Review: Bedtime Bulb E27 LED (2200K, CRI95)
132 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 11 min 12 sec ago
yeutterg wrote:
Hey Josh, you’re right that we have some fluctuations in the US too. But our circuit handles it pretty well in the US.
Not on my block. We’re at the end of the line, pretty much the worst hold-up around. The guy who runs a huge saw on the opposite block will dim the lights here when he powers it up (inrush current).
You want to put a bulb to the test in the US, try it here. LOL
yeutterg
Last seen: 1 month 1 day ago
Well, we were planning on redesigning the driver anyway for both North America and Europe, mainly for better dimmer compatibility. This is just accelerating that!
Bedtime Bulb: The Light Bulb for Healthy Sleep
hodor
hodor's picture
Last seen: 3 hours 5 min ago
Tested for a couple hours the past few nights and didn’t notice any flickering whatsoever. Really nice cosy warm light Thumbs Up
finges
Last seen: 14 hours 53 min ago
ikkentobi wrote:
I have now used and observed the Bedtime Bulb in three locations in southern germany and wasn’t able to notice any kind of fluctuation.
Same for me!
yeutterg
Thanks hodor and finges for the feedback!
Based on the survey results so far, we haven’t noticed any issues in the UK. The most likely plan of action is to continue to sell there. Meanwhile, we are working on a new driver for all bulbs (US included) that fixes the issue in Europe and gives us a wider dimmer compatibility. It will be a while before this is ready, but I thought you would appreciate the insight.
G0OSE
G0OSE's picture
Last seen: 8 hours 22 min ago
Hi, tested mine in a few different light fittings. It takes a bit of getting used to for me because we currently have 3 × 9w lamps in our light fitting and having them off and 1 40w lamp replacing it is a massive difference (nothing to do with the lamp lol – i had 1).
It switches on instantly where my other LAP 9w lamps take a split second longer. One thing I didn’t care for much was being able to see the orange square leds inside. The screwfix LAP 9w lamp seems to spread the light much better , you can’t see the leds at all and the bulb is white. Seeing led is fine when it’s a filament or such like, not so attractive when you see a square block in the middle.
The light is a little orange for my liking, I tried it against my s41 with nichias in and an ‘orange’ fruit looked overly ‘orange’ under this bedtime light.
Tried it in 2 dimmers, 1 had no problem the other had an issue, but it was set up for the LAP lamps – it is not a normal dimmer, you can program it Varilight vpro – LINK after I adjusted it, it worked fine.
Health benefit/better sleep wise, well we had it in the bedroom a couple of nights now and so far haven’t noticed any difference. But it may take longer or be so slight you don’t ever notice it, or it does nothing at all.
I will update this in the future Smile
Thanks for letting me try it out!
yeutterg
G0OSE, thanks so much for the feedback!
I don’t recommend looking directly at any light source, regardless of how diffused or dim it is. The primary purpose of the coating is partial glare reduction when used without a shade, but the best place to put any light source is in a lamp that has significant external diffusion (such as a shade or globe). But otherwise, thanks!
Kevin Z
I’ve tried it a few times in conjunction with a simple light meter & I can confirm that the brightness is steady.
At first I tried it in a table lamp & I thought it may have had a glitch, equivalent to a very quick off /on but after a bit of testing with other bulbs I concluded it was the actual lamp & not the bulb , I’ve tried it in several ceiling light fittings & it works flawlessly.
It’s a very nice tint ,it very close to the blf lantern on the warm setting.
yeutterg
Kevin, thanks so much! Appreciate the feedback.
I will reiterate that we have decided to limit sales to the UK for now until we have a different driver design.
hodor
hodor's picture
A friend tested one in a range of fixtures over the past week and didn’t notice any flickering. It doesn’t play well with some dimmers but that’s as advertised.
yeutterg
hodor, thanks a lot for reaching out to your friend and sharing his feedback.
Cheers.
Greg
