NIGHTWATCH Avaritia NA40 SE: triple SST20 3000K, 4000K, 95cri, type-C rechargeable - $42.24 Code: NA40SE New photos in post #53
69 posts / 0 new
contactcr
Last seen: 7 hours 10 min ago
We get it, you are displeased with Fireflies, move on.
Is your NA50 mystery light a smooth or orange peel reflector?
Tom E
Tom E's picture
Last seen: 9 hours 13 min ago
Oh man, you got the upgraded NA50 smile. What that means, I got no clue.
Yes - those SST-20's do throw well.
Is the tail assembly still the same? Still no spring, but a raised surface?
Adhara
Last seen: 5 hours 16 min ago
Yes – those SST-20’s do throw well.
Yes, same tail internals as pictured earlier in thread. Seems to work fine: shaking/banging while on has no effect using either 26650 or 26980.
bhstinger
Does anyone know how the switch led's are supposed to function with the stock driver? I don't see any documentation on this one.
Looks like there are 4 switch led's:
2 blue - on when light is on
1 red - ?
1 green? - ?
Cereal_killer
Cereal_killer's picture
Red and green are probably for charging use.
bhstinger
That would make sense except the head (with switch led's) needs to be removed in order to reach the charging port.
The battery is housed in its own tube with charging circuit & blue led, separate from the head. See photos from tatasal in post #53
Cereal_killer
Hm, that was my best guess…
What about low voltage indicator?
bhstinger
Thanks CK. I do appreciate the help. Yes, I think you are correct about low voltage indicator. Maybe red = LVI.
Then I wonder what the last switch led is for? No switch led's are on when light is off. But I am not sure what the function is supposed to be.
2 blue - SW locator (on when light output is on)
1 red? - LVI ?
1 green? - ?
