I would suggest coating lens on only one side. I have bunch of HI CRI emitters but all of them in Convoy hosts have higher DUV, more yellow /green than they are in other flashlights.
I have S2 reflector in custom host with only one side coated lens but the beam is beautifull with Nichia.
219B.
on the other hand having the same emitter in S2 with the same reflector gives more higher DUV beam.
Not really a deficit going to the larger die led. Like Obewan said, the 2mm2 emitter is more useful for everything but lux and throw. The smaller emitters beam is so narrow and the hotspot so small up close. The 2mm2 is much more useful in terms of side illumination and general usefulness.
DRIVER is already in its own section and that’s good, easier to search/navigate/compare.
I guess it’ll be great if MCPCB and LED have its own section, they’re very closely related components.
What about arrangement like these categories/sections:
I took the glass lens out and feel the same with LH351D 4000k. Not sure if that is just in my head or not. I will try this with some SST20 and Nichia219C when they arrive.
AR coating effecting tint happens more often than not to varying degrees but i’m not sure what makes one manufacturer’s coating better/worse than another.
It’s not typically enough to make a bad LED good but it can certainly make a great LED just ‘good’ or an average LED not so good. In fact for some lights I have 219b sw45k I leave crappy AR lens in place because it’s already too pink anyways.
And why should you be? A feeling is a signal about something, and unless we are being energetically manipulated or under the effect of some @#$% drug (which involves interaction with unseen negative entities), better pay good attention to it. Also, comparing ourselves to others usually is bad, namely if it involves judgment.
I also see no point in anti-reflective coatings; they mess up with tint for nearly no gain in output.
Thx Barkuti. Found that method last night, tried this morning no luck. I soaked the lens in nitro thiner for 30min, acetone and glass cleaner and i couldn’t even leave a mark on the surface. Convoy AR coating is heluva tough.
