What do you think of OLIGHT R50 PRO SEEKER 3200?
29 posts / 0 new
JAPAN_My Englis...
Hello, everyone.
I have a following of LED light.
(1)ACEBEAM-L30
(2)LED LENSER-P7R
(3)LED LENSER-P7.2
(4)LED LENSER-P7
(5)LED LENSER-i6
(6)LED LENSER-K3
(7)LED LENSER-M14X
(8)NITECORE-CONCEPT-1
(9)NITECORE-EC11
(10)NITECORE-EC23
(11)NITECORE-P12GT
(12)NITECORE-P26
(13)NITECORE-TINI
(14)ROFIS-MR70
(15)ThruNite -TC20
(16)ThruNite-TC12 V2
(17)Manker E14_II (It was broken in 2 hours after purchase)
I have a lot of LED lights.
But there is no knowledge of the LED light to me.
I like the light be equipped with a battery of 26650.
I plan to buy a OLIGHT R50 PRO SEEKER 3200.
Is the OLIGHT R50 PRO SEEKER 3200 less trouble?
Do OLIGHT R50 PRO SEEKER 3200 have excellent performance?
Please tell me if there is an excellent light resembling an
Please tell me the choice of
non-OLIGHT R50 PRO SEEKER 3200.
best regards.
Edited by: JAPAN_My Englis... on 05/04/2018 - 06:56
CM2010
Last seen: 38 min 2 sec ago
I had the R50 Pro seeker, it’s a nice light but hardly ever used it. It also doesn’t take generic 26650’s as you have to use Olights own version.
I’ve just recently got the Lumintop ODF30 and prefer this light over the R50 Pro.
Newlumen
Newlumen's picture
Last seen: 13 hours 41 min ago
Olight make good light. The only thing is you have to use oem battery for the usb charging. I got many 26650 lights. I will give you my opinion lumintop odf30 today.
JAPAN_My Englis...
Hi,
I’m sorry to bother you.
I plan to order Lumintop ODF30 soon.
I have a few questions.
Please answer the following questions:
(1)Is the Lumintop 26650 5000mAh Battery included in ODF30?
(2)I want 2-Lumintop 26650 5000 mAh Battery.
http://www17.plala.or.jp/x000x/battery.jpg
I can order the 2-Lumintop 26650 5000 mAh Battery Where?
Please tell me the URL where I can order a Battery.
The battery can be shipped to Japan?
(3)Can I use the following batteries?
KEEPPOWER IMR 26650 / 5200mAh Max30A Constant-OutPut/15A
4.2V~2.5V (Standard voltage 3.7V)
Diameter 26.1mm ±0.2mm / Length 67.5mm ±0.5mm
http://www17.plala.or.jp/x000x/battery2.jpg
best regards.
toddcshoe
toddcshoe's picture
Last seen: 1 hour 13 min ago
I just got the ODF30 today.
I use a Purple Efest IMR26650 5000mah 45A start 18A continuous. It’s 67.5mm in height and fits and works just fine.
No a battery is not included with the flashlight.
This guy I think ships Efest 26650 to Japan. Not sure how much for shipping.
https://www.ebay.com/itm/2x-Efest-IMR-26650-5000MAH-45A-3-7V-Batteries-A...
Might want to see if this company can help you with the Lumintop battery if you really want that battery. They are in Japan.
http://www.holkin.com/lumintop.html
JAPAN_My Englis...
Hello toddcshoe,
I thank for your detailed answer.
Is the battery of Efest the following product?
Efest IMR 26650 LI-MN 45A 5000mAh.
The consecutive electric discharge upper limits:45A
Maximum moment electric discharge:50A
Diameter:26.50mm
Length:65.20mm (±0.2mm)
http://www17.plala.or.jp/x000x/battery3.jpg
You have Efest IMR26650 5000mah of 67.5mm.
The length of Efest which I checked, 65.20mm.
Are these two the same things?
best regards.
toddcshoe
toddcshoe's picture
Yes, it’s the same battery. My measurement might not be too good. Was using my daughters school ruler so it may be a little off. That is the same battery that fits in my ODF30 and works just fine. Going outside in a bit as soon as it’s really dark and I will post some beam shots.
Newlumen
Newlumen's picture
Same here. I got my lumintop odf30 from banggood. Big discount using coupon code. Great quality light… lumintop did good job on the quality control and stuff.
72_E46666-312_A-478_D-_ADA6-_C7_B930600_A2_C
image hosting
JAPAN_My Englis...
OK, Thank you!
Where can I buy Lumintop ODF30?
I do not know the coupon cord of banggood.
Will you tell me the coupon cord of banggood?
https://www.banggood.com/Lumintop-ODF30-XHP70_2-3500LM-6Modes-Brightness...
Should I purchase it in GearBest?
I know the coupon cord of GearBest.
The coupon cord is LODF30.
https://www.gearbest.com/led-flashlights/pp_1827679.html?wid=1433363?lki...
Which is a low price?
AND
I have a question about 26650 Efest IMR LI-MN 45A 5000mAh.
I checked Efest IMR 26650 LI-MN 45A 5000mAh.
Diameter:26.50mm
However, Mr.M4D M4X lists it when 66mm is too short.
http://budgetlightforum.com/node/59735
Mr.toddcshoe,
You put Efest IMR 26650 LI-MN 45A 5000mAh in a flashlight.
And, please wave a flashlight lengthwise.
Does the battery not act violently in a flashlight?
best regards.
toddcshoe
toddcshoe's picture
No, the battery does not shake inside the light. Fits just perfectly.
toddcshoe
toddcshoe's picture
Agreed, I really like it so far. Lots of light and a great beam. Lights up a pretty large area.
mmalive
Last seen: 9 hours 57 min ago
Gotta to try those batteries.
CM2010
I use Keeppower imr6000mah 26650 in my ODF30.
JAPAN_My Englis...
OK, Thank you, everybody.
That’s reassuring.
I will purchase Lumintop ODF30 by the end of this month.
Lumintop ODF30 is not sold in Japan.
I will purchase it in gearbest or Banggoode.
And I will purchase 26650 Efest IMR LI-MN 45A 5000mAh.
Hi, CM2010
Do length and the diameter of Kppower imr6000mah 26650 not have any problem for ODF30?
I can obtain KEEPPOWER IMR 26650 5200mAh in Japan.
MAX : 30A / Constant : 15A
Diameter:26.10mm (±0.2mm)
Length:67.50mm (±0.5mm)
This battery is long.
As for your Keeppower imr6000mah 26650 battery, is Length 67.50mm?
Does the battery fit ODF30 without a problem?
I asked Lumintop.
Lumintop recommends the battery with the protection function.
It is not IMR battery.
Is Lumintop wrong?
Should I use IMR High-drain battery?
Is Efest IMR LI-MN 45A 5000mAh 26650 High-drain battery?
Is Keeppower IMR 6000mAh 26650 High-drain battery?
best regards.
CM2010
I have the Keeppower imr5200 and imr6000 and both fit and work great in the ODF30.
The length of the 6000 is 66.7
JAPAN_My Englis...
Hi, CM2010.
Thank you very much.
Your opinion served as a reference very much.
TheAuditor
Last seen: 31 min 23 sec ago
Just a note to mention that the ODF30 does not have reverse polarity protection so be careful.
I got the R50 Pro a short while ago and really like it but then I got it for a very good price with a 2nd battery. The build quality is excellent.
Bonum commune communitatis.
Yarp.
Newlumen
Newlumen's picture
Hi OP, I can’t share the code. You will have to register m4d website. It was like $20 off from banggood. I link the website below.
https://m4dm4x.com
JAPAN_My Englis...
Hi, Newlumen .
OK, Thank you very much.
Newlumen
Newlumen's picture
Lumintop odf30 fits liitokala 26650. ( 65.8mm ).
https://www.aliexpress.com/store/product/1PCS-LiitoKala-26650-50A-5000ma...
JAPAN_My Englis...
Hi, Newlumen .
JAPAN_My Englis...
Hi,
Lumintop ODF30,
Does the side switch LED of Lumintop ODF 30 light up?
