UPDATE! groupbuy: Lumintop EDC05C - first 100 pcs only US$29.99
65 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 8 hours 21 min ago
Hello my dear friend!
i present the latest M4D deal:
(pics below are my links to the shop - please use them ;))
Lumintop EDC05C XHP35 / 4x Nichia NCSLE17
Code: MNTOP   price: US$ 29.99 (limited to 100 pcs)
price raises to $35.99 after that
7Modes Micro USB Rechargeable Flashlight
EDC 14500 Flashlight
Features:
Utilizes a XHP35 HI LED and 4 Nichia LEDs with a lifespan up to 50,000 hours
3 output levels for both front (CW) and the side (NW)
Max 500 lumens output and 120m beam distance
Micro USB rechargeable with charging indicator and supports working when charging
using a 14500 Li-ion battery with anti-reverse, overcharge and over discharge protection
Mode memory function for general modes
Soft and comfortable silicon rubber switch
Flat tail supports tail standing to serve as a candle
Magnetic capable to suck on a metal surface for hands-free
Mini in size and the stainless steel pocket clip makes it easy to carry
Size: 90.2*21.4mm (length*diameter)
N.W.: 70g (including battery)
IP68 waterproof, underwater 2 meters (ensure the USB cover is in sealed condition)
2 years free repair, limited lifetime warranty
LEDs confirmed by Lumintop
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
Edited by: M4D M4X on 03/18/2019 - 04:22
Chatika vas Paus
Last seen: 8 hours 47 min ago
I like the design. I would like to buy it, but I will not do it because it looks too much like Olight. They can not come up with something new just copy other brand? And xhp35 with 14500…
bmengineer
bmengineer's picture
Last seen: 1 hour 48 min ago
How is this powering a 12v led from an AA cell? Are you sure it isn’t either 14500 only or XP-L Hi?
Find all my reviews of flashlights and more gear at www.bmengineer.com
lotrbfme
Last seen: 2 hours 26 min ago
Interested. Martin, could you explain the difference between XHP35 HI and Nichia in this FL? Thanks!
nnmnu1
Last seen: 2 weeks 1 day ago
Is the battery user replaceable?
maukka
maukka's picture
Last seen: 7 hours 40 min ago
I don’t really understand the emitter options. I got the impression that the main led is an XHP35 HI cool white while the side leds are nw Nichia, but then there’s both an XHP35 HI and Nichia options on banggood. So which is it and what are the emitter specs?
-X3-
-X3-'s picture
Last seen: 7 hours 35 sec ago
Nice Olight !
EDIT : I hope Lumintop also copied the Olight UI… only that could make me buy one (I will not lie, I love the design of this light)
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
M4D M4X
M4D M4X's picture
I corrected the LEDs as listed by neal
(seems Banggood got wrong data?)
wstrachan
Last seen: 1 day 5 hours ago
Bangood lists Nichia and xhp35 options. I am confused. It should be xpl-HD and Nichia right?
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
TheAuditor
Last seen: 7 hours 4 min ago
Interested
Bonum commune communitatis.
Yarp.
pc_light
pc_light's picture
Last seen: 46 min 16 sec ago
I’m both interested and confused as well Facepalm
So, Banggood appears to have mistakenly indicated XHP35 instead of XPL HD. But did they post incorrect photo images as well because their photo appears to show XPL Hi emitter.
Move towards the light.
d_t_a
Last seen: 1 day 10 hours ago
specs seem a bit confusing, raises more questions and need clarification:
“XHP35-Hi” listed in BG
=> Ok… you mentioned BG got it wrong, so the correct option is XPL-HD)
(BG has more inaccuracies, the runtime table lists the flashlight was tested using a 750mAh 16340 battery” => so now it uses 16340??
“Utilizes XPL HD + 4 Nichia 219c with a lifespan up to 50,000 hours”
=> does that mean 4pcs Nichia 219C LEDs? or is “4” just a typo or something?
“Built-in 3.7V/750mAh 14500 Li-ion battery with anti-reverse, overcharge and over discharge protection”
=> maybe this means a 14500 battery is included? because “built-in battery” would sound like non-user-replaceable (then AA wouldn’t be a battery option).
