Sofirn SP36, impressions of a sample
579 posts / 0 new
djozz
djozz's picture
Last seen: 8 hours 10 min ago
Nooner wrote:
Any more news about this light? Availability? Final specs?
I think that the specs of the sample that I got are reasonable final. It seems a good working design as it is. I asked for a non-glued driver by using a driver retaining ring instead but they do not want to do that in fear of it coming loose, and I asked several times for a nice neutral led version, no answer yet about that. Sofirn asked Toykeeper to adjust the firmware because they found that the flashlight could become too hot with the standard Q8 software, not sure what the current ststus is of that. For the rest I see no obvious flaws in the design.
So I expect the SP36 to become available soon, I’d say before the end of the year, but that is not based on actual promises by Sofirn. Perhaps Barry has more exact information, hope to hear from him soon.
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 8 min ago
I’m not entirely sure either. I think an engineer at Sofirn may be trying Anduril to see if it is suitable, but I haven’t gotten confirmation yet. I think Sofirn may be sending me a sample too, but I’m not sure if that’s really necessary or what exactly I would need to do with it. I asked, if a sample is sent, that it not be glued… because I don’t think I can spot-weld a handle onto the driver and crowbar it out as shown earlier in this thread. Glue would likely just interfere with any help I might be able to provide.
Anyway, it has been a week since I heard anything, so I sent a ping to see how things are going.
Nooner
Last seen: 5 hours 41 min ago
Thank you Djozz and Toykeeper for taking the time to respond. I’m definitely interested to get this light.
Satan@103TFS
Last seen: 8 hours 47 min ago
This light will look nice with SS bezel.
Tally-ho
Tally-ho's picture
Last seen: 9 hours 25 min ago
The SS bezel is going to be gigantic but anyway, the glued driver has completely annihilated the initial interest I had for this model.
ToyKeeper
ToyKeeper's picture
If I understand correctly, the plan is to release the light right away with NarsilM because it has already completed testing on the hardware, and then possibly consider using Anduril in later batches if it works well.
Jerommel
Jerommel's picture
BlueSwordM wrote:
@djozz, actually you are probably right.
They said they set the charging rate for 2A at the cell level, not at the USB buck converter level.
That means since the USB charger is outputting about 5V at 1,65A(could be 1,75A if you used an even shorter and thicker gauge USB cable), that would mean the charger is outputting 8,25W, and at 4,2V max charging voltage, that is about 2A to the cells.
TLDR: The cells are being charged at 2A at 4,2V.
Hmm.. Chances are they use a simple linear charging circuit. You know with that well known 4056 IC.
Sorry, it seems there’s a buck converter on board indeed.
Nice.
2Q19
Jerommel
Jerommel's picture
Hey, nice light!
To me somehow much more attractive than the Q8, (which i didn’t buy afteral.)
Hope for no glue, but something has to keep the driver in place….
We’ll see.
2Q19
Satan@103TFS
No glue please Sofirn ,hundreds of light come with driver retaining ring without loosing problem why this light will.
djozz
djozz's picture
In most of those hundreds of lights the battery tube does not screw against the driver retaning ring. In the current SP36 design it would. It would require a different smaller driver and a pretty major re-design of the head to do it well. (mind that I would like to see the retaining ring as well, I just give you the considerations)
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 hours 16 min ago
Well, how about placing some screws to fix the driver in the head? Would that be feasible? If glue is the only option, how about using glue that can be dissolved/broken easily like this hot-glue you can find in every DYI-store?
djozz
djozz's picture
That is how it is done in the Q8 which is also made by Sofirn. Sofirn made the SP36 as a compact version of the Q8 so they are well aware of that solution, requiring milling the driver cavity in a non-round shape instead of simply turning it with a lathe, with added consequences for the spatial design of the driver circuitry. They decided not to do that, I guess it is a matter of cost.
I assume that they do not aim the SP36 at the modding crowd but at normal people, and perhaps rightly so, with the USB charging this is a very easy flashlight to handle, with still impressive performance. It may just sell well like it is.
2100
Last seen: 11 months 2 weeks ago
Seems to be able to sustain low 5000 to upper/mid 4000 lumens in Turbo for 4 mins plus in a smaller/lighter host than the Q8. That’‘s pretty efficient.
djozz
djozz's picture
There are a few flashlights out there that have similar output at a similar size but this performance is surely at the upper limit for its size. But not the output sets this light apart, but the output combined with a decent reach, the beam is not all flood compared with lights with multiple leds/TIR’s. And it is the first in its class with 2 amp USB-C charging (no doubt more will follow though).
Hopefully what makes it most unique will be the price, I hope for under 40 dollar (but I have no idea btw, Sofirn has told me nothing about the price))
PBWilson
Last seen: 5 hours 4 min ago
Any news or updates? I’m eager to find out more to see if I should stash some money away.
djozz
djozz's picture
Not from me.
ToyKeeper
ToyKeeper's picture
No updates yet. Postal tracking says my sample was delivered, but… it wasn’t.
This isn’t the first time my local delivery agent has done this sort of thing. Or the second time. Or even the tenth time. So I’ll see what I can do to track down the package. It’s probably either delivered to the wrong address or still sitting in his mail truck.
ToyKeeper
ToyKeeper's picture
Okay, I have a SP36 now. My neighbor is a good person, and hand-delivered the package they received by accident. The label on the package is correct; my local delivery agent is just sloppy.
