MF01 Mini / MT07- Mod/Upgrade - Copper Heatsink Cover Plate - 2nd batch available soon - 3rd batch planned
314 posts / 0 new
gerasalex
gerasalex's picture
Last seen: 7 hours 13 min ago
Dr.Phillip wrote:
Nice, so far they look great. Hope this works out and I get to play with them :). Will it be a straight plastic for copper swap or will we need to add washers and/or a bit of cpu thermal compound on those AMCs?
Between the copper “mod” and the microcircuit there is a gap of 0.1 mm, what kind of washer are you talking about ?! You can of course add a washer measuring 00.5 mm Big Smile
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
id30209
id30209's picture
Last seen: 3 hours 56 sec ago
gerasalex wrote:
Between the copper “mod” and the microcircuit there is a gap of 0.1 mm, what kind of washer are you talking about ?! You can of course add a washer measuring 00.5 mm :D
Just add Kapton tape or Liquid electricians tape
WTB Titanium 4sevens Quarks & Jetbeam TCR1
oweban
oweban's picture
Last seen: 18 hours 50 min ago
Okay, shipping looks good (international post w tracking) – lets do this!
(13.5 + 7.92, so 21.42USD)
gerasalex
gerasalex's picture
oweban wrote:
21.42USD)
In fact, if the mod allows you to hold all 5500 lumens without automatically lowering the temperature, then it’s worth it .., but it’s doubtful, without measurements ..
man of light
man of light's picture
Last seen: 7 hours 27 min ago
Basically yes, it’s only a swap of the cover plates, plastic against copper, use the same screws. You don’t need to put any washers or anything else in there, but I strictly recommend to use some thermal compound paste, as I shown with pics and described in the post #1. This is important to achieve the best thermal conductivity and by that to transfer the heat quickly from the AMC’s and the driver pcb to the body (host). Otherwise this mod/upgrade will not work properly.
man of light
I’m not sure what you mean with this statement. 5500 Lm will only be achieved in turbo mode and only with the SST-20 6500K version. The turbo mode is already thermal regulated fine from stock in the MF01 Mini. This mod solves the problem with the step down (due to bad thermal contact to the driver pcb) in the ramped modes (also top ramp) below turbo.
Measurements will follow, if not from my side, than from somebody else, but it will take a while.
twisted raven
Last seen: 2 hours 26 min ago
interested.
gerasalex
gerasalex's picture
I mean, maybe the process of lowering the temperature will not happen due to good cooling (in turbo mode) .. but I think that the case will still heat up and there will still be a decrease .. The question is actually how much time mod will extend the temperature drop in turbo mode?
Watermanchris
Last seen: 4 hours 23 min ago
I’ll take one
texas shooter
Last seen: 2 hours 50 min ago
I’ll take two if possible.
Thank you,
CoRDS
Last seen: 6 days 17 hours ago
jumping on board for one please
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 31 min ago
Man-o-man I want one of these…. Shocked Thumbs Up but then I would have to buy a MF01… Big Smile
KB1428 “Live Life WOT
Dr.Phillip
Dr.Phillip's picture
Last seen: 1 week 1 day ago
The purpose of this mod is to termaly connect the AMCs (chips responsible for ramping) to the body off the flashligt. They were not transfering heat to the flashlight body well enough and heating up during ramping modes (not in turbo) causing their output to regulate down. This mod makes sure they dont get so hot without raising the temperature of the flashlight body as well. Turbo doesnt use these chips. In turbo the leds should be driven through MOSFET. This MOSFET is one the other side of the board and shouldnt generate much heat (if any). In turbo most of the heat comes from LEDs and this mod will not influence turbo run time (how fast the flashlight heats up). Those little piece of copper should slightly increase the thermal “mass” of the flashlight (amount of metal able to absorb heat) but I think it will be such a small increase that you should not be even able to measure any significant increase in turbo runtime.
Tubercle
Last seen: 5 hours 47 min ago
In for 2, but would like more info such as % of additional runtime, some graphs, etc to make the improvement tangible. Thanks!
gerasalex
gerasalex's picture
Sorry, if it’s not difficult for you to explain, I would like to know the dependence of things: 1. The linear change mode – is this related to the thermostability of the flashlight?
2. How does the reduction in AMC power affect the operation of the flashlight, and what is the danger?
Doctawho
Last seen: 3 weeks 5 hours ago
Interested!
