[♛ FreemeGB] ASTROLUX FT03S SBT90.2 4500lm 1428m 26650/ 21700/ 18650 Flashlight
1212 posts / 0 new
KirbyH
Last seen: 2 weeks 1 day ago
I’m curious when they’re going to actually be back in stock. I preordered my black one on December 13th 2019 and they never reshipped it after the first failed shipping attempt on January 9th 2020. I asked them many times since then when it may be back in stock considering they sold mine to someone else. I finally got sick of it on April 2nd and asked them to cancel my order once I realized no other colors were in stock either. For some reason the website has said they are in stock but as far as I’ve been told (as of the 2nd) they aren’t.
Theodore41
Last seen: 14 hours 15 min ago
Finally,what cells are OK for the job?I now have one black Keeppower.
JasonWW
JasonWW's picture
Last seen: 5 hours 4 min ago
Theodore41 wrote:
Finally, what cells are OK for the job? I now have one black Keeppower.
Which Keeppower?
The unprotected 6000mah is okay for this light, but to really get max output you need less capacity and higher amperage. I high drain cell is preferred.
Theodore41
JasonWW wrote:
Which Keeppower?
No,it is of 5200mAh.
JasonWW
JasonWW's picture
Theodore41 wrote:
JasonWW wrote:
Which Keeppower?
No, it is of 5200mAh.
Okay, that is a pretty weak battery with a lot of voltage sag. It should work if its unprotected, but dont expect full power. If its protected you’ll probably get even less power. You might only see about 10A from it which is way less power than the light is capable of.
Dep668
Last seen: 2 weeks 3 days ago
Th558 wrote:
www.banggood.com/DIY-Spare-Flashlight-Reflector-Light-Cup-Smooth-Reflect...
Has anyone tried this? One of the reviews say the beam is slightly better than the original FT03 reflector. Not sure whether that means the intensity or the beam pattern.
Edit: fixed link
Anyone ever end up trying this reflector?
California_Prepper
Last seen: 3 days 12 hours ago
Were the issues with this light ever fixed?
JordanZHP
Last seen: 3 hours 8 min ago
Not that I’ve heard. I ordered a Noctigon K1 SBT90.2 instead.
California_Prepper
I bought the Nightwatch NI40 instead but I’m still interested in this light as well
Ace7
Last seen: 22 hours 14 min ago
I’m interested in the group buy coupon code. Thank you.
freeme
freeme's picture
Last seen: 42 min 22 sec ago
Sent.
Ace7 wrote:
I'm interested in the group buy coupon code. Thank you.
