Inside Convoy T2
28 posts / 0 new
Kame Sennin
Kame Sennin's picture
Last seen: 1 week 2 days ago
Inside Convoy T2
Today i received my first Convoy T2 !
It looks and feel exactly as i expected from a Convoy ie : simple and robust with a clean finish
The only thing that ennoyed me somewhat once the "new toy" effect started to settle down was the feeling that the mid is not really enough (to my liking) for some serious work while the high (and the associated battery drain) is too high, wich was enough of an excuse to decide to open it and see if i could mod it  Wink
Pictures an schematic will follow asap but to make a long evening short and after verifying several time i have a question :
Is it common for that kind of flashlight to drive the led with a constant voltage (about 3.25V) through a low value resistor (0.2 ohms) with NO current feedback (or anything else that could make a decent current source) ?
I figured that while you need a boost converter and decide to add some kind of u-controller it wasn't that much work to have them drive the led in current mode ... but i might be wrong !*
*Long ago i have built a flashlight with cc mode driver (maybe i'll show you pictures of the poor ugly thing one day) but that was a single mode (and low power) one so it was no big deal
Kame Sennin
Adding pictures and schematic for the driver (updated schematic according to HarleyQuin's feedback)  :
Links :
Convoy T2 driver bot
Convoy T2 top
Outer diameter of the PCB : 17.1mm but it doesn't "fill" the inside diameter of the head (threading ID is 18.0mm)
Inner diameter of the retaining ring : 14.7mm
Phlogiston
Phlogiston's picture
Last seen: 28 min 41 sec ago
Thanks for the schematics and photos, those are always interesting to have Thumbs Up
That driver configuration looks normal for a PWM-controlled LED.
Djozz has found the PWM frequency to be 744Hz, which is unfortunately low and makes the PWM flicker perceptible to a fair number of people. Djozz’s post with his impressions and test results is here:
http://budgetlightforum.com/comment/1378223#comment-1378223
HarleyQuin
HarleyQuin's picture
@Kame Sennin
Thanks for the effort, that are very good pictures of the driver, and a schematic to boot Smile
I’m not sure how this driver handles it, but I can say it’s not ‘common’. The PAM2803 based drivers are indeed current controlled with a sense resistor.
If the driver is in fact not current controlled but voltage controlled, it might be adapted for a certain LED. So R3 (R200) could be a current limiter, protecting the FET, or burning off excess voltage to adapt the output voltage of the boost circuit to the desired Vf of the LED. But I haven’t identified this T2 controller IC yet (I also presume the SOT23-5 with D3 on it).
A defining characteristic is the use of an external switch (8205S) in the boost circuit. I’m curious if the external switch would allow for a higher current than the PAM2803 drivers, although it’s not relevant for 1AA (1.2V) use. Here the cell is the limiting factor. But might be interesting for 2AA.
My hopes for an Attiny based driver are gone, of course, the MCU pinout is definitely not Attiny13A and it can’t be easily swapped. Strange to see the sub-par PWM and modes, it’s not typical for Convoy to use visible PWM and a disco mode in a single mode group. That’s what makes me think he just bought the driver and did not put own development into it. Or he sells more lights to muggles and they demand it… But although I don’t consider this driver suitable for use, it’s interesting to study it.
Some annotations to the schematic:
- C2 has the marking 476, which means 47000000pF (6 zeroes), so it’s 47µF.
- there’s a third ceramic capacitor on the board that’s not in your schematic
- R5 is probably “01D” (zero one D) which means 100k in this code form
Again, I’m very grateful for the information you provided.
Beer
The T2 looks great, I consider it a great host, and I’m on my line of boost drivers again, which were a bit neglected in the past.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Kame Sennin
Thank you very much for your feedback !
You are totally right about the 47uF, missing ceramic resistor (near the red wire) and "01D" resistor, i just  updated the schematic.
It took me too much time to reverse engineer the schematic because i was looking for a current drive like the PAM2803 and couldn't have it to fit what was on the board Wink and i was expecting an Attiny too Sad
From what i have seen, without a current mode drive (a higher voltage with a higher value serial resistor is a decent current drive at low power) the led output might change pretty much from one led to the other even in the same batch (U/I curve irregularity) and is more temperature sensitive but that is certainly not a real concern for that kind of use Smile
kikkoman
kikkoman's picture
Last seen: 9 months 2 weeks ago
HarleyQuin wrote:
[…] But I haven’t identified this T2 controller IC yet (I also presume the SOT23-5 with D3 on it).
I’ve seen this style of marking a number of times before, it took me ages to find out who makes them. Big Smile
It’s a Torex XC9104.
