Vapcell INR14500 H10 1000mAh (Purple) 2020
Official specifications:
Model: INR14500 H10
Type: Flat top
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 1000mAh (0.2C discharge)
Min capacity: 900mAh (0.2C discharge)
Weight: Max:24g
Internal resistance: Max:18mOhm AC 1kHz
Standard Charge: 500mA,CCCV 50mA cut-off
Quick Charge Current: 1500mA
Max Continuous Discharge Current: 10A
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage Temperature: –5°C~35°C
A fairly high capacity and high current 14500 (AA sized) LiIon cell.
The two cells do not match, but they are both fairly high capacity and can deliver a lot of current for a 14500 cell.
Conclusion
This cell is from a new generation that can deliver a lot of current, but the factory has not got a completely consistent production yet.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
