It wasnât for very long but I had no clue that you werenât supposed to fire it up without the front on. Hellova floody beam though. Was almost 180 degrees across. How does the optic transfer heat to the body though? To me it just looks like a ring of aluminum, a circle of glass and a plastic optic. I always thought the heat transferred to the little copper disk that the LEDs are mounted on.
Edit: oh I see it has to be pressed up against something and thatâs what the optic+bezel do.
light seems ok though and none of the LEDâs look smoky or anything.
think I fried something?
Good, you may have dodged the bullet then. Put it on super low, or a level you can look at directly; & see if any of the LEDâs appear off color while on.
Maybe nothing if you did not fry/burnout/screw up any of your LEDâs.
CHECK THIS POST & VIDEO OUT to see what happened when someone else did what you did. (sorry Nev, but I had to share you "taking one for the team") ⌠.
holy smokes thatâs a lot of smoke! I donât think I got anywhere near that amount. I had mine on like that for a similar (or slightly shorter) amount of time but I didnât experience it frying itself like that.
Hereâs a photo I took on moonlight mode. It looks alright to me but one diode looks ever so slightly rosier than the rest. Surprisingly that wasnât the one that got kinda smoky so I guess they just came from factory like that. I never really looked into the diodes like that before so I have no reference point. Anyways, nothing I can really do I guess. Seems like I got lucky though.
edit: none of the leds and the colour still looks about the same. I may have dodged a bullet here
