Thank you, WarHawk, for the answer!
And here we go: as a can understood, I can consider these batteries lost money. If it’s correct, I’ll search for good ones, max 3.200mAh. We don’t have many choices in my countery but… some brand to indicate?
And I understood that I can’t join the output of the 2 XL6009. Can’t I do that even using a diode to be sure the current of the outputs don’t “reflow” between them?
Well… as I saw around, in Internet, some people uses just one 18650 to feed PAM8403, and it seems ok. So, if it’s confirmed that I can’t link the XL6009 in parallel (as I can do with other regulators like LM338), I will unjoin these 2 XL6009’s outputs. And as the chinese player tooks something like 200mA, I can use the player’s TP4056-18650-XL6009 to charge cell phones. The other TP4056-18650-XL6009 will be exclusive to PAM8403.
The device you show (a charge manager and a stepup device together) I think I can join my TP4056 and XL6009 and use this. I don’t know if you can see in your country but the EBay link you sent say they don’t send this board to Brazil. Actually it’s not that easy to buy things from other country on line, via Internet…
Almost last, the charge manager I have is not quite equal the one in the picture I’ve send, wich have just one chip. Actually the mine one have 2 outputs (there is not else references but the number 03962A in the board and it have not just one chip in there but 3 chips: TP4056, itself, DW01A and 8206A). The output’s indication is, one for the battery and the other… well, you say I can charge and use at the same time, I imagine that the second output is useful for that. I’ll try, let’s see.
And very last, if I’m not boring you, what do you think to use an electrolitic capacitor, say, 1000uF (16v) in line with the PAM8403’s power circuit? I say that because a flashlight demand current continuosly (and that the battery can hold) but the amp is a PWM: as far I read around, if the volume is low or the music is only treble tones, this amp asks few current. But if one up the volume or if the sound is bass, the amp asks for more current. Do you recomend this capacitor or it could be dismissed at al?
Thanks again.
