Flashlight Host and Uncommon Budget Flashlights
Not bad at all…
I have no idea what any of that says, but it looks tres kewl.
Whut’s with all the purty colors in the switch?
And where ya get one? :smiley:
It could make a good host for a boost driver and 70.2.
Look what I found on AliExpress
http://s.aliexpress.com/n6viEvQv
I found this flashlight on AliExpress that is 3 XHP-70, I’ve talked with them and this is what they sent me about specifications. —-Emitter:7070
v —Aluminum Alloy body with HAIII Anodize black surface Finish
v —Battery: 4x High Drain >10A button top 18650
v —Switch: Side electrical switch with big Transparent rubber boot
v —Aluminium OP Reflector
v Ultra Clear Double-sided AR coated Glass lens (99% Light transmision )
v —Double O rings; IPX8 Waterproof
v —With standard Tripod hole
v —Max Brightness:13000 LumensNW ;
v —Max Runtime: 58 days
v —Brightness Level: (Digital current regulation)
v Low Low: 10 Lumens (28 days )
v Low: 150 Lumens (35 hrs to 10% power)
v Middle: 1000 Lumens ; (480 minutes to 10% power)
v High: 2700 Lumens (250 minutes to 10% power)
v Hidden moonlight: 0.6 Lumens ; 58 days
v Turbo—13000lumens —–2.5 minutes (thermal control) step down to
v 6000 Lumens—–2 minutes (thermal control) step down again to 2400
v Lumens (300 minutes to 10% power)
v Overclocked descent55 degrees 2.4 A-2.6A
v 6000 Lumens55 degrees 1.4A-1.6A
v — Timed Temperature stepdown and thermal regulation
v Size: 135mm length x65mm Head x53mm body
v Weight:460 Gram
Ø User Interface:Single Click-on ; Single Click-off
Ø Hidden Moonlight (press and hold switch in off status; easy to access)
Ø Low Low-Low-Mid -High-turbo (Long press to change
Ø modes ; with last mode memory)
Ø Quick access to Turbo (Double click after you turn
Ø on the light) ; Turbo can be memorized.
Ø Click+hold+flash signal to lockout the light;
Ø loose the flashlight body to unlock.
Ø Switch LED indicator:
Ø 100~50 power: Blue LED on
Ø 50~9 power: Blue LED flash twice every 2 seconds
Ø Blow 9% power: The flashlight will flash fast and step-down to moonlight.
Ø The indicator LED will be off on Moonlight mode to extend the run time.
Ø Internal parts:
Ø 40mm Haike Copper DTP Emitter board
Ø 20 gauge thick copper+silver wires
Ø 5mm thick internal integrated emitter shelf
Ø double silver-plating copper-alloy springs
Ø Caution:
Ø The Turbo mode gets hot very quick!!!
Oh, so now they’re selling a discount MT03.
Nice.
Well, a very similar light.
Same light as https://budgetlightforum.com/t/-/37396/211
Powered by Haikelite
What is the connection to Haikelite?
Obviously the machining is very different from the MT03.
The price has now dropped to $55 with store coupon. If this a haikelite internals than this is a steal of a deal. I’m going to order one.
I ’d buy a dozen if I’d only knew how to order them. That site is like Chinese to me…
Aliexpress? I tend to use their app on my phone. It’s a lot easier.
Ultrafire version UF-1802 from GearBest. Use CA%LA704 coupon for 10% discount (above $10 order).
Nice but overpriced.
What is this above? I guess it has 4 18650 in it? Is it like a camping light or work light? How much is it?
freeme, that looks like the kind of snazzy table lamp that should really have a wire coming out of it…
USD50-60. There is review in Japanese here.
Looks like 3*18650 for smaller one.
where does one get his light??
Countryman T10R:
https://www.aliexpress.com/item/Free-Shipping-CountryMan-CREE-XPL-LED-bead-Flashlight-for-Bright-bike-camping-light-lamp-home-climbing/1000004788444.html
Metal switch Convoy S2+ style :exclamation: :exclamation: :exclamation:
Early addressed last year, the countryman T10: * - #49 by vinte77
Countryman lights are good, I owned quite a few in the past. This T10R has this P60 dropin flashlight look.
Never owned one, so thanks for the feedback!
Some time ago I noticed a S2+ similar on AliExpress under Countryman brand and today I was searching and found that one (don’t know how recent it is or not, so sorry if it is outdated).
The metal tailcap is nice on it, though (maybe it has room for a FC switch too! ) :slight_smile:
