Where do i buy good 26650 high drain cells?
54 posts / 0 new
wolfdog1226
wolfdog1226's picture
JasonWW wrote:
Mikeadoo wrote:
Woah dang! Ok Orbtronics it is thanks all!
I don’t have much experience with Efest. I’m not sure if I trust them since the batteries under the wrapper can vary over time and their ratings are sometimes incorrect. So I’m very skeptical about that brand.
Well then he could get the Ijoy[D=26.22mm] 26650 4200mAh OR The Golisi[D=26.0mm] 26650 4300 mAh[least V sag of them all].The Shockli[D=26.0mm] 26650 4300 . That is not easy to get in the USA,,,especially at a good price.
The Ijoy is the most accessible of the Two. The Golisi is very expensive if you buy from a USA vape shop,,,,,,,,,,,,would have to get it overseas!.
I checked out the Liitokala and it is also too big[D=26.8mm] according to HKJ’S review.
My hometown dealer[Liionwholesale] is out of the Ijoy.
I think his best bet is the Efest, either that or pay more money or wait and buy from China.
I know this does not help the OP,,,,,,,,,I am glad that I have the Catapult V6!! NO issues with battery size and great performance
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Mikeadoo
Thanks Wolfdog.
Mike
Mikeadoo
Ok everyone. I have one Efest purple and it works great in the ODF30. I wasn’t sure where to find them, but now I do thanks to Wolfdog. Never heard of mahbattery.com before.
Mike
JasonWW
JasonWW's picture
Last seen: 1 min 52 sec ago
Hmmm, HKJ’s specs may be a little off or maybe the cells vary. My Liitokala cyan are about 25.3-25.4 and fit the ODF30 just barely. It’s a tight air seal. The cells slide in and out slowly due to tight fit, but they do fit.
Looks like they just sold out. They were in stock on the 5th when I recommended them in post 12.
The Aspire 4300 still looks to be in stock.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
Lothar
Lothar's picture
Last seen: 5 days 18 hours ago
Sorry for reviving an old thread. Does anyone know if the Shockli IMR 26650 5500mah will fit a Lumintop ODL20C?
Thanks!
Current Collection: BTU: Shocker (3 x SST-40 @ 8A)Lumintop: BLF GT70 (CW Sliced), BLF GTmini; Solarforce: 2 x L2P (XM-L2 U3 2C @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 2C @ 12A), M6 (Nichia 319A @ 6A), M8 (Cree XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 1A @ 2A)
Coming Soon: Lumintop: BLF GT4; Sofirn: BLF-LT1;
HKSJOSHUA_
Last seen: 1 week 3 days ago
I purchased four imren purple 4200 mah 26650 batteries at wholesale price locally at perfect vape warehouse, online they cost much more but I have had excellent results with these batteries in my ft03.
hasddie293
hasddie293's picture
Last seen: 2 hours 4 min ago
Does Aspire is same as golisi and shocklii?
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
JasonWW
JasonWW's picture
hasddie293 wrote:
Does Aspire is same as golisi and shockli?
Different.
Golisi 4300 is good.
Shockli 4300 green is good.
Aspire 4300 is good.
iJoy 4200 is good.
All close in performance. Good high drain cells.
Shockli 4200 purple, not as good.
hasddie293
When you look at HKJ’s 26650 comparator, Shocklii 5500 vs shocklii 4300mah(green) graph look very weird. At below 15amp discharge, Voltage sag still in favour to the Shocklii 5500mah. But when it come to above 15amp discharge, the 4300mah(green) can handle heavy load. That why I change my mind, 5500mah look very strong for me….
Edit: its Shocklii 26650 4300mah (green) imho typo Facepalm
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
JasonWW
JasonWW's picture
hasddie293 wrote:
When you look at HKJ’s 26650 comparator, Shocklii 5500 vs shocklii 4500mah grap look very weird. At below 15amp discharge, Voltage sag still in favour to the Shocklii 5500mah. But when it come to above 15amp discharge, the 4500mah can handle heavy load. That why I change my mind, 5500mah look very strong for me….
