I would like a board for my mt03. Running narsil. Let me know where we go from here. Thank you.
Tracking | UPS - United States
Track one or multiple packages with UPS Tracking, use your tracking number to track the status of your package.
Send today your driver and for 4 other people spreadsheet is updated
did ship today again some drivers
some People ask me if I may have a driver left, yes I got lots of em waiting for you
here the workflow on new Seeed boards
left 10x10cm PCB already drilled,
then cut them to 4 pieces, usually here use stencils to apply solder paste
next boards cut with side cutter in rough shape
now grinding them with a Dremel and 12mm sandpaper head
some boards are partial reflowed, so Narsil or Bistro parts added later
last step fully assembled boards ready to flash and test
a normal order from Mouser
Just a little comparison from BLF MF02 Inductor with stock driver ones
I finally got one of my L6’s built w/this driver and love it.
Now for a couple clicky versions for a friend and I’s Z1 zoomies.
3) 22mm, 2S for 6V led, Bistro HD, shipping w/tracking
……no wires or springs
On another note, does anyone know if Dr.Jones Lucidrv2 will work on these boards for a clicky firmware ?
I have several of the H17F drivers with that firmware and like it a lot for clicky lights.
Jim
depends on the pinout
Indicator pin 7
FET pin3
1 AMC pin5
bank of AMCs pin6 this will not be used
of course rewiring possible to match the output channels, just lift the particular pins in the air on assembly and route small wires
Thanks for that info Lexel, but nope, not that big of a deal.
Bistro HD is a good UI. I have just got so many different UI set-ups going on lately, it takes a second to remember what is in the one in my hand.
Anyway…….
When you get the chance, put me down for
*3) 22mm, 2S for 6V led, Bistro HD, no wires or springs
and
1) 26mm (sanded 30), 2S for 6V led, Bistro HD, no wires or springs
shipping w/tracking + insurance *
$62.30 + $7.40 shipping and ins Correct?
Thanks
Anyone already modded a Lumintop SD26!? I wonder if it’s possible to change a driver and keep usb charger?
Credit image: WillyD Review: Lumintop SD26 XP-L 26650 USB Rechargeable (discount code available)
If the charger is self contained, it could be done. You would probably have to design a unique driver board to accept the charging board on top.
Pilot dog did that with the Eagle Eye x2r light.
That SD26 driver looks like it carries the switch and emitter wires on the charging circuit. It looks very difficult.
Do you have any 21mm if you do i would like a Narsil m, 1s,60c,PO-2B,SD-2.8.
That’s unfortunate my skills are very limited maybe next time
VW Pieces added an new charging pcb to a Lexel driver, but he swapped to a magnetic charger plug and was a lot of work also.
Let’s hear what Lexel says.
plenty 21mm boards
Received mine, fantastic !
Now my JM70 is a true thrower with nice UI !
Thank you Lexel !
Lexel, would you happen to know what kind of power limitations the TA driver has?
I know a 6v version can handle 20 amps, but can it handle 30 amps, 40 amps?
6V version may have at 30-40 Amps the problem with blown AMCs
the SIR 404 FET can handle 60A when solder point is up to 135°C hot
0.155mOhms at 3.5V
pulse drain current is low with only 100A, a dead short can kill it
lately I changed to PSMN1R5-30YLC on the 2S builds partially,
because the 404 has its advantaged below 5V, but on 2S the FET always gets 5V
1.6mOhms at 5V
this one is rated 100A at 150°C solder point
with pulse drain current of 1000A
next FET will be Infineon replacing the 404, even better characteristics
lower resistance
100A @125°C
1.2mOhms at 3.5V
pulse drain current 400A
Hey lexel I’m interested in a 21mm thin board for a Skilhunt H03 with narsil and with spring attached.
Not sure if there’s any other info you need from me this is my first purchase through BLF.
Hello, I’d like to place an order for the drivers below.
2 - 30mm 2S NarsilM 60C, PO=(2B), SD=2.9v
2 - 21mm H03 with NarsilM defaults
OK for both orders
the thin H03 boards from Oshpark are on the way and already in Germany, hope they get here in next few days
Excellent—no rush. I assume you’ll contact me with an invoice at some point?
Ill get you contacted when I get the boards with PM
Of course it would make it easier if you contact me with shipping information and if you want tracking or not
I can also equip the drivers with resistors for side switch LED just need to know if you like it dim medium or bright
I have it on the to do list to make new pictures for the new designs how to connect them properly
