Test of Vapcell INR14650 1100mAh V11 (Gold) 2020
Official specifications:
Model: INR14650
Type: Button top
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.75V
Typical Capacity: 1100mAh (0.2C discharge)
Min capacity: 1050mAh (0.2C discharge)
Weight: Max:28g
Internal resistance: Max:18mOhm (AC 1kHz)
Standard Charge: 500mA,CCCV 50mA cut-off
Quick Charge Current: 1500mA
Max Continuous Discharge Current: 6A
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage Temperature: –5°C~35°C
A 14650 LiIon battery, this is AA cell in diameter, but as long as a 18650 cell.
The two batteries matches well and keep the capacity first starts dropping above 3A.
Conclusion
It is a unusual size, the extra size gives it a slightly more capacity than 14500 cells.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
