Ahh, I see. Thanks for the info and for the emitter gallery. Very helpful and now I know that I have the Nichia indeed. Had I received the paper manual as pictured on the BG website, I would have noticed the 5000k rating, but I didn’t look that up until after your post.
Wow, I got my Nichia version today… It is better than I expected, the solder on the MCPCB for the LED wires is ok. The screws look good, I can even see some thermal compound under one leg of the optics where it oozed out.
The only gripes I have are the tiny lanyard holes and the clip location. The actual clip is pretty nice, but rides a bit funny with the tail on the head. A new convoy clip makes it a deep(ish) carry on the last groove of the tail cap.
UI is good (as always with TK’s code). The finish is better than the BLF A6/Astrolux S1 on mine…
Now, question of the day for me is: do I swap in two 219B V1 4000K, or go all in with 219C’s?
For now I will just leave it alone and have some fun with it…
That’s why I’m hoping for a host version. I’d like to leave mine how it is, and have a host to do strange things with. Who knows what the possibilities are.
I was tempted to replicate my wide-spectrum BST in smaller form with the S41, giving it four different tints of XP-G2. Might be nice to have a smaller wide-spectrum light.
If you’re changing all the emitters anyway, it might be a thing to consider.
(be warned though, it may not be easy to get the tint mixture right)
I’m not familiar with the ‘wide spectrum’ approach using different led tints… but aren’t high CRI emitters exactly that - so no point in building a wide spectrum setup?
Nope. High CRI means the curve closely approximates the bell-like curve of a pure blackbody radiation source. Wide-spectrum is what happens when you take that curve and stretch it out sideways. It basically makes the edges brighter and the center dimmer, which produces artificially-vivid color rendering. It looks like what happens if you use a “vivid colors” filter on a photo, only in real life.
The main downside is that having different tints from different locations tends to produce rainbow-colored shadows. The edge of a shadow gets different tints at slightly different angles, so it ends up with several overlapping shadows of different color. But on a quad like this, that effect should be minimized compared to the Blackshadow Terminator I used.
I put in a Efest 18350 900mAH protected charged 1 time it read 3.9 when i put it in the light. It worked great.
I attatched the 18650 NCR18650B 3400mAH protected brand new fully charged and it did not turn on. I flipped the tube and tried it again and it worked. Same thing happened with the 18350.
I then fully charged a brand new Efest 18350 900mAH and put that cell in the light. It turns on but when i get to the highest or last half click it flickers off. After it flickers off i give it a half click and it goes to the last mode right before the last half click.
The same thing happens with the 18650.
It also flickers on and off when i tighten the tail cap when putting the battery in.
As im typing this i just put in a Fenix ARB-L2-2600 Protected and it does not flicker and turn off like it does with the NCR18560B cell.
I am not a modder and dont know alot about the internals of lights and i am new to flashlights.
I don’t want to sound like an impatient turd, but I’m just curious if anyone knows about how long it will be before there is a coupon code? I’m having a hard time not jumping on this (even at the full price) and am wondering if I should hold off a bit longer. Any ideas?
