ThruNite TC20 (Compact XHP 70.2) / Full review
95 posts / 0 new
klrman
klrman's picture
Last seen: 21 min 21 sec ago
robo819 wrote:
Yours is actually the first one I have heard a problem out of. They are nice little lights though and I hope it is a quick and painless ordeal to get things done for you.
Thrunite has been great and offered to pay for return shipping and also ship me a new one in a month when the new production is finished.
robo819
robo819's picture
Last seen: 3 weeks 14 hours ago
Wow that WAS quick and painless…….Kudos to Thrunite for the great service.
I am sure your replacement will be checked and working properly before it is sent also. Thumbs Up
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
robo819
robo819's picture
It sounds like maybe the protection circuit is holding the current back as a guess. It could be that when it tripped it did not reset properly? (just a shot in the dark)
I just went and rechecked with mine to be sure I wasn’t lying but……..
I don’t get nearly enough lumens difference to tell with my eyes using the Thrunite cell , the Basen High Drain , Efest High Drain , or the AWT High Drain cells.
I also checked each on my meter and there wasn’t but bout about 80 to 100 lumens difference across all the cells when the light is turned on (at start). All of the cells were fully rested but had been fully charged prior to setting them back on the shelf.
If you haven’t already asked about it , I would find out if they will send another cell with the new light , even if you have to send back the one you have now with the light.
*EDIT: Ok I was really curious and went and done some more checking.
With the Thrunite cell and all the above mentioned High Drains the light comes on with an average of around 3700 to 3795 lumens and all have around 9.7 amps at start at the tail.
The kicker and what is making me wonder now about the included cell is………….
With the Thrunite cell although it has the highest initial amperage at start with 10.03 amps , it drops off sharply at about 18 to 20 seconds to around 7.9 amps and 2600 lumens. (different than my initial 30 second test when I got the light)
The rest of the high drain cells start at about 9.5 to 9.7 amps , but none of those drop off below around 9.1 to 9.2 , even up to 45 seconds and all the high drains are still retaining around 3500 lumens at the 30 to 40 second mark.
Very interesting indeed.*
I have already emailed them to report a possible problem and included my findings with my sample also.
klrman
klrman's picture
I think you found something there with the Thrunite cell dropping off so fast after only 20 seconds or so.  Good troubleshooting!  I may have an especially bad cell from Thrunite as brightness from my Keeppower is very visibly stronger.
You said you couldn't notice the difference from High to Turbo.  I have an easy test for you to try out.  Click and hold until you reach high and then just click once to turn it off.  Then in a small room doing a ceiling bounce, double click to bring it right to turbo.  When you double click, the first click actually turns it onto  high and the second click puts it into turbo, so you should see the difference between the two real clearly if everything is working right.
robo819
robo819's picture
OK everyone….I thought I had already done what Thrunite has suggested doing for the quick drop in amperage and lumens , but I guess I wasn’t thorough enough.
I had cleaned all the contact points on the TC20 before such as inside the head at the small brass contact , the brass ring in the head , the tail springs . both ends of the tube and the un-anodized threads on the tube , as well as inside the tailcap and I also wiped off the ends of the cell itself with some isopropyl alcohol.
They suggested trying to clean the cell ends again so I did and I rubbed them very well with the alcohol and a paper towel and was very surprised at the results , as it seems the cell ends themselves were the problem of the quick amperage and lumen drop.
With the included thrunite cell I am now getting the 10.03 amps at the tail at start but instead of the light stepping down at 10 to 20 seconds to the 7.9 or so ………..it holds well on to about 65 to 70 seconds at about 9.7 amps now.
OK I had to check the lumens too…….At the start I am now getting 3784 to 3807….at the 30 second mark with included cell I am getting about what I did in initial testing at an average of 3531 to 3573 lumens now. At the 60 to 70 second mark the lumens with all the cells is averaging about 2900 to 3100.
I do feel each test was varied slightly because the light had not cooled down to room temperature each time.
This is now very much in line with the AWT , Basen and Efest cells as they are starting at about 9.7 average and then dropping off at almost the same point as the thrunite cell (to about 9.1 or 9.2 amps) now that it has been cleaned well.
Also from the first drop at the 1 minute or slightly over mark , the light gradually drops from there over the next 2 minutes until the full step down at the 3 minute mark , where it levels off around 1755 or so lumens with all the cells.
And yes there is a definite difference , very noticeable to the eye , from High to Turbo.
Hope this can help with any future problems of quick step downs or low Amperage / Lumens.
High
Turbo
DB Custom
DB Custom's picture
Last seen: 3 hours 16 min ago
So it’s Sam approved now? Gonna have to buy one of these yet…
robo819
robo819's picture
Actually JJ approved…..he is the yellow one that is always out there with me when I go to test the lights.
