Test/review of Keeppower 14500 1000mAh P1450C2 (Black) 2019
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 44 min ago
DSC_6896
Official specifications:
  • Nominal voltage: 3.70V
  • Nominal capacity: 1000mAh
  • Minimum capacity: 950mAh
  • Charging voltage: 4.20+/0.05V
  • Charging current: 500mA
  • Charging current cut-off: 20mA
  • Discharge cut-off voltage: 2.75V
  • Maximum discharge current: 1.9A
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-info
This is high capacity protected 14500 LiIon batteries from Keeppower.
DSC_6895
DSC_6897 DSC_6898
DSC_6899
DSC_6900
DSC_6901
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-Capacity
The two cells match nicely and can easily deliver the rated 1.9A
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-Temp-2.0
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-Temp-3.0
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-CapacityTimeHours
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-Energy
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-PowerLoadTime
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-TripCurrent
Keeppower%2014500%201000mAh%20P1450C2%20(Black)%202019-Charge
Keeppower%2014500%201000mAh%20P1450C2%20%28Black%29%202019-Pulse-0.5A-30-30-2.8V-IR
Conclusion
This cell has good capacity and the length is fairly short for a protected cell. It can be used in most equipment that requires a 14500 LiIon cell (length may be a problem in a few cases), it a very good candidate for equipment that can run on both 1.5V and LiIon cells (This type of equipment usual needs protected LiIon cells).
Notes and links
The battery was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Edited by: HKJ on 07/06/2019 - 03:20
djozz
djozz's picture
Last seen: 26 min 54 sec ago
Thanks for the test HKJ, that looks like a fine cell.
SKV89
Last seen: 1 hour 30 min ago
Is it the same cell used in the Vapcell gold?
toobadorz
toobadorz's picture
Last seen: 2 weeks 17 hours ago
Yes. This is a protected DLG NCM14500-950 cell, the same cell core as Vapcell Gold 14500 1000mAh.
Superstocker
Superstocker's picture
Last seen: 1 hour 11 min ago
Thanks HKJ!
MiG0
Last seen: 17 hours 34 min ago
Any coupons for this item?
teacher
teacher's picture
¯\_(ツ)_/¯
ggf31416
Last seen: 13 hours 23 min ago
Good to know that that cell is getting into protected batteries. Some flashlights really need protected cells, I lost a pair of unprotected 14500 (not vapcell) from overdischarge to 0.7V . The price I found for these is still high but hopefully it will go down in time.
SKV89
Man shipping is expensive on banggood now for this cell. I ended up buying the Orbtronic version since the price is not much different and I think Orbtronic is one of the highest quality brands.
