SST-40 has 2mm die, with dome that magnifies it to about 2.5-2.6mm (rough estimate)
Xhp35-hi has 2.35mm die, but no dome.
So the smaller total die size in the same size reflector will throw farther. Assuming lumens are about the same 1700-1800 OTF.
Of course xhp35 requires an expensive 12 volt Boost driver which would raise the price.
You could swap an xpl-hi (2mm die, no dome) in and get even more throw even though it has a few hundred less lumens.
Slicing or removing the dome from the SST-40 will give similar throw to xpl-hi due to both having the same size die, but the domes are very hard to remove.
well I can wait. my cover still covers the port from water, I just have difficulty opening it (the handle has been broken which we grab to open the usb port). thanks
I’m sure that a dedicated cover is the best option for BOMBAY but out of curiosity I wonder if a generic port cover from Aliexpress would also work fine…
Coupons don’t work on sale-priced items. However, the Flash Deal price for the SST40 model is $29.99 through 9/15, which is as good as most coupon codes.
28mm according to those who modded their FT03’s earlier in this thread. Banggood sells a replacement with the SST40, but I’m not aware of bare direct replacements.
Ridiculous that BG never mentions the diameter on the replacement MCPCB/emitter page.
Again, I saw on BG FT03 SST40 say 5000k back instock, but when select, processing will be due 0ctober 20… that not too long to wait for me. I just wonder if or wish they are true…
