*BLF LT1 Lantern Project) (updated Nov,17,2020)
Image below shows what type of chargers that will work, ( any USB charger that has the standard larger common USB-A socket) and the type of charger that will not work (the ones that need to use a type-C to type-C cord on both ends)
Hey Den, did you know of a source to get some high capacity 18650s in Canada for a decent price? Everywhere seems to be around or over 50CAD shipped for a set of 4, is that about what to expect if not ordering a large bundle?
I recall you mentioned something about 18650canada a while back and those are the figures I’m getting from that site for 4 Sanyo NCR18650GAs.
Could you point to the location(s) where a resistor may be effectively installed?
Does this completely activate the full USB-C function? Or is more change required. Like a new chip.
@ dbsar
@ lexel
Are you sure about the pull up resistors?
Can someone point Lexel to this page? Tabelle 3.02
https://kompendium.infotip.de/usb_power_delivery.html#Kap3.5.1
It is in German.
I would not vote for full USB-C support
USB-C stuff is quite complex to implement. You need to know all this stuff:
  • USB 2.0 Spezifikation (April 2007)
  • USB 3.1 Gen 2 Spezifikation (Juli 2013)/USB 3.2 Spezifikation (September 2017)
  • USB Power Delivery Specifikation, Revision 2.0 (MƤrz 2016) / Revision 3.0 (Januar 2017)
  • USB Billboard Device Class Specification, Revision 1.2
  • USB Battery Charging Specification, Revision 1.2
Do you really need USB Power Delivery for the LT1? The 3A or 1.5A on 5V should be enough.
But I am not an USB expert
Joe
If I understand this discussion correctly one would have to cut traces on the PWB in order to install the 5.1k ohm resistors. A new chip is not required. Depending on how the board layout is, IMO its not really possible for someone to make the necessary change on a purchased lantern without seriously risking damaging the lantern.
No.
True, but that still requires resistors. By default (without resistors) there is no 5V coming out of a USB-C charger.
Nice BLF family photo with the GT peeking between the Q8 and LT1! :+1:
I think this is the first time I’ve seen the LT1 next to a Q8. It gives a good idea of size, even after seeing all of Den’s videos of the LT1.
Are the 600lm from the manual are for all 7 or for the 5 soldered?
For genuine cells here in Canada, i buy all my Li-Ion cells from https://18650canada.com even though it seems that we pay more, ( due to our weak CAD) its still not bad as other prices are in USD elsewhere.
Last first - No. There is no way to support the full USB-C spec in the LT1. It will not fast charge, will not function as a power bank, or support any of the ā€˜fancy’ USB-C features.
Where the resistor goes… I hate to say it like this, but sometimes blunt is the best kind of answer. If you have to ask, it’s probably not for you. This is not a simple ā€œConnect pad L to trace Gā€ process.
Now, in case you are qualified, lines CC1 and/or CC2 from the UCB-C connector have to be separated from ground and a 5.1k resistor inserted. This is delicate surgery, and currently untested on the LT1 driver. While some here are undoubtedly qualified to do this, most of us aren’t.
Some folks have managed to do this with the Raspberry Pi 4, so it’s not impossible. It is, however, risky enough that I’m not going to give any instructions that may lead to someone trashing their LT1.
For the majority of us, using a USB-C to USB-A (female) adapter between your USB-C charger and USB-A to USB-C cable (supplied with the lantern) is the best answer.
To make the LT1 full USB-C support will probably add cost, and not worth for just the some of compatibility with a odd few type-c chargers, (honestly we could have saved cost if we had stayed with the plan to use the standard USB Micro plug interface, which that interface is still going to be around for a long time yet. We only went with the USB-C plug because a few members kept pushing for it, which ended up making things more expensive & complicated, (and this petty issue with the complaints of some type-c port chargers not working could have been completely avoided, AND saved cost & time by going with the still far more popular micro plug as originally intended. :person_facepalming:
Folding lamp shade for the LT1
Finally found a white one, colored is no problem on Ali.
only the hole in the bottom is missing :scissors:
US $1.75 25%OFF | Silicone Dog Bowl Silicone Folding Travel Bowl For Dog Pet Cat Food Water Feeding Dog Bowls Pet Accessories 1PC
https://aliexpress.com/item/33039973165.html
:+1: That is the exact one i used for the folding lamp top shade in the Youtube video i did. :smiley:
If only mailing these to CA wasn’t such a royal mess. :person_facepalming:
What percentage of packages do you think Canadian customs would inspect and confiscate?
Nah - ignore that. I’m not up for risking my money, and I don’t want to risk your money either. (or get put on yet another list)
Did you cut the black ring off, or did you get the one that’s out of stock and might have been plain white?
Yes, I know it is more complicated. But Sovirn will sell the LT1 for a few years it is worth the trouble. That’s the normal hick up with the first batch of products :wink:
But can you point lexel to the table? It seems we need other values for 1,5A charging current.
(also this USB-C page is a good read for an electronic guy)
Thank you
I’m so confused. I’ve received no messages yet, but it appears these are ready to purchase. Where do I go to claim mine?
No, I just ordered one of the plain white :slight_smile:
For the last days I found only colered ā€œfolding bowlsā€ on aliexpress, so I thought others have the same problem. Probably because I didn’t search for Dog Bowl.
From how it looks it seems to me that a USB-C sockets, being wider, are more robust than micro-USB sockets (correct me if I’m wrong). Since I have experienced two broken-off micro-USB sockets already in flashlights and one in a charger (almost unrepairable because it required reflowing them back into place) I’m a fan of USB-C, even if it does not have more functionality than micro-USB.
It’s not ready to purchase. You have to wait like the rest. The ones you see were part of the 1st 500 batch release. Sofirn is controlling the messaging.
