Mark, thermal performance of the mcpcb seems to be just fine, the XP-G3’s put it to a pretty good test as they really put out a lot of light and heat.
But, alas, I have killed DBC-02.
One of those scenarios where you try to fix/improve one thing and it leads to another which leads to another and things didn’t work out. My Bistro driver wouldn’t work in moon mode, so I went to build a new driver and found my brass retaining ring not fitting snug when screwed down to press the driver in, so I thought maybe ground was an issue. I built the new driver, and a new brass retaining ring, and put Nichia 219C’s in it. All was well except the new driver was doing the bump to moon when trying to hit Turbo thing. Yuck! So I tried again with the brass ring by boring the dual piece copper pill for a Ti battery tube and that failed, the tube is too large for the inside copper piece and ruined the pill.
SO, I made a new one piece Tellurium Copper pill, a bit larger in diameter than the Titanium bezel and with the Ti battery tube threaded into it, and a Tellurium Copper tail cap. Ultimately I went with 4 XP-L V2 1A HI’s in this one and built yet another driver with the A6 firmware and ATTiny13A for reliability. Still doing something around 2200 lumens off the little 18350, still with a Cutter quad mcpcb and Khatod optic.
Guess it’s now DBC-04, as 02 died. lol
The battery tube is made from welded Titanium Grade 2, 1” in diameter with thin walls. So it’s larger inside than the 18350 cell. I made an insert from black Delrin so the cell fits nicely and doesn’t rattle. Sorry for the low pic quality, been a long couple of days in some intense heat, I’m bushed. Met with some frustrating turn of events doing all this, found I still have a 1’ long bar of 1 3/8” diameter pure copper that is unusable… it’s full of hard/soft spots that either resists cutting and gums up, really ridiculous but it just won’t machine. The Tellurium Copper is so nice, shame I have to make a boat anchor of this bar of pure copper, totally sucks. Spent way too much time and effort trying to force it to work, changing inserts, from sharpening HSS to using new carbide, just flat wouldn’t cooperate.
I’ll probably remake the head for DBC-02 and revive it, not interested in messing with it in the heat we’ve been having.
