Thanks to emarkd I was encouraged to open my brand new (more on that later) Zebralight SC30 and prepare it for the same emitter swap. However, I thought starting from the switch could help me to prevent the light from any damage. At CPF someone did so with a Zebralight headlamp, pulling the boot retaining ring with a pick. Well, I wasn’t really successful, as you can see…
So I cut away the whole cap and desoldered the electronic switch, in order to use a screwdriver as a lever.
It was quite easy then to pull the ring, but some minor marks were left.
I could lift the switch PCB from the right site, but I destroyed one of the solder contacts. The cable could not move at all as it was soldered to the MCPCB for no obvious reason.
Now I used a screw driver between the MCPCB and the reflector to push out the lens. This caused some damage at the base of the reflector. Not dramatically, but hard to avoid.
Desoldered the wires and lift of the MCPCB. No thermal paste here as well. Did you note the alignment of the screws? I have never seen this on another board, so you cannot just throw in a normal 10 mm one…
Ok, my conclusion is to sacrifice the lens and not the boot cap, as this is not a regular spare part. Luckily, Zebralight will help me here and promised to send me one (thanks a lot, Zebralight!). The lens has a diameter of 18.5 mm (diameter of the light opening is 19 mm) and a thickness of 1 mm, so one of these lenses should fit:
https://www.fasttech.com/products/1606/10001022/5422700-18-3mm-ar-coated-glass-lens-for-led-flashlights
http://kaidomain.com/p/S024571.18_4mm-D-x-1_0mm-T-AR-Coated-Lens
http://kaidomain.com/p/S021958.18_6mm-D-x-1mm-T-AR-Coated-Lens-1-pc
You avoid desoldering the switch and the potential of destroying the PCB and the reflector, as evything can stay in place.
Hope that helps. I will give you an update as soon as I have sourced a new emitter for the light.
