FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public
I can’t see your picture.
But I can see it in the link in the quote.
It appears that I have fixed the problem
please let me know if it’s only fixed on my end and I’m still an idiot
Yeh it’s fixed & I can confirm that you are indeed an idiot :smiley:
The image might be a bit big for som though :wink:
Don’t worry though because they will tell you :wink:
still an idiot so I guess I got that going for me
fixed the size
now its small
Yeah, it is fixed now for me. Good picture too.
I am no expert… but it looks like you did not make complete crispy critters out of any of your LED’s. :+1:
I do see some dark areas on them all…. BUT, that may just be on the optic or dirty LED’s.
You can clean the LED’s & MCPCB with a Q-tip & alcohol if you wish.
Have you got a pic of yours Nev? So we could compare.
it appears that my unexpected science experiment yielded no permanent damage. I’m still kinda spooked though regardless :weary:
edit: for science purposes, let it be known that I have an SST20 model.
it’s very rosy on turbo without an optic/glass
edit 2: moonlight and peak output look to remain unchanged to my eyes. Of course, I don’t have fancy (non-eyeballs) equipment so I wouldn’t even know if I lost any output.
colour looks about fine as well
Yes
But I can’t get in the photo bucket thingy , I can post them on email, I had one wonky dodgy curflicked led , (sorry mustn’t swear ) it was also curflicked before I took the bezel off, I’m afraid to show it , I’m really scared of getting ridiculed.
Note made & documented for scientific purposes…. :+1: . :wink:
Thank you for your contribution & Welcome to BLF!! :beer:
Hey, just a quick question though. Isn’t it the retaining ring that keeps the pressure on the driver/mcpcb? I’m just looking at the schematic on page 1 of this thread. Haven’t taken the thing apart yet so I actually don’t know how it functions.
edit: found a disassembly album. it does appear that pressure is important. at least some of the heat transfers out the edges of the copper disk though i guess. maybe thats how I got lucky
Yeah, right…from a master. :crown:
Understood on photo bucket…… Fear not of being ridiculed my friend….
I’ll stand by you with a high powered blue or violet laser too…. ready to zap any ridiculer. As far as “holding your hand”…. yes i’ll do that to. But only if it is life or death for you. :smiley:
I do have 3 feelings now… pumped up & ready. So if you need one after getting scolded…… I got spares. :smiley:
Post #13,000!
(at the moment)
Fanks mate.
Wow , the 13000th post.
Yes… retaining ring holds driver in. Just make sure retaining ring is tight/not loose.
The MCPCB the LED’s are on is copper, it must be pressed against the shelf in the head to properly transfer heat.
my guess is the thermal paste is kinda gluey so it kept the mcpcb attached to a certain extent
still, im never doing that ever again
Amen.
In flashlights that use reflectors, it’s the bezel and lens that push down on the reflector, which then pushes down on the led/mcpcb. It’s this contact pressure between the mcpcb and the aluminum shelf that causes the heat to transfer into the flashlight body.
So you don’t want to use Turbo if the reflector or optic is out or the bezel is loose/removed. With no pressure on the mcpcb, the leds could overheat within seconds.
A few flashlights use screws to hold down the mcpcb, but most only use the screws for anti-rotation purposes (FW3A) and they don’t apply any downward pressure. The designs vary from flashlight to flashlight. It’s best to not even turn on a flashlight if the lens or reflector is loose or removed. Moonlight or a very low level is usually okay for a short period of time, but be careful.
This.
It doesn’t matter to me. It does matter to the forum owner/admin. Perhaps you are unaware of that after less than four months.
You were participating in an argument which you initiated.
As a reminder of, the rules that we all agreed to when we signed up:
Your first post accused another poster of being dishonest. That clearly violates rule #1
You then resorted to a personal attack towards said poster. This clearly violates rules #1 & #4. An argument can be made that it also violates rule #2.
Both posts have been reported. Please feel free to discuss the issue with the board owner.
In the future if you see other posters violating the rules I am sure he would appreciate it if you did the same.
