[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
I have got a phone call from the shipping comany about the import charges and that the shipment will arrive soon.
I can wrap up to about 10 packs today. Book & Pay before 21:00hrs 22:00hrs GMT+7 for the 3rd round.
Reinforcement Lot no. 2 has arrived!
Round 3: Shipped
Chatika vas Paus - RR146459745TH
I pulled 3 random LEDs from the 2nd batch for spot-check.
Hereā€™s the light (appearance) test on 5500k WB and 2800k WB
https://imgur.com/a/5P4iLzH
Tracking numbers update:
Phosphor22 - LX054010845TH
e1000 - LX054010831TH
Kame Sennin - RR146459793TH
Received the package of 100.
There will not be a proper review until next tuesday (I will have enough forum chat time but there will be no hands-on cave time possible).
Quick first impression of one random led from the package:
*plenty bright
*very pleasant tint to look at
*very smooth broad beam (60 degrees from specs seem correct)
*edge of the beam a bit warmer than the rest (found it not disturbing)
*at ~20mA, middle of hotspot: 3325K, duv ā€“0.0039, CRI=97.4, R9=88.
Summary so far: great led :+1:
Wow! Sofirn should get some of these.
Many will be waiting for the review djozz. Thanks.
Any 7x emitter honeycomb arrangement host or flashlight out there for these? Hexagonal/honeycomb is the most dense arrangement, I wonder why it doesn't seems to be widely used.
How about this as a host? Itā€™s 0.5w though, so I donā€™t know if my LEDs would survive that.
https://www.aliexpress.com/item/32833777655.html?spm=2114.12010612.8148356.12.6afa51e8B6l2WJ
Received! Many thanks.
GREAT! :crown: :+1:
Iā€™m really looking forward to seeing the results of your testing. :smiley:
Re-posting this old Yuji mod just for ideas:
My first LED swap which didnā€™t require solder. In fact I only used a screwdriver, wire cutters, and tweezers:
I recently ordered some batteries from Shockliā€™s aliexpress store and they threw in some freebies with my order. One was this cheapo keychain light. It has a 5mm straw hat LED that is press to activate and has a tiny switch to ā€œlockā€ it on.
I bent and trimmed the legs of my Yuji 95 CRI 3200K LED
We have light!
I just now am realizing it had 2 stacked CR2016 batteries so I am probably giving this thing way too much voltage? Maybe a 2032 battery would have been more appropriate, who knows. I guess if it dies iā€™m out 55 centsā€¦
If you still have stock I woukd be interested in 1 pack as well. See the PM.
The CR2016 cells are 1.5V nominal, so two of them would be 3V, which is fine for a white LED.
I dont know anything about the cells but when I look at replacement ones on Amazon it says 3V nominal
Huh. Yeah. I just looked. Youā€™re right. Hmm. Curious thing.
I have used and gifted dozens of these small lights, all the white ones use 2xCR2016 and i have never seen a single one with a fried led.
These coin batteries have a high internal resistance so the voltage drops when you load them with a led.
CR2016 cells are ā€œ3Vā€, but their internal resistance is very high. Thus, 2x in series CR2016 cells drive a 5mm led well.
That and the fact that you donā€™t turn that on for a sustained period. Even if you overdrive these LEDs and degrade them way faster than their rated lifespan, you probably wonā€™t notice it.
CR2016 cells are indeed 3V. The ā€œCRā€ code denotes a lithium manganese dioxide chemistry, nominally 3V.
Alkaline button cells are 1.5V and are given ā€œLRā€ code. The typical form factor is also fatter and taller than lithium coin cells.
A pair of CR2016 cells shouldnā€™t be any concern, but because of the low forward voltage on the Yujiā€™s, they run pretty well on a single CR2032 cell, in my experience.
I havenā€™t done a controlled test, but Iā€™d expect you would get more stable output and significantly longer runtime out of a single CR2032 compared to a pair of CR2016ā€™s, although you might get higher initial output out of the latter. The massive voltage drop the pair of smaller batteries experience is in part due to a lot of energy being wasted on internal resistance.
Either cell does better at these kinds of loads with intermittent use (a few minutes at a time) than continuous use. Itā€™s surprising how much the voltage recovers when a load was removed in a test HKJ did:
