Test/review of Test of Vapcell INR14650 1100mAh V11 (Gold) 2020
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 16 min ago
DSC_1993
Official specifications:
  • Model: INR14650
  • Size: 14.0*66.7mm
  • Type: Button top
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.75V
  • Typical Capacity: 1100mAh (0.2C discharge)
  • Min capacity: 1050mAh (0.2C discharge)
  • Weight: Max:28g
  • Internal resistance: Max:18mOhm (AC 1kHz)
  • Standard Charge: 500mA,CCCV 50mA cut-off
  • Quick Charge Current: 1500mA
  • Max Continuous Discharge Current: 6A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage Temperature: -5°C~35°C
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-info
A 14650 LiIon battery, this is AA cell in diameter, but as long as a 18650 cell.
DSC_1991 DSC_1992
DSC_1994 DSC_1995
DSC_1996
DSC_1997
DSC_1998
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-Capacity
The two batteries matches well and keep the capacity first starts dropping above 3A.
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-Temp-5.0
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-Temp-7.0
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-CapacityTimeHours
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-Energy
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-PowerLoadTime
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-TripCurrent
Vapcell%20INR14650%201100mAh%20V11%20(Gold)%202020-Charge
Discharge-Vapcell%20INR14650%201100mAh%20V11%20%28Gold%29%202020-pulse-0.5%2010%2010-IR
Conclusion
It is a unusual size, the extra size gives it a slightly more capacity than 14500 cells.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 3 hours 1 min ago
Thanks HKJ!
gchart
gchart's picture
Last seen: 4 hours 32 min ago
14650? Whaaaaaat? Interesting, but is there an application for such a battery? I would doubt it would get created if there wasn’t a use for it, but these odd battery sizes have me scratching my head sometimes.
Barkuti
Barkuti's picture
Last seen: 3 hours 20 min ago
I can remember having seen cells this size before. These TrustFire 14650 1600mAh and (discontinued) IMR 14650 950mAh are examples and feature the same anode geometric shape as this newer cell, this means it is manufactured by the same OEM (Heter). The bloated 1600mAh capacity cell appears in the official TrustFire website.
Applications? ¯\_(ツ)_/¯
Thanks for the review Henrik.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
