So, is what you wrote before still true (that you can use any charger , provided that its 12V and enough amps)?
I think yes. because usually, and i mean usually....12V PSU have + inside, and 5.5x2.1 barrel plug, i mean ...also the Infrared floodlight i use outside my house for my surveillance system has them. Also any generic outdoor AC to 12VDC have the same plug, also if you take a look at any oem generic chinese IP (non POE) cam they have it too...let's put it that way: it's difficult and rare to fall on a different plug...albeit still possible . regarding MY chinese buying experience...
instead buying a crappy PSU declaring 5A and really not pushing more than 0.5A is more than probable...my worst 12v psu is an aliexp LX1205 which behaved exactly like i just said.
You are correct.
Most of the 12v power bricks I have come along use the same plug type that the Lii 500 has.
Either way, I have a code for the Lii 500 US coming in a few hours!
Can you please request code for these boxes:
https://www.gearbest.com/led-accessories/pp_582741.html?wid=21&lkid=12792408
Last time code did not work or I was too late.
Thank you.
Active codes
25/1/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS
C8 ordered, thank you :+1:
Interesting 6-port USB charger, but I can’t tell if it’s 3.5A max total, or if each port can simultaneously deliver 3.5A (21A total).
In FAQ section is this answer:
Yeah, I saw that, but then what is the total output for all ports combined?
EDIT: OK, found info on another website. It looks like it’s 6A max for all ports combined.
code is not working for S2+.
Also, any code for C8 but in 3A tint?
gregor:
The maximum current that one port can out-put is 3.5A.
It is not making a toal of 20A output.
That sounds like a more reasonable power output estimation.
The actual reason why I requested a code for it was due to its nice appearance ![]()
It looks like a bench top power supply!
The code does work, bilakos told us before he does not have acces to a PC and he does everything with his smartphone, so I can imagine it is hard to write down in a tiny screen.
I just bought the S2+, just put one s less like all his codes.
bilakos, thanks for the code!, thanks to your codes I ordered my third S2+ tan now ![]()
The correct one is:
Convoy S2+ CREE XPL HI 3000 - 3200K 840Lm Flashlight
$ 12.99
bilakosJ166
The code bilakosJ170 doesn’t work either.
KuoH
Pete7874:
gregor:
The actual reason why I requested a code for it was due to its nice appearanceIt looks like a bench top power supply!
I have a smaller 2 port like that I use with my raspberry pi. Quite handy to monitor what is going on with it
mikeymikey:
I just bought the S2+, just put one s less like all his codes.bilakos, thanks for the code!, thanks to your codes I ordered my third S2+ tan now
You are absolutely right.
Doing everything from my mobile is quite difficult and mistakes are made.
If anyone is interested, the code for the S2+ Sand is bilakosJ166
SpAwN:
mikeymikey:
Doing everything from my mobile is quite difficult and mistakes are made.If anyone is interested, the code for the S2+ Sand is bilakosJ166
First time customer here. If I am ordering multiple different items on one order, can I use multiple codes?
Thanks.
Hi Bilakos, can you add the code for Eagle Eye X2R 3C please? Thanks.
Can we please get the code for S2+ Sandy brown 4c tint?
That sounds like a plan.
I will include it in my requests for Monday.
< /a>
