How well was it heatsinked? My father has been running his UF-T20 with a dedomed R5-1A at 4.5A with a 20R for almost a year now, and I know that he uses it a lot--sometimes for several hours a week.
It was pressed down with the reflector and screws. I use Arctic MX-2 on alu pill. It got hot really fast with the other 3A driver so I think it transporting the heat really good. Maybee I got a low vf led. The best I got with XM-L2 and this driver was 3.6A I think. I think I have tested 7 XM-L2s with different tints. I will try again with 2 less 7135 and 20mm board when I get one. I throwed in my best 3.6A XM-L2 again.
That's still bizarre, because theoretically with a 7135 driver the LED's vF shouldn't matter in determining peak amperage as long as you have enough voltage overhead to maintain regulation.
I´m just in the learning fase and messure everything I can.
I just tested 2 leds again in direct drive with the panasonic, and there are quite big difference.
XM-L T6: 3,45v 5,25A XM-L2 T6: 3,67V 3,86A
It´s not the easiest thing to get the XM-L2 to go over 4 amps as it is now The other one I get over 4amps with that driver before the battery sags.
I have ordered 3 new batteries (LG 18650HE2) that seams to fit my use upp to 5 amp and runtime.
Probably with a spectrometer. You can make a cheap one using parts from publiclab. The red emitters make a nice, clean spike in the color spectrum.
Edit: Here’s the red XP-E2 reading I took with my cheap spectrometer:
Ah spectrometer, completely forgot about that, I’ll see if I can build one that would be acurate and cheap
Wait a sec, you’re cheap spectrometer has a PC output (RS232 or USB output)!
How about making a thread about building a spectrometer that you made, I bet there will be interested people
It’s just the default PublicLab spectrometer kit. I haven’t even bothered upgrading its slit and recalibrating it yet.
For measuring white LEDs, it’s surprisingly sloppy. Mostly useless, actually. The spectral curve changes dramatically in response to even slight changes in angle or positioning. So, it’s more limited to measuring narrow-band light sources like a red LED, or finding narrow spikes within wide light sources like a CFL bulb.
I had hoped to be able to measure color temperature and CRI, but it’s nowhere even near accurate enough for that.
Some of my friends like there C8 and asked, if I could get some more power on these, but they prefer a long runtime on high.
Could anyone give me an advice, how much Ampere could be possible without killing the LED. Two wants a XM-L2, one friend a XP-G2.
Host: Convoy C8
Runtime: 20-25 minutes on high
LED: XM-L2 and XP-G2 on copperbase, dedomed
Which rate is conservative, which one risky.
At the moment they have alu based LEDs: XM-L2 U2 1A and XP-G2 R5 (maybe 1A). I will dedome these, too.
How much Ampere would be possible on these (for a runtime of 20-25 minutes on high)?
With a good battery( 25r, he2 or vtc5) you`ll be able with sqeeze 4,5 + amps from a U2 1A emitter on a Cu MCPCB and a fet driver, and yes its safe
XPG2 you can drive safe enough up to 5.5amps
Using that setup the runtime would be arround 40-50 mins till the protections hits
https://publiclab.org/wiki/spectral-workbench-usage
SpectralWorkbench.org is a web-based software suite for collecting spectra, using your Public Lab DIY spectrometer.
https://publiclab.org/tool/spectrometer
up to v3 now, being improved (somewhat sporadically, so if the web interface seems odd, look around for info on the status)
Using this one for already 2 years, its quite reliable, user friendly and not that spendy as other pro spectrometers: it could be fount at a very reasonable price, its portable and quite easy to carry
Thank you Mitko. I got 4 LG HE2 a few days ago. Maybe I will buy a few XP-L high, instead of the XM-L2.
I will strip an old driver down, make it direct driven and try an Panasonic NCR 18650B and a HE2. If it takes 4-4,5A it's ok. If not, I will order new drivers, too.
You can try this driver Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modi Taschenlampe Treiber Sale - Banggood Deutschland-arrival notice-arrival notice
Noticed this yesterday and was a little bit confused (know it from mtnelectronics for a higher price). After this I find the BLF "driver" thread with the posts of Toykeeper and others.
Now I have to wait, because it is out of stock, but this is ok, because copperbased LEDs are ordered, too (mtnelectronics is also out of stock).
Im loving my Thorfire C8 that I won a while back. This thread makes me want to mod it. Maybe Ill just get another host to mod. Which C8 hosts have the best heat sinking abilities? or are they all the same? If they are all the same Ill just get an Ultrafire C8 for about 9 bucks on amazon just to mod.
But…
Do I really need anything brighter living in the city? lol
YES!
Just put in a XP-G2 for the first mod…
Get the dedome option if you want, but this is a great, budget upgrade.
A Qlite flashed with Guppydrv is nice too, so for less than $10 it is a much better light.
With the XP-G2, use the XML centering ring, it will work for the smaller LED.
It's all good and bad - good because of China pricing for parts/assembly/distribution, bad because of China quality (and availability apparently). For me, it's about even in cost of parts but I like my quality of build better. Anyway, this driver is obsolete the day it went up on their site - Tiny25 and Tiny85 based drivers is the way to go for TK's latest for Tiny25 power/tail switch lights (bistro), and my latest firmware for Tiny85 based drivers.
We need a review!
http://www.kaidomain.com/Search/SearchResult.c8.2
KDLITKER C8.2 Cree XHP50.2 White 6000 - 3000K depending on LED, 2600 Lumens 5-Mode LED Flashlight - Black ( 1x18650 )
Our Price: $29.93 free shipping
Brand: KDLITKER
Model: C8.2
Flashlight Material: HAIII Hard Anodization Aerospace Aluminum
Flashlight Color: Black (Matt finished)
Emitter Brand/Type: Cree
Emitter BIN: XHP50.2
Color BIN: White 3000-6000K
Total Emitters: 1
Battery Configurations: 1 x 18650 rechargeable Ii-ion battery (not included)
Voltage Input: 3V - 4.2V max
Switch Type: Clicky
Switch Location: Tail Cap
Modes: 5
Mode Memory: Yes (Stay the current mode for more than 3 secs)
Mode Arrangement: Very Lo(5) > Lo (35) > Med(65) > Hi(100)
Hidden Strobe: Double click
Circuitry: Digital Regulated 3000mA Current Output
Brightness:
Runtime: Hi Mode: 40 to 50 mins (manufacturer rated)
Med Mode: 2 to 3 Hours
Lo Mode: +10 Hours
(Tested by KDLIGHT KB3500 3500mAh 18650 battery)
Lens: Multi-Layer Coating Glass Lens
Reflector: Aluminum Textured / SMO Reflector
Carrying Clip: -
Carrying Strap: Yes
Other Features: 1. Constant Current
2. Low Voltage Warning: It will keep flashing when the voltage is below 3V.
3. Waterproof Standard IPX-6 (Underwater 2m)
Dimension: 140mm (L) x 44mm (Dia. of Head) x 26mm (Dia. of Body)
Weight: 155g (not include battery)
Package Content: 1. 1 x KDLITKER C8.2 Flashlight (with package box)
2. 1 x Lanyard
3. Spare O-ring and Tail Cap
I need that driver!
It’s hard to believe a stock light would do 2k lumens with no step down from a single 18650 - the kf8 kdiy is similar and was tested as being truthful. What’s the likely kcd on this?
