Pics of your build please
Nice…love the purple board goodness!
More bad news. I moved the components back to the stock PCB and they function in that configuration. This appears to be a layout issue.
EDIT:
I’ve reviewed the layout again (of course I looked closely yesterday as well!). (See post #41 for the layout) I do not see any problems. Sense trace is short & thick, gate trace is about the same as the DX board. LDO cap is a long ways away but shouldn’t matter? Input smoothing cap is very close.
So I’m going to put the components back on my PCB again.
Good luck, fingers crossed
Still no luck. I got the same results as the first time I populated my PCB - low current at low voltages, higher current at higher voltages.
I tried:
- removing the cap on LDO (greatly reduced current)
- input voltage = 5v & strapping the DIM pin to that instead of to LDO (no real change over using LDO)
- moving my GND point next to the FET (no change)
- leaving DIM floating again (no output this time. this pin is not meant to float, so this means nothing.)
Tonight I did some bone-headed experiments which really proved little to nothing. I killed both of the QX5241 chips which I was willing to sacrifice for now. I ripped the leg off of one and miswired the other.
I’ve ordered some more chips.
Wouldn’t it be nice if a flashaholic worked for one of the chip manufacturers and could sponsor our research. A few chips invested here and there to promote the sale of many more.
Much as I love free stuff, I’d rather get free advice!
Plastics…
As in invest in?
I preferred Harold & Maud.
I don’t think I’ve seen either, but “invest in plastics” was such a thing, it must have permeated lots of creative works.
Looks like I could move the QX5421 to the top if I also move the input smoothing cap and sense resistors to the top and move the diode to the bottom. If I did that I could make the DRV (gate) trace much shorter. I don’t see the length as the issue though. There must be some no-no that I’m unwittingly committing.
Sorry wight but I’m helplessly hoping here.
Bad news first: I still don’t have anymore QX5241 chips. The eBay vendor sent me AOZ1014AI instead. Hopefully I can get them to send me the right thing.
Good news now: I haven’t given up hope, so in preparation for eventually receiving some more QX5241 I’ve decided on my next troubleshooting step: a new PCB layout. I wanted to put the entire buck section on one side, so I stepped the size up to 20mm for now. Even with the extra 30-40% more surface area this was more of a challenge than I’d hoped. Therefore I sacrificed a sense resistor - the design is now down to two of them, at least for this 20mm test version.
I’d like to say that I did a ton of improvements, but I still don’t see any problems with the 17mm version. As far as I can tell my decoupling cap placement is great on that board. Maybe it’s the location of the Vcc trace. That’s my best hunch. Maybe when I get some more QX5241 I will cut the VCC traces on one of my existing 17mm boards and relocate the Vcc cap for testing.
Any way you cut it, this one is now super simple! I know the layout is a train wreck aesthetically. Despite my continued hope and effort, I’m nowhere near motivated to clean this up until I can get something to FUNCTION.
Please review. No aesthetic suggestions, only functional considerations, errors, etc please.
Good news #1: the seller did indeed deliver my 5241a chips on their second try! I’ve had them for several days.
Good news #2:
- I received the 20mm boards today.
- I built a 20mm board with a single R400 and it regulated fine at 0.5A output to an original-gangsta XM-L.
- I added an R39 in parallel to the R400 and the driver regulated fine at 1.0A output to the same XM-L.
I tried putting an R10 in parallel to the R400 but it seemed to go DD. The R10 was used so maybe it was fried from being soldered so many times. I will continue to work on this.
I have now tested with:
- (R100) = ~1.8A regulated.
- (R100 & R39) = 2.2A regulated.
R100 & R39 is the stock configuration of the donor board, DX SKU: 20330. As far as I’m concerned, the buck section of the 20mm board has completed phase 1 testing. I have not installed an MCU & support hardware.
What is the max amps you can push? I would really like one and drop into a Defiant super thrower and push it at around 3-4A w/ 2 18650’s or 26650’s
Most awesome man!
