Custom CRI 90+ 4W GU10 LED spotlight bulb LUXEON 2700/4000/5000K
20 posts / 0 new
Bocian
Bocian's picture
The latest edition of modified Niviss 4W LED spotlight bulb described below:
Bocians custom 90+ CRI 4W GU10 LED spotlight bulb 3000/4000/5000/5700K
This version is based on Lumileds LUXEON 3030 2D Line (Square LES) LEDs It is new Lumileds product, achieving efficiency levels of 130-145lm/W at CRI 90+ (it is rather in vain to look for such 3030 diodes from other manufacturers). Such high efficiency was achieved due to, among other things, the specific structure of this emitter (the light emitting surface of the diode has a square shape). It is also interesting that color coordinates are “hot binned”, at a temperature of 85 ° C (thanks to which the declared color parameters of light , are to correspond in real terms of use to the manufacturer’s declarations.) Below is the link to the LEDs documentation:
SPECIFICATION:
Two-structure LUXEON 3030 diodes are connected in 2s2p topology and powered 140mA per emitter. The isolated converter supplies ~ 11.5V voltage and 280mA output, which gives the power of ~ 3.2W with which the diodes work. The measured efficiency of the inverter is ~ 80% at a power factor of PF = 0.6 Optics – textured reflector. Total wide emission angle approx. 120*.
Heat sink made of CNC machined aluminum with a very good thermal possibilities in relation to the power with which the source works. The total active power consumed from the 230V grid is 4W (after heating up, the average power consumed is 3.8W). The temperature that the radiator reaches after heating at room temperature is ~ 50*C. Onboard converter with isolated and very fast output (frequency 60-70kHz) which means no exhausting eyes flickering (strobo / flickering effect). The power supply has high quality components (including Rubycon BXC series electrolytic capacitors).
Housing in color SILVER + gray bezel, GU10 base (connected directly to the grid).
Input Voltage: 85 – 264 V AC
Frequency: 47 – 63Hz
Operating temperature: -20°C – +40°C
Lifetime: Up to 50,000 hours @ 25°C room temperature
Below all available color options:
2700K CRI min. 90 luminous flux min. 400lm – 8$
4000K CRI min. 90 luminous flux min. 440lm – 8$
5000K CRI min. 90 luminous flux min. 440lm – 8$
Shipping cost (international shipping priority registered package via Polish Post):
1-5 pcs 5$
6-8 pcs 7$
9-16 pcs 13$
PayPal payment.
Each source has a 3-year warranty from the date of sale.
Total length of the 54mm source
Diameter at the widest point of 50mm
Weight 58g
The luminous flux of LED module for the 85*C LEDs junction temperature.
Edited by: Bocian on 10/29/2019 - 08:10
Agro
Agro's picture
Last seen: 1 min 32 sec ago
According to datasheets:
Everlight 62-227ET/RK6D does about 200 lm/W (not sure, probably cold binned). But it’s not 3030.
Osram Osram Osconiq S3030 does 173 lm/W cold and about 163 lm/W warm. And it is 3030.
BTW, I like your lights.
Bocian
Bocian's picture
With CRI min. 90? Check one more time Wink
Agro
Agro's picture
Yes, CRI min. 90.
Osram GW QSLM31.QM.
Agro
Agro's picture
Also, Samsung LM301B seems to do about 145-185 lm/W when hot depending on CCT and bin lottery.
Lexel
Lexel's picture
Last seen: 4 days 22 hours ago
2700K 90CRI 132lm/W L130-2790003000×2 @120mA hot
132lm/W CRI90 2700K
11.2V 280mA—>3.22W—>425lm
80% PSU
3.22W/0.8—>4.025W
so all is pretty much solid
Bocian
Bocian's picture
Yes bin lottery :-). All the LEDs manufacturers pride themselves on advertising brochures with extremely high product performance that is achieved by a small percentage of total production (and is usually not available for mass purchase). As you can see, these are all quite fresh products (a common feature is the square emission surface). To be honest, I have to admit that I started this project a few months ago and did not follow new products of 3030 class from other manufacturers. Osram GW QSLM31.QM, as I can see, has a lower thermal resistance but is a single 3V diode (in this design you would have to use them twice as many). It also has a statistically lower forward voltage (hence a slight advantage in efficiency at similar currents, e.g. for the 2700K option).
