Keeppower 14500 1000mAh P1450C2 (Black) 2019
Official specifications:
Nominal voltage: 3.70V
Nominal capacity: 1000mAh
Minimum capacity: 950mAh
Charging voltage: 4.20+/0.05V
Charging current: 500mA
Charging current cut-off: 20mA
Discharge cut-off voltage: 2.75V
Maximum discharge current: 1.9A
This is high capacity protected 14500 LiIon batteries from Keeppower.
The two cells match nicely and can easily deliver the rated 1.9A
Conclusion
This cell has good capacity and the length is fairly short for a protected cell. It can be used in most equipment that requires a 14500 LiIon cell (length may be a problem in a few cases), it a very good candidate for equipment that can run on both 1.5V and LiIon cells (This type of equipment usual needs protected LiIon cells).
Notes and links
The battery was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
