Thanks for the clarification Scallywag! I tried some stuff but itt didn’t help after all! Still, now I know how it works
Thanks for the tip Lightbringer.
After testing and trying some stuff, last night I decided to call it a end! Pressing the led or the board didn’t help, the only thing that made contact were the tweezers but on the wall.
So, I decided not to invest more time trying to fix it, I replaced the XML2 in the DTP copper board for an XP-G2 (S4-3D, apparently) and put everything back on place and closed the light.
So that you know, the ML mode is lower than the Reylights have (I have an Amutorch SS light with that driver and compared it).
Despite I don’t have the 0.5lm moonlight, I can live with the current one. And the tint of the XP-G2 will suit me better
Thanks for the help, the information, the time and the tips! All are much appreciated
After emitter swap, the moon mode of my S1R is slightly higher now. Hard to tell. It is higher than moon on my S1RII I think. I guess it’s just forward voltage. Hopefully. Still ok to preserve night vision, and much nicer due to the warmer tint.
However: I noticed something similar in my RRT01 2019. When on lowest position, there never was any light before emitter swap. Now there is, even if only visible in total darkness with eyes adapted to it.
I saw your mod and was going to comment and to congratulate for doing it without the flashlight “tripping”. But…it seems you’re facing some issues too! :zipper_mouth_face:
Unlike mine, your moonlight went higher, but I’m glad it still works
And giving that it is warmer tint, it will look less brighter than if it was a cool tint.
There may be something happening on these drivers when we mod the lights.
BTW, on mine I am having issues with Turbo and Turbo S, it doesn’t hang on there as it used to :zipper_mouth_face:
Even with the battery fully charged it decreases fast. I am not sure if it is something related to the driver or the LED, but it only gets there for few seconds and then decreases….
Hope you’re more lucky than me
I came back to your thread because you linked it somewhere.
The S1R driver is not good. If really everything is ok, the battery new and the light warm, Turbo S sustains 1’30 or more (my timer is off, giving it about 1’40 or so). The slightest amout of dirt, cold battery or full moon, and the light behaves like you describe. A Keeppower 700mAh protected cell gives better results but is quite long. At some point, I removed the collar of a 10C cell for the S1RII and use it in the S1R since. Now the turbo modes are almost always stable.
I guess the trouble in mine was that I am now using a non-DTP aluminium board, 3535, instead of the original copper one. I am not sure if it was DTP, but I am guessing that it is making the difference in the capacity to hold a longer time on Turbo…
It was a tricky mod from the beginning so I guess I downgraded the light except in terms of tint :zipper_mouth_face: In any case, I think I’m not going back to the original one. I would like to find a 12 to 14mm diameter board, 1mm thick to use a 3535 footprint led, as I don’t want to shave/sand/fill a larger/thicker one.
From my understanding - though the testing happened before my time and I’d be glad to be corrected if I have the wrong impression - MCPCBs are the primary place in a light where copper vs aluminum makes a measurable difference, and that’s even if they’re both otherwise DTP.
After trying to mod my light again, replacing the led and MCPCB, I ended up damaging the driver.
There was smoke, “that” smell when you burn things and the flashlight doesn’t work as it should.
Some kind of short circuit was created that damaged it.
I’m quite sad I did this to it as the flashlight was working “well” before.
Due to this I have a question: do you think it worths the time and money to ask Olight if they can fix it (sending it to them, paying all the shipping materials and labour)?
I really don’t like having “ghost hosts” of flashlights but given the techincallity of this repair, I can’t do it myself, so…
I think from a usability point of view the S1R is one of the best EDCs ever produced, with the S1RII being technically superior (much better regulation) but of inferior ergonomics (hate that clip).
Yes, try to get assistance from Olight. Maybe they have spare parts for you.
Yeah, that tiny light is quite nice, and I actually like it more than the SIR II. I was stupid trying to mod it one time and even more to try that a second time
So, I’ll give it a try and check what they say about it. If a new light is less expensive than the trouble/expense of sending this to them for a fix, I may have to chose that option. Although I’d really to get this one fixed.
Just wanted to give a quick update on this. I sent a message to Olight, got the first reply a few hours later (considering we are in different timezones), and I’ve been in touch with them about the repair.
It is indeed possible to repair, I’ll need to ship it to China factory. So far I just don’t know how much is the repair fee. After more information on this I’ll be able to decide for sending it or not to them!
Likely, for the price, it won’t be “worth it” in the conventional sense to send it for repair, since you’ll have to pay shipping in both directions as well as the repair fee. On the other hand, it will be tough to get hold of a S1R (as opposed to S1RII) now since it is discontinued. Also, if you’re looking for it with an emitter swap and GITD added… It might be worth checking around to see if any are for sale, or if any modders are willing to take that on for you (the tradeoff there would be a higher price, but reduced risk to yourself).
I did successfully emitter swap my S1, but I reflowed onto the original MCPCB (and otherwise, probably got lucky considering my track record).
Yup, you were right, price for repair (+shipping both sides) wasn’t “worth” the time and money invested. Unfortunately :zipper_mouth_face:
Olight CS replied quite quickly yesterday and today informing that repair would be around 50€ which is more than the light costed.
But they offerred a discount to get a new S1R II on the Olight.es website. It is not wanted I’d prefer, due to the will to repair and not having another empty host around, but…well, I know I won’t be messing with this new light.
I should have gone your way, Scallywag, using the original MCPCB. But I didn’t have any led to reflow onto it, so I went through another route :person_facepalming:
Got it today
Sent last friday from Spain, received it this afternoon
Meanwhile I disassembled the S1R I and I noticed that…possibly it was a drop of thermal paste that poured into a component (nead the - wire) and it completely cooked it when I turned the light on!
Sad, as I will be hard to make the light work again (specially due to polarity it has). Another lost host