Lexel
Lexel's picture
In that table they give you the minimum guaranteed flux for this combination of CRI and color
those low power LEDs are usually pretty much on the typical specs, and if you buy a specific reel you target for above typical flux
All those XPL V6, XHP35 HI D4, XHP70.2 P2 bins are quite a lot above the typical in the data sheet
I am pretty sure they know which flux group they got to build in the product to meet their own specs
When I build a flashlight I also know which bin I get, there is no lottery involved if you build stuff
Scallywag
Scallywag's picture
Last seen: 2 days 19 hours ago
Where was this a month ago when I bought lights for my hallway? Facepalm
Instead I got CRI80 Satco S9385. Which aren’t even that much brighter…
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Bocian
Bocian's picture
Lexel, you explain the rules that are obvious to me. Ordering mid and low power LEDs is different comparing to high power diodes (XPL, XHP...). For high-power diodes you gave as an example, we can easily buy a carefully selected, large amount of bins. But for the smaller ones, you usually buy diodes from a very wide bin range. I meant more about this situation: I open the Osram GW QSLM31.QM, data sheet and see on the first page: CRI 90+, Luminous Flux: typ. 31 lm @ 3000 K, Luminous efficacy: typ. 173 lm/W @ 3000 K for 65mA current. Then I see that the bin ranges for this option are very wide: 28.5 ... 43.5 lm. I see 12 flux bin codes from the lowest GV (25,5lm-27lm) to the highest HV (42-43,5lm). So I think OK if 31lm is typical so I should find with no problem bin H2 (30-31,5lm). That should be ~31lm and 173lm/W (cold junction). I open google, try to find it and all I see (at Mouser, Digikey, RS-online) is only bin ranges (very wide from H1-HV - 28,5lm-43,5lm). Nobody will go to the warehouse to select manually most attractive rollers. And they can be very diverse (the range is wide). That is why it is a real lottery about low and medium power diodes. I am not a great producer who can negotiate and require from the manufacturer diodes with strict parameters (and they usually do not do it because it raises the price very much). It's more like hobby production/modding ;-)
fneuf
fneuf's picture
Last seen: 9 months 2 weeks ago
By any chance, would you be able to tweak bulbs also?
Rise and Shine my precious...
Bocian
Bocian's picture
Yes, I have several designs of bulbs with high CRI. Link below but you must use translator:
https://www.swiatelka.pl/viewforum.php?f=57&sid=90349a50c40ed1c53ce988f2...
fneuf
fneuf's picture
That is very interesting Bocian. Do you have a full spectrometer report for your 3000K and 4000K setups?
Bocian
Bocian's picture
Some time ago Maukka tested Citizen 97 CRI 6,5W GU10 light sources. Link below:
http://budgetlightforum.com/node/60719
Measurements:
http://budgetlightforum.com/node/61071
fneuf
fneuf's picture
That are some really interesting results! Do you have a list somewhere of all the custom products you offer?
Have to add, that right now you top-off the brand new "BLF Bulb Quality factor" thanks to Maukka's test. Congrats!
Bocian
Bocian's picture
Hi. Yes, I can prepare such a list. BTW. Do you have any particularly desirable LEDs on which you would like to have LED-based sources? Any GU10, E27, E14 mounts and so on… But if it did happen, it would be small quantitative series.
fneuf
fneuf's picture
Based on my current knowledege, I think Nichia's Optisolis offering is top of the art and CitiLED the second's best. Have to think about it before being definitive, but personally I am sure to be interested in E27 bulbs, and maybe a few E14.
macross42
Hi Bocian,
I’ve been looking for a high CRI, GU10 (120VAC), dimmable COB LED for sometime now, and was wondering whether this Lumileds LUXEON 3030 version is dimmable (and doesn’t flicker horribly at say <10%)? There have only been a few LEDs I’ve found that are, like SORAA. I especially like that you’re using Rubycon capacitors.
Thanks!
Bocian
Bocian's picture
Unfortunately these are not dimmable but have very fast output without the strobe/flickering effect.
macross42
Ahh, thanks for the quick response! I noticed that the older Bocian Citizen CitiLED-based bulbs from the BLF table in http://budgetlightforum.com/node/69805 indicate that they’re dimmable – is this correct (e.g., cell T8) (actual Google sheet: https://docs.google.com/spreadsheets/d/12jj1A6PNjHmWbFNu0FSisEztir7izxAh...). I thought your other post on the Citizen CitiLEDs indicated that they are not dimmable either. Thanks!
I should also add that I’m looking for qty around 120, in case there is an option for custom work to make them dimmable.
