My BLF A6 works, but is very dimm (help please)
10 posts / 0 new
foristo86
My BLF A6 which I have had an enjoyed for a while now has now became very dimm but it still working as should (it’s just dimm). It’s not the battery, I’ve checked it on multiple ones. Has the light died?
Here’s a video showing the issue that I filmed yesterday.
Any advice would be great!
Lightbringer
Lightbringer's picture
Last seen: 9 hours 39 min ago
First thing(s) I do if a light goes wonky is to take it apart as much as practical and “give it a tune-up”.
Snug up all retaining rings, remove/clean/lube all O-rings, clean/lube all threads, clean/buff exposed ends of the tube, springs, etc., for better electrical contact, and so on.
Yours sounds like it might be a driver issue. Ain’t got an A6, so will defer to those who do.
foristo86
Thanks! I’ve cleaned it all and applied some bike grease very carefully and put it back together, but the issue remians Sad Any suggestions for how I could fix the possible driver issue?
SIGShooter
SIGShooter's picture
Last seen: 8 hours 22 min ago
I noticed that the light flashes a number of times after you turn it on (LVP?). You mentioned that you tried a number of batteries but did you measure their voltages with a DMM?
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
foristo86
It is me switching the modes from low, med and high. It seems like all the batteries I own have the same effect on the light. Sorry, I dont know what a DMM is, I am guessing I probably dont have one if I dont know what is is Smile
TMaxxJJ
Last seen: 1 hour 24 min ago
Digital multimeter. What charger do you have? Does it show the battery voltage when you start charging a battery?
Just out of interest, where abouts in the UK are you based?
Rat_Racer
Rat_Racer's picture
Last seen: 3 hours 14 min ago
Digital Multi Meter
foristo86
TMaxxJJ wrote:
Digital multimeter. What charger do you have? Does it show the battery voltage when you start charging a battery? Just out of interest, where abouts in the UK are you based?
I have a LiitoKala Lii-100 USB charger
I dont have a DMM and I live in Leeds, WY.
TMaxxJJ
Ah ok, a bit far, I was going to offer to take a look at it for you. Have you checked to see if the driver retaining ring is nice and tight?
foristo86
Thanks anyway! Yes, it’s all nice and tight.
