@Flintrock, that was my inital feeling. The powder coat is very thin and the area (compared to the thickness) is big. If the surface of the other light would not be black but reflective a powder coat may have the better cooling by emission.
I will know more soon. Stay tuned.
The XP-L led with FET+1 driver draws about 5A, so 1.66 times the heat in a comparable package. Still assuming that everything is lineair, the calculation is 20+70*1.66=136.2 degC. That is the pill temperature, right under the led will be hotter. A bit too close to unsoldering temperature of the led for comfort.
Yes, you did. But someone else mentioned that the release of heat from the body (convection, thermal radiation) wasn’t fully taken into account. I guess I am really wondering if you or anybody else actually tested it with a FET driver, or in a similar light like the BLF A6.
I know the result will be “freaking hot!”. I’m just curious if it really does get hot enough to fry any electronics or melt solder.
At the moment I am waiting for my S2+ with XM-L2 U6-4C and 7135x8.
Are there any measurings for the heat transfer rate from the star/pill to the head on a stock flashlight?
What I am afraid of is that the head is below 60degC and I think everything is allright, while the LED gets too hot and solders out itself or something else.
Best regards
The newest ‘tan’ S2+ from Simon came with a DTP star, but older S2+ Convoys have a non-DTP star which under normal use are fine up to 3A or even higher. But a test like in the OP might not be very healthy for the led on the non-DTP star.
Dang, old thread I missed somehow with some great useful info, and including this great referenced post: candlepowerforums.com Convoy S2+heat. I can testify a 7135x8 in a S2 or equivalent on max is not healthy to leave alone tailstanding without thermal or timed controls.
Thanks. There is quite a large gap between temperatures that feel dangerous and that actually are dangerous. That gap can be regarded as a safety distance, or if you are a more calculating kind of person, can be used to get more power out of your flashlight.
I suppose it depends on what you consider to be dangerous. If it’s a danger of burning your hand, then temperatures on the outside of the light probably shouldn’t get hotter than 60C. If it’s battery safety, then 80C in the body tube is probably the safety limit. Safety to the electronics, probably over 100C.
Nice test Djozz very detailed, can you guys help me with the next doubt, I bought some 7135’s drivers from convoy, I have the following lights C8’s, M8’s, S2+’s and C8mini’s, what’s the number of 7135’s chips on each light, that will not cause a battery thermal runaway, in case of leave the light unattended on max(100%)?
S2+ grey 77 grams and S2+ cyan 81 grams => 4 or 5 *7135?
Manta Ray C8mini weights about 122 grams and Jaxman M8 is about 117 grams => 6 or 7 *7135?
