Received this yesterday from CNQ along with the F12. I'll save the F12 for another thread.
First off, my photos do not do the copper color of this flashlight justice in any way. If you want to see the true color, please stop by Ric's website. http://www.cnqualitygoods.com/goods.php?id=1542
This is a beautiful flashlight and properly built for heat dissipation. It arrived very well protected in bubble wrap and in mint condtion with the lanyard already attached. I wasn't sure how much I was going to like the looks of this unusual design, but after seeing the amazing color and how perfect the anodizing was, I had a huge smile on my face from that point on.
Size comparision to the Skyray 3800 on left, and a Stainless Steel Cree on right.
Business end shot.
2x18650 configuration
1x18650 configuration
The reflector actually unscrews from the bezel, and takes quite a few turns to remove it, but doesn't aid in heat dissipation. More on this below.
Threads are very good, just need a bit of lube. O-ringed on both ends and of the correct size.
One great detail I liked was the fact a black plastic cover (removable) is placed over the LED protecting the solder connections from being shorted out by the reflector. The reflector actually contacts this cover, so without it, you would be assured of a short. I recall BLF member, Kramer, needed to make a protective piece similar to this for his Ultrafire HD2010. Glad to see the K8 already has it. Nice touch CNG.
Pill screws deeply into the main body and makes great contact.
The base has a flat top contact, but is mounted to a gold spring, so using flat-top or button-top batteries is fine.
Self explanatory photo.
Big Head K8 on HIGH. CNQ builds these to order. This is the 3-mode, XM-L T6-3C in NW Tint and rated at 900 lumens.
The Big Head K8 is a thrower. It has a bright and tight hot spot and dimmer spill.
Using a 2x18650 configuration with Redilast 2900's, tail readings were as follows:
HIGH - 1.24a
MED - .29a
LOW - .04a
UPDATE - I couldn't figure out why the tail readings were so low on this light, yet the beam was so bright. Using the tail readings enabled me to calculate input power, less any losses to the LED, and everything made sense.
9.92W / 3.3V = 3.0 Amps
Switching to 1x18650 with Redilast 2900 tail readings were as follows:
HIGH - 2.30a
MED - .55a
LOW - .07
2.30A * 4V = 9.2 Watts
9.2W / 3.3V = 2.78 Amps
In spite of the difference between one and two battery configuration, there was no detectable difference in brightness.
Beam shot of another thrower, the FandyFire HD-2010. No 26650 cells yet, but it was running on an AW-2600, 18650.
Wow, was this one putting out a beam with a tail-reading of 3.30a+ on HIGH.
