I tap most of mine, sliced or not. I habitually put too much solder on. On the off chance I don’t put too much I will “push” it side to side and up and down a little to make sure it’s even and leave it be.
They’re “rated” /tested to take more but I also burned two out in an FW3A, just not at the same time. I did a reflow and after a while it burned one out. I replaced that one, ran a while, then a different one burned out :person_facepalming:
I went back to the original triple XP-L and haven’t had issues since.
Having tested membrane switches (very similar to the switch used in the FWXX), I would pretty much agree with you. And would only like to add my ¢2. Changing the “nibin” for an o-ring will probably shorten the useable life of the switch.
That being said, I did so and have had great success in eliminating accidental activations. I feel that benefit outweighs the probable downfall of early switch failure.
That is it EXACTLY!! For some reason I missed this image in your post prior to this. Which model was this from? I’ve bought 4 over the years, three wizards, and a predator back in the day.
For anyone looking for a low profile lanyard ring and is willing/able to do some light modding to get it to fit, there probably aren’t many better options
Cool. I wasn’t sure because I don’t own any armytek lights. Looks low profile just like you said :+1:
This looks awesome. Though I wonder if he’s created weak points in the clip with all those trits? And does the glue flex along with the clip? To me it doesn’t look structurally sound. It does look good though
That clip looks great! Thanks for sharing, Martin. :+1: Not so sure about so many trit slots but I like the concept. Does Andreas sell those clips through a venue here?
I get that people have shelf queens but IMO the light still needs to be usable and not fragile. Of course, I don’t know how fragile that clip is. Hence I asked.
I got mine from Barry (Sofirn). They should be the same ones used in the SP36 Anduril and SP10S. I’ve checked a few now and the majority of them can’t handle many amps. Convoy S2+ (8x7135) for example turns blue on the highest mode. I’ve checked and rechecked the reflows. Ended up reflowing XPL-HIs and Nichia 219Cs and not had any problems. So all signs point towards suspect emitters atm.
I haven’t kept up so forgive me if this has been done already.
The button was just too sensitive for me so I traded mine shortly after receiving, was recently gifted another and wanted to make it work for me.
I removed the nipple from the center of the rubber disc and replaced it with an o-ring with an I.D. slightly bigger than the O.D. of the nipple.
This isn’t a flashlight-style o-ring but one you’d get out of one of those kits you can buy at harbor freight.
The action is just stiff enough that I don’t turn it on when putting it back in my pocket.
O-ring seems to stay in place from friction so far. It fits into the dished area around the nipple mounting point.
Instead of the nipple pushing in the very center of the membrane switch, the o-ring pushes further out on the dome.
Works great for now, will update post if there are any issues.