Quote:
Output Current | More than 400mA (VIN=1.8V,VOUT=3.3V)
The parallel 8205S and rather small inductor certainly help its current capabilities but efficiency probably sucks. I’m a bit skeptical about that “800mA”.
I’d really love to see an output/runtime graph on High…
Kame Sennin
kikkoman wrote:
I've seen this style of marking a number of times before, it took me ages to find out who makes them. Big Smile It's a "Torex XC9104. ":https://www.torexsemi.com/products/step-up-dcdc-converters/series/?name=...
Nice find !! I have watched many small boost IC datasheets but couldn't find one that was totally fiting !
 I am somewhat short of time at work right now but i hope to be able to take this driver to the bench soon and see what it can do
So now we only miss the MCU ... i have seen that "gnd at pin 8" on some cheap driver's picture already but don't know that kind of IC well enough to guess what it could be. Idea anyone ?
kikkoman
kikkoman's picture
Kame Sennin wrote:
So now we only miss the MCU … i have seen that “gnd at pin 8” on some cheap driver’s picture already but don’t know that kind of IC well enough to guess what it could be. Idea anyone ?
Could be one of the countless 8-bitters that Holtek makes. Cheap and generic. I’ve found quite a few that have GND on pin8 but pin3 would be reset I assume… no luck so far. Maybe a PIC12Fxxx or a clone, VDD and GND match too.
Does it really matter though? It’s going to be far easier to shoehorn in an Attiny.
HarleyQuin
Thumbs up for a link to the boost controller, I’m pretty sure I hadn’t seen that one.
I’m interested to see some performance values of the driver. I’ll buy me a pair of T2 at Fasttech, 12.47$ -5% BLF code = 11.85$ ist the best offer around. Banggood, Gearbest, all more expensive despite some code offers.
In the meantime, I need 2 measurements: The outer diameter of the driver (roughly to 1/10 of a mm) and the inner diameter of the retaining ring.
Much obliged.
I’m already tweaking my Oshpark boost drivers for the T2, I’m pretty sure I’ll build them myself as I’m not that fond of shoehorning MCUs… any more Big Smile
Oshpark Boards:
Kame Sennin
PCB OD : 17.1mm
Retaining ring ID : 14.7mm
Schematic updated, links and  dimensions added
HarleyQuin
Thanks a lot! Smile
Oshpark Boards:
Kame Sennin
Trying to measure the current drained from the battery whith an ampmeter did some very weird things at max brightness. I guess that the voltage loss in the measurement shunt was too high and made the driver to enter a very fast ON-OFF loop.
So i measured the voltage across a (very) low R shunt and got  3A max with a freshly charged eneloop.
Changed the 0.2 ohms limiting  resistor in the driver of a second T2 (stupid me who didn't think of measuring this one before modification for reference !) for a 0.5 ohms, got about 2A max and then 1 ohm wich was 1A max
Lux measurments are from a calibrated Minolta T-10A using a 20cm polystyrene foam ball setup according to Djozz's "fast and cheap integrating sphere". As i don't have a calibrating light for now i have no good way to convert from lux to lumen but a Convoy S2+ with xm-l2 T6-4C at 1.4A (4*7135) in mid (40%) mode (should be about 200lm ?) reads 924 lux with the same setup.
  T2-a 0R2 T2-b 0R5 T2-b 1R0
  A Lux A Lux A Lux
Low 0.023 13  / 11 0.014 8.6
Mid 0.260 152  / 113 0.133 86
High 3.0 1150 2.0 848 1.05 585
Jack Kellar
Jack Kellar's picture
Last seen: 8 hours 51 min ago
Anybody got any idea as to when this will start being sold at the Convoy store?
Kame Sennin
You mean T2 ?
You can buy T2 from Convoy store on aliexpress since the mid august iirc (mine was from a 08/29 order)
Jack Kellar
I’d never seen it before there, and it sure is. Cool beans, getting that (alongside an S2+) ASAP.
kikstyo
Last seen: 1 year 1 month ago
Get the T2 from their Taobao store instead. https://item.taobao.com/item.htm?spm=a1z10.1-c.w4004-16307498356.2.7c0b2...
Taobao Description:
(2) Low voltage protection: When the battery voltage is between 2.9 and 3.1V, the flashlight will alarm, showing a weak brightness with 2 flashes per second.
(3) Reverse battery protection: the battery will not light up, but there will be no abnormalities, no need to worry about burning the battery or circuit
It has low voltage protection and reverse battery protection while the one on Aliexpress store doesn’t have them. Pretty disappointing as the Aliexpress store is direct from Convoy. Anyone contacted Simon about this?
