Samsung high tech 21700 48X 4800mah and 50G 5000mah battery
21 posts / 0 new
vapcell Dennis
vapcell Dennis's picture
Last seen: 19 hours 48 min ago
These high-capacity 21700 batteries are commonly used in electric vehicles. It has excellent consistency, high power, high capacity and very high cycle life
In the field of electric vehicle battery, battery quality requirements are very strict. Thousands of batteries are combined into a battery pack, which requires excellent consistency and more than 2000 cycles of cycle life
So the battery rating is very harsh
Samsung 48x and 50g are excellent batteries with similar power performance, which beat Sony VC7, Samsung 50E, Samsung 48g and LG M50
Please refer to discharge curve comparison 15A
In addition, the Samsung 48x has an amazing 3000 cycle life
This is the highest cycle life of cylindrical lithium battery that I have seen so far, which is a happy thing. Lithium battery technology is progressing slowly
Edited by: vapcell Dennis on 07/24/2020 - 07:21
2A
Last seen: 28 min 31 sec ago
sounds great
zoulas
Last seen: 10 hours 39 min ago
Where do you get them from?
RapidLux
RapidLux's picture
Last seen: 4 hours 36 min ago
This 21700 Tesla rewrap also has 15A continuous and slightly higher capacity, and 1500 cycles, should be enough for most BLF’ers.
Buy: https://www.aliexpress.com/item/32880308308.html
Cycles: https://insideevs.com/news/375459/tesla-model-3-50k-miles-battery-degrad...
dmsoule
Last seen: 33 min 53 sec ago
Dennis – Thanks for the comparison between all these different Samsung cells.
SKV89
Last seen: 50 min 50 sec ago
I don’t see any graphs comparing the 48x and 50G. Do you know why Samsung created two models if they have the same performance?
Scallywag
Scallywag's picture
Last seen: 15 min 13 sec ago
Hopefully HKJ gets a pair of each soon.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
vapcell Dennis
Please try again
vapcell Dennis
We have sent each pair to HKJ a few days ago Smile
EasyB
Last seen: 1 hour 36 min ago
vapcell Dennis wrote:
Please try again
I don’t see the graphs either. Tried a couple browsers and on mobile and no difference.
thijsco19
Last seen: 11 hours 59 min ago
I can see them now.
For the people that cant see them I reuploaded them to imgur:
https://imgur.com/a/Q97Lb0A
thefreeman
Last seen: 6 hours 43 min ago
I had trouble seeing them too, on mobile I could see the non loaded pic icon and open in a new tab and that worked.
https://i.postimg.cc/6QpX0mW9/005-YO0-Afgy1gh29dgo795j30jl0fc40t.jpg
https://i.postimg.cc/zGjNTr1t/005-YO0-Afgy1gh29dn2ykbj30n40fwqon.jpg
https://i.postimg.cc/CLbSL8rV/005-YO0-Afgy1gh29dn6jhij31hc0o0ker.jpg
https://i.postimg.cc/SxqqXKHY/005-YO0-Afgy1gh29dtjpv5j30ob062jsl.jpg
edit : thijsco19 mirrored them just before me.
I assume the 48x trades a bit of capacity for cycle life. It would be nice to see the full specs/datasheets.
vapcell Dennis
Thanks you very much,sir Thumbs Up
datasheet is PDF file Facepalm
thefreeman
Is the issue file sharing between China and rest of the world ? if so a quick search gave some results : https://nihaocloud.com/ , https://cowtransfer.com/ (I haven’t tested those)
SubLGT
Last seen: 1 day 1 hour ago
Mooch’s Test of G50
Quote:
…The Vapcell G50 is a great performing ultra-high capacity 21700 cell. These beat the blue Vapcell 12A 5000mAh, Samsung 50E, and Samsung 50E2. Vapcell says they are rewrapped Samsung 50G cells and they look and perform essentially the same as the Samsung 50G…
…Samsung gives the 50G a 9.8A continuous rating and a 14.7A non-continuous (“temperature-limited”) rating. This means you can use it at 14.7A as long as the cell temperature does not go over 60°C/140°F…
The capacity of the two cells I tested was 4978mAh and 4979mAh…
vapcell Dennis
Both Samsung 50g and 48x currently come in two colors, gray and green
The figure below shows the complete technical table of 48x
ryansoh3
ryansoh3's picture
Last seen: 2 days 23 hours ago
Thanks for the tests Dennis.
In the datasheet above, does anyone know why it says “Avoid direct wind” in section 3.1 and 3.2?
On a different note, too bad the datasheet doesn’t specify either the 4.15V -> 3.0V capacity or the cycle life at 4.2V -> 2.5V
BLF ≠ B-grade Flashlight Forum
Blggg
Last seen: 18 hours 58 min ago
Hi Dennis,
Do you have a datasheet of the G50?
vapcell Dennis
Thank you very much for your information sharing Wink
vapcell Dennis
50G datesheet
Blggg
Thank you.