Nice looking flashlight, but would like to know how the main light (XPL-HD) and the side light (Nichia 219C) works
JasonWW
JasonWW's picture
Last seen: 1 hour 39 min ago
Here is very early review. It answers most questions so far.
http://budgetlightforum.com/comment/1472953#comment-1472953
SKV89
Last seen: 4 hours 32 min ago
If this can charge AA battery, it is the very first usb rechargeable AA flashlight I’ve seen Thumbs Up
syracuse
syracuse's picture
Last seen: 1 hour 5 min ago
From BG’s page:
“*2) To avoid the risk of exposition, it’s forbidden to charge the AA (Ni-MH/ Alkaline) directly via the flashlight.”
JasonWW
JasonWW's picture
It can be designed a few different ways. One way is it detects if the voltage is about 2.3v or higher. If so, it will charge to 4.2 with a lithium charge curve (CC/CV).
If below 2.3, it charges with a NiMh charge curve to 1.5v.
The other option is that it does not charge at all if the voltage is below 2.3v (roughly). This would prevent accidentally charging a AA alkaline battery.
Or perhaps we have to use our own judgment to not use the usb charging when there is a AA battery inside.
Another situation is that it may not even work with AA. It might be 14500 only.
HONDARIDER
HONDARIDER's picture
Last seen: 8 min 13 sec ago
Not sure about this one. 500 lumens is ok for EDC but the XP-L HD is capable of so much more. Wish it were in the 800-1000 lumen area. Not much on the built in battery. I have so many, I would like to be able to change them out. Think it would be great for a gift. Looks cool though.
saypat
saypat's picture
Last seen: 36 min 15 sec ago
can one have the front and side light on simultaneously?
M4D M4X
M4D M4X's picture
Lumintop confirmed they use a xhp35
cell is of course user exchangeable
AA and NiMh and 14500
JasonWW
JasonWW's picture
No.
JasonWW
JasonWW's picture
That doesn’t make much sense. A 14500 battery can not supply the amps needed to run the xhp35 at any decent output (higher output than an xpl). Are they running it at 500 lumen (2.5A-3A at the battery) to get better efficiency compared to an xpl/xpl-hi?
I guess they are using a boost driver anyway so why not ramp the voltage up. If so, the 4 Nichia might even be wired in series for 12v as well.
The output must be really low when using a AA.
IDK, the whole design sounds a bit strange. I’m curious to learn more about it’s driver.
M4D M4X
M4D M4X's picture
me too.
M4D M4X
M4D M4X's picture
price: US$ 29.99 for the first 100 orders
(then price raises to 35.99)
MascaratumB
MascaratumB's picture
Last seen: 4 hours 46 min ago
This light with a double tail click (1 for the front led, another for the side led) would be nice!
Not saying it is not right now, but it would be nice in a different way (for me).
I’m with others, the 500 lumens on a XHP35-HI… Flat Stare
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
M4D M4X
M4D M4X's picture
hopefully there is a senseresistor... Wink
bikenber73
bikenber73's picture
Last seen: 1 week 17 hours ago
Ordered !
Thanks
bidas
Now on banggood says:
“Main Light: XHP35 HI, Cool White
Side Light: 4x Nichia NCSLE17, Natural White”
gottobegeek
gottobegeek's picture
Last seen: 8 hours 6 min ago
Is that a tritium vial slot in the tail?
g
JasonWW
JasonWW's picture
That’s how you loosen the battery cover.
bidas
EDIT:Is just a notch to unscrew the tail.
Tom E wrote:
The EDC05C’s tail can unscrew with a regular screw driver or slim coin
From Tom E
Scallywag
Scallywag's picture
Last seen: 4 hours 24 min ago
It's a clever idea. I've decided I don't like 219Cs or 14500 lights, though. Another near-miss from Lumintop, for me. I want to like their lights so much, but I've yet to find the right one.
I do question the O-light aesthetics - while it's not a bad look, it's someone else's look.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V
"Back-Ups": EagTac D25C Ti | Olight S1
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2 | Jaxman Z1 White Flat
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