So. I have a SP36 sample. It’s a little banged up in ways which weren’t caused by shipping, but the important part is, the driver isn’t glued. It actually falls right out if I point the head upward without the body tube installed. So this should be a good host to use for development purposes.
I have Anduril on it, working pretty well. I haven’t tested the thermal regulation yet, but other functions appear to work.
The charger works too. If I connect it to a USB power bank, it charges at 1.5A. The flashlight still functions while this is happening, but the button’s charging LEDs override the driver’s normal indicator LED functions. That’s fine though. The light can actually be left in battcheck mode while charging, to get realtime progress information (ish; reported voltage is the charging level, not the cell’s resting level).
It can also run entirely off USB power, with no cells installed. It just makes the button LED behavior change; when it’s running at 5V it has no low mode for the button LEDs, and instead just goes smoothly from green to red as the main emitter power goes from moon to 350mA. And battcheck displays 4.2 to 4.4V in this mode.
It’s running the experimental SP36 build of Anduril I made a few weeks ago. I took some guesses about the light and the driver, compiled a version I thought might run on it, and … it works. So I mostly just need to make sure the calibration is correct, like for the voltage readings, thermal regulation, and the ramp shape. And then it should be good to go for production purposes.
PBWilson
Thanks TK. I’m looking forward to finding out the final details.
ToyKeeper
ToyKeeper's picture
This may be redundant, but here’s a picture to show how the physical size compares against other related lights:
Emisar D4S (1×26650), Fireflies ROT66 (3×18650), Sofirn SP36 (3×18650), BLF Q8 (4×18650):
It aims to be a smaller Q8 with built-in charging over USB-C, and that is a good description of it.
As a side note, the SP36 button LEDs are in low mode here. On high mode, its button is the brightest of the bunch. Easily bright enough to use as a firefly mode or a low moon. However, I wouldn’t recommend leaving it on the high mode, due to the amount of power it uses. It’s almost as much as moon mode. I measured the following:
  • At 4.2V:
    • Moon mode: 1.96 mA
    • Button LED (high): 1.54 mA
    • Button LED (low): 0.08 mA
  • At 3.3V:
    • Moon mode: 1.32 mA
    • Button LED (high): 0.78 mA
    • Button LED (low): 0.05 mA
FWIW, the estimated runtimes with 3×3500 mAh cells are:
  • Moon mode: ~9 months
  • Button LED (high): ~13 months
  • Button LED (blinking): ~8 years
  • Button LED (low): ~18 years
So I’m setting the default to low during “off” mode, and blinking during lockout.
adirus
Last seen: 38 min 49 sec ago
Thanks for the update Toykeeper. Going off to order VTC6s in preparation for this light.
ToyKeeper
ToyKeeper's picture
I managed to let the magic smoke out already too. Smile
With the driver loose like this, something got shorted while putting the battery tube on… and it turned the red LED+ wire into ash. But that was the only part damaged, so it was easy to fix.
So, although it would be nice if the driver was screwed in like the Q8… without that, the driver glue is kind of necessary. Hopefully the next version can replace the glue with screws. Until then though, don’t expect to do any modding without doing like djozz did earlier in this thread. It looked like quite a bit of effort to get the driver out.
djozz
djozz's picture
Thanks ToyKeeper for the work on the SP36. I think the SP36 is worth developing well because Sofirn already made a good start with designing it as it is, it has a nice size-performance ratio (better than the Q8 for me) and personally I like reflector beams better than TIR beams (and reflectors look a lot better too Smile ) . They could have made the design a bit more exciting (the ROT66 has that extra glamour) but because of the plain design it feels more like a working light to me, while I’m afraid to use my ROT66 in fear of scratching it Innocent .
Now that I know how to do it, it is pretty straightforward, the main obstacle is that you need a pretty powerful solder iron (mine is 80W with a quality chisel-style tip) to attach the handle to the brass ring. My driver btw clamps well in place when pushed back into the head.
djozz
djozz's picture
Btw, with a good mains USB charger plus short USB->USB-C cable (both Blitzwolf), the charging speed that I got was 1.95A, so the 2A charging that I was told by Barry it should have is met if the conditions are good.
ToyKeeper
ToyKeeper's picture
I let the SP36 charger top off some cells. It runs at about 0.7 A when plugged into my USB hub, but that’s not surprising. Just slow, when divided between three cells. Anyway, it terminated right at 4.20V. I don’t know if this is normal or if I was just lucky to get one with an accurate chip, but it’s nice that it did exactly what it’s supposed to.
DB Custom
DB Custom's picture
Last seen: 17 hours 6 min ago
Facepalm
Thanks a LOT guys! ANOTHER light I HAVE to have… more cells, always more cells…
PBWilson
*crosses fingers for NW tint option, minimal/no glue, decent price
So would 30Q or VTC6 button-top cells be good choices? Any others?
DB Custom
DB Custom's picture
Samsung 25S will deliver the most power for the longest time, at a better price typically. There is a new 24S that might best it if it can be found. Either of these will outperform the Sony VTC5A which itself outperforms the 30Q or VTC6.
DB Custom
DB Custom's picture
The GA and 30Q are likely candidates for a blending of power and run time, just saying.
erlebo
Last seen: 5 days 20 hours ago
The SP36 is now in their store.
New Sofirn BLF SP36 4*XPL2 6000LM
