Test/review of Shockli 18350 1150mAh (Black) 2018
13 posts / 0 new
HKJ
HKJ's picture
Last seen: 22 hours 20 min ago
DSC_1291
Official specifications:
  • Battery: 18350
  • Battery Type: Lithium-ion
  • Rechargeable: Yes
  • Protected: No
  • Voltage(V): 3.7V
  • Capacity: 1150mAh
  • Max discharge current is 10A / 15A
Shockli%2018350%201150mAh%20(Black)%202018-info
A high capacity and high current 18350 cell.
DSC_1289 DSC_1290
DSC_1292 DSC_1293
DSC_1294
DSC_1295
DSC_1296
Shockli%2018350%201150mAh%20(Black)%202018-Capacity
Fairly good discharge curves up to 10A.
Shockli%2018350%201150mAh%20(Black)%202018-Temp-7.0
Shockli%2018350%201150mAh%20(Black)%202018-Temp-10.0
Shockli%2018350%201150mAh%20(Black)%202018-Temp-15.0
Shockli%2018350%201150mAh%20(Black)%202018-CapacityTimeHours
Shockli%2018350%201150mAh%20(Black)%202018-Energy
Shockli%2018350%201150mAh%20(Black)%202018-PowerLoadTime
Shockli%2018350%201150mAh%20(Black)%202018-TripCurrent
Shockli%2018350%201150mAh%20(Black)%202018-Charge
Conclusion
This is from the new generation of 18650 that has high capacity and can handle high current.
Compare to older 18350 the performance is very good.
Notes and links
The battery was supplied by shockli.com for review.
Comparison to other LiIon batteries
SKV89
Last seen: 13 min 7 sec ago
It’s better than the majority of 18350 out there but too bad not as good as the Aspire and Vapcell. I’m really looking forward to a 1500mah 18350 to match 18650 energy density. Thanks for the review!
Pete7874
Pete7874's picture
Last seen: 1 hour 8 min ago
Wishful thinking, IMO. A physically larger cell will always have higher energy density.
Barkuti
Barkuti's picture
Last seen: 3 hours 43 min ago
The already known Yodeli 18350 1100mAh 15A (cough!) 10A cell. No surprises. It seems that Yodeli bins their cell production with slight chemistry changes and sets slightly different pricepoints to it, this is the reason this cell ranges from ≈1000mAh to 1100+mAh:
BestFire IMR18350 1500mAh (black-silver)
Keeppower 18350 1200mAh UH1835P (black) 2017
Vapcell INR18350 1100mAh (purple)
The curve shape is a little bit different for the BestFire and Shockli cells. The Shockli performs a little bit better at high current, with slightly less capacity than its wrap figure. Overstated as they like to.
Cheers Smile
P.S.: the weight in the Shockli cell chart (20.7g) seems incorrect.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts or at least trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
eas
eas's picture
Last seen: 4 months 4 days ago
And, for a given generation of materials & chemistry, a larger cell will also have a lower IR and higher power density, because it will have ~two or more times the electrode area.
Or, putting it another way, if Samsung made an 18350 that was exactly the same as the 30Q, except the case and core were shortened. It would have <1500mAh capacity, and it would have a continuous discharge rate of <7.5A.
HKJ
HKJ's picture
I do not know what you are talking about, the weight is 25.1 gram Big Smile
(Thanks, I wonder how that sneaked through).
Boaz
Boaz's picture
Last seen: 4 days 2 hours ago
I’ve always thought this was a poor choice of names for a battery... i was shocked when i first saw it .
 I’m looking forward to the new line of smaller cells called ..  Shorted.
So when you get a bad one you may say... shockingly I got a dead shorted shockli
raccoon city
raccoon city's picture
Last seen: 9 min 33 sec ago
If you think that's a stretch...
Chinese actress Gong Li
gong_li
Chinese actress Gong ShockLi
gong_shockli
fedcas
fedcas's picture
Last seen: 13 hours 10 min ago
Thanks for the review HKJ Wink
Mmh… either these Shockli or the Aspire doesn’t seem very consistent: https://www.youtube.com/watch?v=xr70mpOUS1s (minute 8-9)
Barkuti
Barkuti's picture
Did someone able to somehow properly test these bought some recently? I am wondering if the stuff is still at least as good or super close, I mean, if they haven't gone downhill too much.
master-of-disaster
Barkuti wrote:
Did someone able to somehow properly test these bought some recently? I am wondering if the stuff is still at least as good or super close, I mean, if they haven’t gone downhill too much.
I hope they’re still good, I’ve got a 4-pack coming in the mail, but no testing equipment.
Pete7874
Pete7874's picture
Boaz wrote:
I’ve always thought this was a poor choice of names for a battery…
If you thought Shockli was a bad name… http://budgetlightforum.com/node/62973
Shockli-Simon
Shockli-Simon's picture
Updated on 10/09/2019 – shockli -simon
Shockli 18350 1150mAh Battery have promotion on US Amazon
- Shockli 18350 1150mAh Battery specifications
- Capacity: 1050mAh-1150mAh
- Continuous / Max Discharge Current : 10A / 15A
- Work Voltage : 2.75V – 4.2V
- Positive: Flat Top (Does not make contact if used end to end in series for flashlight)
- Ideal for : Flashlight, Electronic products
Promotion on USA amazon store
You can search“18350 battery” in us amazon, USA BLF number can PM me on BLF or email to sales@shockli.com, I will give $3 promotion code, you can get 2pcs 18350 battery in $ 12.99, Now the promotion only available on us amazon