Dr.Phillip
For gerasalex: when this light came out, some people noticed to us strange behaviour we did not now from other lights. When you set this light to some level in ramp, lets say to max ramp value (roughly 2000 lumen) after 8-10 seconds the light will start to lower its output power and in like 20sec the visible intensity will drop to half (to like 500 lumen). This is caused by the AMCs on this two sided board. some larger lights have one sided board where the AMCs are in contact with the flashlight body. In this light, to fit them on such a small surface, they put them on the other side facinv the battery. Since they are not in direct contact with the body of the flashlight they do not transfer heat to it very well. When they get hot, the chip on the other side of the board detects the large temperature and starts lowering output power. The temperature sensor has no way of knowing if the entire flashlight is getting so hot or just one component exactly on the oposity side of the board from it is. Thats why user “man of light” came up with an idea for a MOD that would connect the AMCs to the body of a flashlight thermaly, so they would transfer heat to it and wouldnt get so hot unless the flashlights is hot.
mxyzptlk
mxyzptlk's picture
Last seen: 12 hours 18 min ago
Hallo man of light,
ich würde 5 (in Worten fünf) Wärmeleiter nehmen, passend zu allen meinen M01ern,
da Du erfreulicher weise in Deutschland Dein Domizil hast, passt es umso besser. Wink
gerasalex
gerasalex's picture
[Dr.Phillip]
Thank you, I thought that these AMCs are connected to the main temperature sensor, but it is located on the other side of the board, but there is some
something remote, not a direct relationship between them.
Xenovora
Last seen: 2 weeks 5 days ago
Interested in two pieces!
johnzm
Last seen: 2 weeks 3 days ago
I am interested in one as well.
Please send one of the prototypes to someone who is qualified in runtime data analysis. we are all interested in the tangible performance
jaynick
Last seen: 1 hour 59 min ago
^^^ this. I have the copper/stainless version and the throttling isnt too bad to my eyes so far, but id like to improve it if possible and worthwhile.
man of light
mxyzptlk wrote:
Hallo man of light, ich würde 5 (in Worten fünf) Wärmeleiter nehmen, passend zu allen meinen M01ern, da Du erfreulicher weise in Deutschland Dein Domizil hast, passt es umso besser. Wink
Sehr gerne, der Versandweg ist auf jedenfall sehr zügig innerhalb Deutschlands. Dauert leider noch etwas bis es soweit ist.
Yes, I would like to send one sample (half price + shipping) to someone who would like to do additional testing and provide some detail results like runtime graphs etc. But so far no one has offered for it. Please feel free to contact me if there is somebody who want to do this.
In the meantime I started to upgrade and build up my own testing environment. In a few days I will provide (update post #1) runtime graphs with direct comparison of the results in different scenarios, before and after the mod.
PatX
Last seen: 2 weeks 1 day ago
Interested in 4 pieces!
ZozzV6
ZozzV6's picture
Last seen: 2 days 4 hours ago
I sent a PM about testing Wink
noboneshotdog
Last seen: 3 hours 5 min ago
I would like 1 please.
Thank you!
Thier ain’t no bones in a hot dog. F. York
Ryzbor
Ryzbor's picture
Last seen: 6 hours 59 min ago
Shipping price is good. Interested. My mini also steps down rather quickly.
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
JasonWW
JasonWW's picture
Last seen: 1 hour 23 min ago
gerasalex wrote:
[Dr.Phillip]
The heat from the AMC’s seem to be flowing very quickly to the temp sensor (inside the MCU) which is directly on the other side of the driver.
We dont know why it flows so quickly, but the best theory is a combination these 2 things:
1. The AMC chips are not touching the battery tube or body so they get hotter than normal.
2. Maybe there are vias too close to the legs of the MCU (the MCU absorbs heat through it’s 8 legs). The vias might be transferring heat directly from the AMC to the MCU, which is not good.
This new copper piece adds mass to the AMC’s making their temp go up much slower. This prevents the MCU from heating up so fast.
Here is the thread where the problem was discussed.
Click this to go to signature links.
trailhunter
Last seen: 1 day 6 hours ago
Interested in 1
gerasalex
gerasalex's picture
Yes thank you ! I later read more attentively carefully .. But damn it, why did the manufacturer not take care of this? Indeed, before selling a product, it must be thoroughly tested .. as a person, before a serious fight))