I don’t see a Shockli 4500mah.
The 5500mah is a fairly new (couple years old) high capacity cell that is still pretty good at delivering amperage despite being high capacity.
Since only smaller companies make 26650, they usually can’t get very high capacity, but they can still get good high drain performance.
Fedos
Last seen: 5 hours 37 min ago
Anyone know what Sofirn SP33 tubes are like? Would a the new SP33 V3 take one of those “fat” cells?
RapidLux
RapidLux's picture
Last seen: 1 hour 57 min ago
Vapcell 26650 battery 4200mAh 32A https://www.aliexpress.com/item/32870546544.html
Can’t find any review of this. Vapcell seems to rate their cells amp draw somewhat reasonable.
JasonWW
JasonWW's picture
I don’t know if the version 3 tube is going to be the same as version 2. I’ve got the version 2 and there is no problem using a shockli 5500.
JasonWW
JasonWW's picture
RapidLux wrote:
Vapcell 26650 battery 4200mAh 32A https://www.aliexpress.com/item/32870546544.html Can't find any review of this. Vapcell seems to rate their cells amp draw somewhat reasonable.
Mooch has tested it. It's a good cell with accurate ratings.
Mooch link
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 35 min 55 sec ago
JasonWW wrote:
Fedos wrote:
Anyone know what Sofirn SP33 tubes are like? Would a the new SP33 V3 take one of those "fat" cells?
I don't know if the version 3 tube is going to be the same as version 2. I've got the version 2 and there is no problem using a shockli 5500.
I have tested the below mentioned batteries in my SP33 V2. All of them fitted except for the protected Keeppower 6.000mAh on the right end.
Fedos
JasonWW]<p>[quote=RapidLux]Vapcell 26650 battery 4200mAh 32A https://www.aliexpress.com/item/32870546544.html Can't find any review of this. Vapcell seems to rate their cells amp draw somewhat reasonable.[quote=Lux-Perpetua wrote:
Thanks. Is the Sofirn battery itself “fat”. From the picture it looks about the same a the Shockli.
JasonWW
JasonWW's picture
I have the Sofirn HD 5000mah button top, it’s a normal size cell. Just a tad smaller in diameter than the Shockli 5500. I don’t know about the normal Sofirn 5500mah.
Barry0892
Barry0892's picture
Last seen: 9 min 59 sec ago
I contacted PLB and got some samples of PLB 5000mAh 26650(the 5500mAh was discontinued)
the 5000mAh cells works well on SP33, SP33 V3, but they are flat top, so they won’t work well on SP70 directly.
If sofirn rebrand these batteries, I am not sure if they will be too fat for the flashlight tube.
What’s your ideas? Do you like PLB 5000mAh 26650 HD cell to be used in SP33 V3 and SP70?
Or do you prefer using 21700 for SP33 series and SP70?
Find FREE items on my timeline.
Facebook: https://www.facebook.com/barry.lee.984991
WhatsApp: +8615773183209
JasonWW
JasonWW's picture
I wonder why PLB would discontinue their best battery?
I’ve never heard of their 5000mah. Do you know if it’s new or maybe currently being sold by other companies?
Barry0892
Barry0892's picture
I was told the sales of 5500mAh is not good, the last inventory runned out in Oct.
PLB’s 26650 batteries are for battery powered cars or for factory. Even if flasholics like 5500mAh HD 26650 very much. The sales is not big for PLB. That’s what I am guessing.
The guy contacted me after I emailed PLB official email address, so I think it’s factory direct. Maybe some dealers have inventory.
Anybody help confirm this “discontinued 550mAh HD 26650 from PLB”?
Fedos
I want to use the battery with biggest possible capacity, provided the performance is adequate.
hasddie293
I like the shocklii 26650 5500mah and already place another order on AE.Why would they discontinue? Hmmm…probably they come out a new one, much more better…
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
JasonWW
JasonWW's picture
They don’t mention that on their website. They just show the smaller capacity 5000mah, and the specs for that one are not so great, they show 10A continuous discharge. The 5500mah was 15A, so that’s disappointing.
