Hi, Im after a 1mm thick (any diameter) mcpcb to use in a no-name cheapie torch mod. It doesnt need to be copper, just suitable for an xpg/219 led. If you could provide a link to such an item, I would be a happy chap
Thank you.
Thank you.
I have a bag of cheap aluminium MCPCBs of various sizes you could have some or have a look here
https://www.fasttech.com/category/1611/diy-kits-parts-base-plates
I was about to post the same link as CRX. Here’s another option (Kaidomain). Most of the usual suspects should carry them.
http://www.kaidomain.com/c/371.DIY-Flashlight-LED-PCBS-LED-MCPCBS
Thank you, I did look at fasttech earlier, but could only see 1.6mm or thicker - must need my eyes tested!
If you can use a PCB layout program and want to wait till the shipment from china arrives at your doorstep.
Aluminium Metal PCBs are surprisingly cheap.
The Seeedstudio online calculator quotes 30 Dollar for 100 Boards measuring 15mm by 15mm and 5 boards for 25 Dollar.
The biggest cost is the initial setup.
Have some here I don’t need, 11,5mm diameter.
I can send them in a letter.
Just give me your address.
