Anybody tried this driver?
Good question.
It should work for a 6V XHP LED since its 3V in and 6V out.
Here are the given specs (cut & paste from Kaidomain):
Input Voltage:
3V - 4.2V ( 1 Li-ion )
Output Voltage:
6V - 6.8V max.
Output Current:
2900mA - 3000mA max.
Mode:
Very Lo(5) > Lo(35) > Med(65) > Hi(100)
Hidden Strobe: Double Click
Feature(s):
Constant Current, No PWM
Low Voltage Warning:
When voltage is below 3V, it will keep flashing. -
Memory function : ( > 3 secs)
Note:
- The driver does not have battery reverse protection. Please make sure the battery is connected in the correct way.
- The max current from battery can be up to max. 8A, high drain battery is recommended for this driver.
- Better heat dissipation is essential for this driver.
Dimensions:
20mm ( Dia. ) x 1.6mm (Thickness of PCB)
x 7.5mm (Thickness)(including all component)
Note:*And that 20mm diameter board is where its weakness is. Won’t fit a P60 drop-in. Wish it were a 17mm board.
What hosts out there accommodate a 20mm driver board?
Convoy L2, Eagle Eye X7
Look like there already exists a commercial driver for this purpose! Though if anyone is interested, I also made a 6V 3A boost driver (oops note typo on silkscreen). But otherwise it's a same single cell boost driver designed for the XHP50 / 144 6V LEDs. It can also be easily modified for 12V out operation - will work fine as is due to constant current control, but will not be as efficient since the components were chosen specifically for 6~V out.
I suppose the only benefit over the stock driver is more programmability with a ATtiny84A on board as well as true 256 levels of constant current brightness adjustment and 92% efficiency at 3A 6V output. It also features 3 additional GPIO for mode select / E-switch button operation, mode memory, as well as temperature and voltage control. More features available also with any firmware of your choice ^_^
> EDC
http://edc-light.com/6a-boost-driver-for-dqg-26650_p0903.html
link is 404 Not Found
I’m sure eager to see y’all succeed with this, it’s beyond my skill level and I want drivers to make some 1-cell triple lights.
Looks great!
Note to self: Here is the latest thread on the boost driver as mentioned above. Looks like it will work with an e-switch too.
GXB20 Driver – Homemade Constant Current Programmable XHP50 Single-Cell Boost Driver
Just got my H1-A and H2-C drivers. Will let you all know what these guys can do as I play with them over the next few weeks.