Jack Kellar
Thanks, but nope, don’t intend on getting it from TaoBao, even because I don’t have 14500 cells to toss in it so the LVP is moot and I don’t think they even ship to my country. If anything, I’ll wait for Simon to have his stock updated/upgraded.
2100
Last seen: 1 year 6 months ago
Oh shoot, 774Hz PMW freq. What the…..
HarleyQuin
Got 2x Convoy T2 from Fasttech. I’m very pleased.
The moment I held one in my hand I thought:
  • I need more
  • as host please!!!
  • do these come in colors???
Really nice look and feel. I’m a sucker for the S2+, and this is absolutely its little brother.
Greatest asset is that a driver of 17mm does fit. Makes DIY much easier, and the trade-off of a slightly larger diameter is really insignificant.
Lineup:
From left to right
SK68 clone, Ultrafire SK58, Convoy T2 (/w clip + sling), Thorfire TG06, Uniquefire G10, Utorch UT01, Convoy T2, Manker T01, Thrunite Archer 1A
Stock mode spacing is already really good, waaaaaay much better than most, especially the expensive AA lights. But doubleclick-to-strobe and PWM are a downside. Leaves room for improvement.
Wink
Oshpark Boards:
Sillen
Sillen's picture
Last seen: 1 week 3 days ago
Got my Convoy T2 last week. Haven’t had much time to play with it. First impression, big and heavy for a AA only
If you like the smaller lights, I recently took delivery of a batch of small Sofirn lights – SF10, SF12, SF14v2.0 & SP10v2.0. The SP10 comes in black, red and blue.
HarleyQuin
I really like Sofirn lights, but not the AA ones so much.
Speaking of size, their 3 clicky lights (SF10, SF12, SF14) are all larger than the T2.
And the SP10 is a momentary light (that comparison would really be apples and oranges) more in the ballpark of the UT01. I eyed the SP10 for some time, but refrained because of the don’t-drop-it-or-it’s-broken problem. And it’s much more difficult to mod them. Most lights I buy, I see them as hosts, which happen to have stuff inside… Smile
Oh, and color, the Sofirn red is too pink for me. The Convoy red is good. Not as nice as the Maglite red, but good. I’d take blue and green as well…
Oshpark Boards:
alberto7
Last seen: 1 day 14 hours ago
Anyone know the size of the led mcpcb?
gchart
gchart's picture
Last seen: 1 hour 45 min ago
Sorry to dig up an old thread, but I was poking around about the driver in the T2 and ran across this. Great schematic!
And yeah, that’s PIC-like layout, not compatible with our usual attiny’s. But the new ones (attiny412) would work, as long as you don’t mind the new architecture. The one downside I see… no provision for voltage readings via a voltage divider. And since the voltage coming into the MCU is boosted, internal vref readings are out of the question. So no driver-based LVP? Hmm… at least it’s a 17mm driver.
iamlucky13
Last seen: 3 hours 27 min ago
There doesn’t seem to be a dedicated Convoy T2 thread, so I might as well post here, since this thread is driver focused.
It seems there is a new driver for the T2, and both the old and the new version are currently available.
Original T2 listing, XP-G2
Original T2 Driver, AA only, 3 mode
Updated T2 listing, XP-G2 or Nichia 219C
Updated T2 Driver, AA or 14500, 4 mode
There are a few additional details about the new driver shared in the Convoy general discussion thread starting at post 2340.
  • No PWM (original version is 744 Hz on medium and low)
  • Low voltage protection between 2V and 2.8V to protect 14500 cells, but allow AA use.
  • Optional 12-mode firmware (similar to Biscotti) planned?
Lightbringer
Lightbringer's picture
Last seen: 4 min 19 sec ago
Whoa. I wasn’t aware this light even existed. Looks nice, but that clip gots ta go. It needs to be a deep-carry clip, especially for a short light like an AA/14500.
At least it’s not a chromy silver afterthought-clip…
The 4-mode driver looks nice if in fact it removed blinkies.
iamlucky13
It has existed for a while, but I don’t think many people were very interested in it, because of it’s relatively large for an AA light, and the PWM was a dealbreaker for a lot of users.
With the new driver, it seems a lot more appealing.
Cythras
Cythras's picture
Last seen: 59 min 59 sec ago
It’s not perfect, but the bolt-on style of clip works decently well here through the lanyard holes. It would be nice if there was a groove cut for Olight’s old baton style clip.
MascaratumB
MascaratumB's picture
Last seen: 5 hours 29 min ago
This is what I did to my T2. I use the pocket clip of an Amutorch S3 and screwed it in, using some bolts.
The holes in the “screw in” clips sold by Convoy (and many other stores) are more distant than the lanyard holes in the tail of the T2.
This is a comparison with the Sofirn SF14 (top), that uses a “regular” screw in clip!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
