that particular emitter.