Tumbleweed48
Last seen: 4 hours 51 min ago
Cleaning the cell ends is a very valuable bit of information – it something that never occurred to me.
Just another reason I love BLF! Thumbs Up
atbglenn
atbglenn's picture
Last seen: 1 year 3 months ago
Thanks! I cleaned my TC20 and battery contacts. Made a noticeable difference.
Boycott Nike
beam0
beam0's picture
Last seen: 3 months 2 days ago
For me the difference from high to turbo isn’t huge. Noticeable yes but hasn’t really been a “wow” moment.
Will do some cleaning and try again tonight. Also will try with an Lii-50A
DB Custom
DB Custom's picture
Light is a cruel mistress.
To double the length of throw takes 4 times the amount of light, it’s an exponential investment that is ever elusive.
And this is, of course, the challenge.
Newlumen
Newlumen's picture
Last seen: 6 months 4 weeks ago
I have been using my tc20 everyday with the shockli unprotected.. oem 26650 is in my other flashlight that need protected.. ( to be excat, manker u21 oslon black)..
Anyhow, i like this light.. red indictator finally came on tonight.. so thats mean its time to recharge.. 3.25 v .
robo819
robo819's picture
Glad you are liking this light. There is only one thing I see wrong in what you mentioned ………
“Anyhow, i like this light.. red indictator finally came on tonight.. so thats mean its time to recharge.. 3.25 v “
It sounds like you need to use it even more and get the new worn off , at least a charge every other day for the first week?……….LOL
Rambo007
Last seen: 2 years 6 months ago
I read a review of the Thrunite TC20 in the German amazon site in which the reviewer indicated he was using a Keeppower 27700
5700MAH battery and he posted a picture of it .Its 3.7V 21.09 WH
Does anyone know where I can get it in USA .anyone have experience with this battery?I imagine this would greatly increase the light life b4 charging.
Here is link to review and the link to the actual battery
https://www.amazon.de/gp/customer-reviews/R197Y00O29RIYG/ref=cm_cr_dp_d_...ASIN=B078JYVJCS
http://keeppower.com.cn/products_detail.php?id=554
SKV89
Last seen: 43 min 6 sec ago
Rambo007, why not just get the Shockli 26650? I tested the ones I have to be 5,800-5,900mah. They are known to be the best 26650 you can get as of now.
Rambo007
What about 26650 Orbtronic 5750 MAH unprotected?
https://www.orbtronic.com/26650-battery-5750mah-30a-orbtronic-high-capac...
Newlumen
Newlumen's picture
First time recharging my 26650 shockli., it take forever at 1 amp.
DB Custom
DB Custom's picture
These kinds of cells are the reason I got the MiBoxer C4-12, it charges 4 bays at up to 3A each. Wink (Yes, that’s 12A total charging power!)
If I’m not mistaken the Thrunite built in charger can do up to 2A, so that would be quicker by a considerable margin than a 1A external charger.
JeffroGymnast
JeffroGymnast's picture
Last seen: 1 year 1 month ago
Does anyone have a comparison shot with a D4? I’m looking for a light with similar throw/spill but more sustained output and I think this could be the ticket. 3000+ lumens from a big emitter and a tiny reflector though, it might be too spilly…
charles lin
charles lin's picture
Last seen: 1 day 3 hours ago
I have no problem charge T20 up to 2A, even my power bank can charge T20 up tp 1.6A. Average charge time is about 2 hours, not bad for charging 26650 size battery with build-in charger!
beam0
beam0's picture
“The charts on the Lumens and amperage testing I did with the TC20…………….”
Were these deleted? I’m not seeing them.
robo819
robo819's picture
I don’t see them either , but don’t have a clue what may have happened. Have you tried reposting?
beam0
beam0's picture
Re post them? No I was referring to your charts…
I see how my post could be confusing, but this was your quote in the OP:
So it’s your charts I’m not seeing.
robo819
robo819's picture
Sorry , my bad……….I did get the charts back up , but the rest of the pictures will not show no matter what I try. Something going on with the server maybe?
beam0
beam0's picture
Thanks! Totally forgot there were photos too, hope you can get the problem resolved.
I think the charts are missing also in the Neutron 2C V3 review (I posted a comment about it there too)
No photos there either.
robo819
robo819's picture
Photo / GIF and chart problem now resolved in 85% or so of my review threads. At least in the OP or the main review part of it so far. FINALLY !!!!!!!!…….LOL
j-son
j-son's picture
just ordered one of these tonight. found all sorts of coupon codes/discounts and couldnt resist.
robo819
robo819's picture
Think you will be impressed with this light…….hope you enjoy it.
SKV89
Do you mean the 20% discount or are there more?
j-son
j-son's picture
20% off plus paypal credit gave me $10 off