When do LEDs turn on?
Best regards.
Barkuti
Barkuti's picture
Last seen: 8 hours 2 min ago
Diameter:26.50mm
Those discharge rate specifications are a lie. Period.
Efest rewraps cells from OEMs. Nothing wrong with this, but they like to inflate the actual OEM cell specifications in a twisting, consumer misleading way, and on top of this try to charge you more. No way Efest.
I second Newlumen's cell suggestion but please check these AliExpress vendors' offers with a much cheaper shipping and handling quote to Japan (cells are blue wrapped but they're equivalent):
Cheers
Sofirn C8T and C8F reviews of mine
PMme for a tip Wink thanks
Ajay
Last seen: 3 weeks 4 days ago
Love my r50 pro seeker LE
This is our family go to work horse for around the house.
Stays in the kitchen cabinet in its charger always ready to go.
Nice size and hand.
Olight perfection on fit and finish, if your into that kind of stuff…
JAPAN
Last seen: 8 months 3 days ago
Hi,
I bought the following products at Banggood.
I have a question to the following products.
Lumintop ODF30 XHP70.2 3500LM 6Modes
Brightness Power Indicator LED Flashlight
I have to 5-questions.
Please answer in detail to all the questions.
At first, please watch the photograph of the URL.
http://www.lumintop.com/wp-content/uploads/2018/03/20180315061816_66180.jpg
(1)What kind of situation is output/mode shift?
(2)How do you operate output/mode shift?
(3)How does the indicator of the switch shine?
and
I locked-out a flashlight.
However, the indicator in the switch does not change.
As for the indicator, the lighting does not flash on and off, too.
(4)Is not the problem that the indicator does not light up or blink?
I think that the indicator is broken.
and
Capacity of the battery decreased.
(5)Is not the problem that the indicator does not light up or blink?
I have never watched the light of the indicator.
I think that an indicator is broken.
At first, please answer a question.
Please check the correct information.
I want to know the answer as soon as possible.
Best regards.
toddcshoe
toddcshoe's picture
JAPAN wrote:
Hi,
and
and
Best regards.
Okay, I will try to take these one at a time.
One click will turn the light on in the last brightness it was on. Single clicks after that will progress through the LOW, MED, HI. Double click while ON in any brightness to get to turbo. Single click gets out of turbo and back to the last used brightness. Long press to shut off from modes or turbo.
Instant access to turbo is available with three quick clicks from off.
The indicator light will only shine when the battery gets low in voltage. Plugging the light in will charge the battery and start flashing red and when the light is fully charged it will turn green.
If you locked out the flashlight you can unlock it by untwisting the tail cap and screwing it back in. That will take the lock out off. When it is in lock out you still have the option of using a momentary press of the switch for low mode only until it is unlocked.
I hope I answered some of your questions.
JAPAN
Hi, toddcshoe.
Thank you.
However, the Lumintop ODF 30 does not have a function to charge.
When the indicator lights up is it only at low voltage?
Will the indicator light up when output/mode shift is set?
Will the indicator light up when Lock-out function is set?
Best regards.
JAPAN
Please tell me about Lumintop ODF30.
Please look at the image of the following URL.
When output/mode shift and Low pwer indicator and Lock-out function is chosen,
it is written that the indicator of the switch turns on or it flashes on and off.
I do not understand the meaning of Output / mode shift.
Please tell me in detail.
(1)Output/mode shift,
Does the switch indicator light or blink?
(2)Low pwer indicator,
Is the switch indicator lit or blinking when the battery is low?
(3)Lock-out function,
At what time is the indicator on the switch lit or blinking?
The flashlight will flash.
However, the indicator inside the switch does not light up or flash.
Is this normal?
Is there the problem?
(4)When a light dims, a light flashes on and off.
Is this normal?
Best regards.
toddcshoe
toddcshoe's picture
You are correct sir, I apologize. At low voltage the red light on the switch starts to flash to remind you to recharge.
I do not think the light on the switch blinks or anything on mode changes.
When the light gets too hot on turbo or high the light will decrease output. The flash you are seeing might be the flash it makes when going into lock out mode.
