No coupon codes that I tried have worked so far. I know that sounds kind of entitled. The fact that there was a code for the Cu got my hopes up I guess.
I just tried to order the Ti Nichia but the site would only let me order the XPL.
It did not say which tint. There seem to be XPLs with either two or three different tints.
If I can’t get the Nichia, I want the XPL with 5000K.
I also want the stonewashed Ti but the site would not confirm that either.
I found no coupons for the Ti versions, which are listed as $100.
Correction — the site says. “Get discount code: NDF.”
However, “NDF” did not work for me.
The sandblasted version is listed as preorder, with an estimated ship date of Aug. 20.
Just got my SST20 FW3a in the mail and its by far the nicest flashlight I have ever owned. Took apart the head to get to the leds to clean the domes off a bit. Out of curiosity, I put the flashlight on turbo while I had the optic off and observed what appeared to be some smoke coming out. Anybody have any clue what this smoking was caused by? I didn’t think the flashlight could get hot enough to melt solder so I’m not sure where its coming from. Perhaps some leftover flux?
Always have the optic installed & the bezel tight before running the light at a highet level or Turbo. If you do not you may well fry things. The MCPCB must be tight against the shelt to transfer heat. With the optic out & bezel off it is loose.
