catching the light of the moon
30 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 51 min ago
Tonight the sky is very clear over Amsterdam, with an almost full moon shining om my balcony (as photographed above through binoculars). Which gave me the opportunity to try something that I was pretty sure of that it would not work: recording a moon spectrum on my handheld spectrometer.
The minimum illuminance that it can record a spectrum of is about 10 lux. So I concentrated the light with some cheap plastic magnifyer and behold, it worked. The projection of the moon on the sensor was made as sharp as possible and was a bit smaller than the sensor surface of the spectrometer, so I think that chromatic abberations of the magnifyer were reasonably averaged with the rest of the light by the diffusor of the sensor so I rather trust that it is an accurate spectrum of the moon as it shines over Amsterdam tonight.
So here it is, how fun is that! And no PWM was measured Smile
Edited by: djozz on 09/23/2018 - 19:25
CRX
CRX's picture
Last seen: 4 hours 36 min ago
Smile
gravelmonkey
Last seen: 4 min 17 sec ago
Awesome! It’s amazing that the CCT is 4253K, moonlight always appears a lot cooler.
djozz
djozz's picture
I just looked it up, there ‘s more people who noticed that. Here’s the long answer (but a good read): https://physics.stackexchange.com/questions/244922/why-does-moonlight-ha...
Boaz
Boaz's picture
Last seen: 8 hours 55 min ago
   That's cool ....
  I mean neutral
 4253K  can be a really a nice tint
 Hey DJOZZ have you contacted the manufacturer? If there is a group buy I'm in for 2 .
   "The Purkinje effect makes us perceive faint light as bluer (higher colour temperature) than we would perceive a brigher light with an identical spectrum"
  << this may explain why Hi Cri lights look much better on med. or high compared to low or moon modes.
jon_slider
jon_slider's picture
Last seen: 6 hours 23 min ago
djozz wrote:
Moonbeam Love! Wink
EasyB
Last seen: 7 hours 47 min ago
CRI snobs. Facepalm Thumbs Up
pc_light
pc_light's picture
Last seen: 9 hours 22 min ago
98 CRI & 4253K – I knew there was a reason I was such a lunatic about hi-cri at those temps
Seeking the light.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 26 min ago
It would be nice if LED light bulbs came in 4250K with 98 CRI. That’s pretty much perfect for both indoor and outdoor lighting. I generally never see anything between 3000K and 5000K in stores though, so I have to mix multiple bulbs to get the right temperature.
WillyD
Last seen: 1 month 9 hours ago
First, djozz, super cool to know this. Like others, I would have thought it cooler as well.
TK, not sure if you have a Rural King in your area, but I just picked up a couple boxes of ‘Tool Shed’ brand LED bulbs rated at 4000K. Cheap brand, I’m sure, but I surprisingly liked them so much, I picked up an extra box and replaced all my basement bulbs with them. They are ‘just right’.
electricjelly
electricjelly's picture
Last seen: 1 day 3 hours ago
Wow, pretty neet. Seems the moon sets a good standard for leds to try and match. I’m surprised to see the red part of the spectrum is so full.
djozz
djozz's picture
The link in post #4 gives some good information on the physics behind moonlight and the perception of it.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 53 min 44 sec ago
Here in Australia 90+cri 4000k bulb are common but the tints seems much cooler than a 4000k maybe its the white plastic diffuser they use.
ToyKeeper
ToyKeeper's picture
Djozz, do you have a jar big enough to fit your spectrometer?
If so, you should take another measurement, and take pictures of the process. Because it would prove that you actually caught moonbeams in a jar.
djozz
djozz's picture
That sounds like a wonderful thing to do.
I do have a jar big enough, but how to push the button while the spectrometer is inside?, sure the moonbeams will try to escape if I keep the lid off. Smile
Nev
The light from the moon is reflected sunlight , Grad
Tally-ho
Tally-ho's picture
Last seen: 13 min 13 sec ago
The ambient light from the moonlight is so dim that you are using your rod cells, not your cone cells, hence you are not perceiving that the ambient light is in fact warmer/yellower than the ambient light under sunlight (light of the sun + light from the sky (blue)).
gravelmonkey
Yeah I assumed that was the case, djozz replied with a pretty good link in post #4.
JaredM
JaredM's picture
Last seen: 4 hours 50 min ago
As others have said, I’ve always found this to be the sweet spot for CCT at night time and roughly 3B tint for daytime (about 5200K). The latter is apparently the CCT at sunrise/sunset .. It’s always cool to see these preferences and ‘attractions’ be correlated to things in nature.
Boaz
Boaz's picture
JaredM wrote:
As others have said, I've always found this to be the sweet spot for CCT at night time and roughly 3B tint for daytime (about 5200K). The latter is apparently the CCT at sunrise/sunset .. It's always cool to see these preferences and 'attractions' be correlated to things in nature.
 I've heard Jon Slider talking about this too and have problems understanding people talking about using flashlights during the day ...Just makes no sense to me .If i use a flashlight in the day it's for 11 seconds to find my pen that fell behind the stereo speaker.tint isn't an issue at that point . where do people use a light in the day ?
sbslider
sbslider's picture
Last seen: 1 hour 24 min ago
This thread got me thinking about how the amount of moonlight (reference a full moon at latitudes < 40 degrees from the equator) compares to what we call “moonlight mode” (typically less than a lumen). Perhaps a different thread?
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Boaz
Boaz's picture
stupid thread got me doing a 6 hr study on black body and quantum physics.
Thanks now i'm more confused .
reading is hard
djozz
djozz's picture
Last night I recorded another full moon:
Apparently the one full moon is not the other. This time it was warmer, 3400K. The luxvalue was lower than the first recording in september last year. It is attractive to speculate that more haze in the atmosphere (the sky looked very bright though) caused more scattering (affects blue the most) and warming up the CCT. Or the moon was lower than last time (it was), so the light travels a longer distance through the atmosphere, again more scattering.
Whatever the reason, the CCT of moonlight seems pretty variable, but the CRI is invariably high. Let’s wait for a very high moon next time and see what the CCT does then.
acab
acab's picture
Last seen: 1 month 1 week ago
This was very interesting, I had no idea this could be done. Thank you.
contactcr
Last seen: 5 hours 41 min ago
Funny how no one mentioned the positive DUV. I’m surprised you guys can stand to go outside without it being rosy negative DUV Facepalm
Geuzzz
Geuzzz's picture
Last seen: 4 hours 9 min ago
That’s why I wear Lee minus green filters in my glasses Cool
Geuzzz
Geuzzz's picture
Nice read Djozz, looking forward to the next.
Muto
Last seen: 54 min 52 sec ago
MAybe they are using a new clone moon emitter Smile
T
The Chhinaaa man must have caused it. LOL
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Rockin’ In Bedrock, Twitch, Twitch!
Big Sky Country
hank
hank's picture
Last seen: 9 hours 43 min ago
I just saw that as an explanation for why this month’s full moon looks more pink — it rises only to the lowest angle above the horizon.
I’ve seen some wonderful outdoor time exposures of Yosemite waterfalls made with moonlight. They make “moonbows” too dim for the eye that cameras can capture.
https://www.google.com/search?client=firefox-b-1-d&channel=tus&q=moonbow...
ToyKeeper
ToyKeeper's picture
There’s no need to mention it.
Everyone already knows the moon is made of green cheese.
