It appears (unless I misread) the gearbest version is different to the CQ version? Thought I would grab one anyone to try out… 2am here sorry if I’m not paying attention. Doesn’t matter if no momentary, but clicky works? on/off? change mode on tap?
Definitely not a clicky in the conventional sense. Like others have said it’s more a squishy/pushy/spongey. Terrible feel, like nails on a chalkboard to me.
Mine has next mode memory for a couple of minutes.
Didn’t come in a bag or plastic or a container. It was just a bare light in the padded shipping envelope. The light came with a barcode stuck to it that I had to peel off and then clean away the glue residue left behind.
I'm not to sure I have 8 Trustfire Black 10440 form fast tech and only a few work because of the button top are not that long, but they have protection, so you do not really have to worry.
I think it's better using AAA batteries, sure you get less light but you don't have to worry but battery drain on the AAA. I will check when I have time.
Dario you only have 1 post and it recommends a light from Banggood. You have no other posts do you have this light from Banggood, If so what are you experiences?
Not intentionally. In the other post somebody asked specifically about this light and I responded after seeing nobody else do so. I don’t have this light. I have the one I suggested as an alternative. I have no interest in Bangood - it doesn’t matter to me where people buy.
I’m new, don’t have a ton of experience with flashlights, and am trying to give some feedback on a light nobody else seems to have.
ok. These look far more similar to me than different. AAA stainless clicky. 2.54” vs. 2.76” - I get that this one is smaller. I just noticed that this one seems to have glow-in-the-dark. This one takes 10440, the one I have doesn’t.
I’m not seeing that much difference. I’d be happy to be educated on what I’m missing.
What how 2 is getting at, is not that the 10440 won’t fit, it will,but that the the light you linked to can’t handle the higher voltage of the 10440 battery (4.2volts) it will burn out the light
Just to add, if a aaa light can handle the higher voltage of a 10440 it will be much much brighter
I get that - I know my light can’t handle the voltage of a 10440.
This light is rated at 60lm. I assume that’s for AAA? What is the output with 10440? The light I have won’t take a 10440 and does 140lm with a AAA. If this one is close to 140lm with a 10440, what’s the real difference between the 2? Or are you expecting significantly higher output with a 10440? 200lm?
